Question about Shop Vac 201-13 Wet/Dry Vacuum
Shop-Vac 301-01-00 5-Gallon 1.5 HP Wet/Dry Vacuum
Too loud
MakikiChris
  • 84 Answers
SOURCE: emptying the water from the Shop Vac 925-13 Canister Wet/Dry Vacuum
Stand in front of the vaccuum with the lable facing you, the 2 release levers are on the left and right sides, attached to the motor housing, which sits atop the tank/canister. Pull out and up on the levers, twist counter-clockwise, lift straight up and the motor housing will follow, leaving the tank/canister on the floor.
Posted on Aug 02, 2007
Pyrhyc
  • 2028 Answers
SOURCE: Shop Vac
You **** up water the same way as dirt. It's designed this way, hence the name wet/dry. Just be sure not to get the water in the very top of the unit where the motor sucks the air for cooling ventilation, if water gets in there it can burn up the motor. A little hard way, personal experience, speaking there.
Posted on Jul 16, 2008
wiringlunati
  • 576 Answers
SOURCE: car interior!!!!!
It will extract the water from the interior, just be sure to remove the paper filter from it before you do.
Posted on Jan 25, 2010
  • 447 Answers
SOURCE: Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
Posted on May 16, 2010
small6363
  • 18407 Answers
SOURCE: Shop Vac 84M200 Wet/Dry Vacuum does it blow?
This video will show you.
http://youtu.be/-gCukdig57I
Posted on Oct 02, 2012
Is there an 800 number where I can reach customer service for my shop vac?
I cannot find a 1-800 # but here is some of the contact info from their website. Hope this helps.
https://www.shopvac.com/contact.asp
United States Customer Service
Phone: (570) 326-0502xepmsfks7ymm8bsamlyf2owtpszamzmeaygcpjvaaaaaelftksuqmcc
Fax: (570) 326-7185xepmsfks7ymm8bsamlyf2owtpszamzmeaygcpjvaaaaaelftksuqmcc
Web: Send Email
Regular Business Hours: Monday - Friday, 8:00 AM - 5:00 PM EST
Jul 16, 2014 | Shop-Vac Corporation 18 Gallon 6.5 Peak Hp...
Can u wash the paper filter on a wet dry vac
You really cannot wash the paper filter. You can blow it out with an air hose if you have access to one, or vacuum it off with another vacuum. If it does get wet you should let it dry outside of the vacuum before you use it again.
May 10, 2014 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
WHAT IF THE SHOP VAC IS BLOWING INSEAD OF SUCKING
Check for blockage and make sure that the hose is in the correct port.
Mar 19, 2010 | Shop Vac ShopVac 3 HP 2 Stage 10...
Car interior!!!!!
Jan 25, 2010 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
How do you change the ridgid 9 gallon wet/dry shop vac from a dry to wet vac? Is it simply changing the hose to the back fitting?
all you have to do is open it up and take the paper filter off and then it's a wet vac. If it has a foam over filter you leave that on
Oct 13, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Using shop vac 52722-90 for wet applications
yes, the foam filter is what you should use, also make sure you remove any bag, or paper filter, the water would make it fall apart.
Sep 16, 2009 | Shop Vac ShopVac 3 HP 2 Stage 10...
How do i go from dry vacuming to wet vacuming with the rigid shop vac
can I run my sears shop vac without the paper bag, for dry pickup?
Jan 29, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Moto Brushes Problem... Who could help?
where can i fine moter brushes for my ridgid 5.25 hp 16 gal. wet dry vac.
Oct 02, 2008 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Shop Vac 201-13 Wet/Dry Vacuum Logo
23 people viewed this question
Top Shop Vac Vacuums Experts
Mike
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
