Question about HP Compaq nc6000 Notebook
I am connected to a Netgear 75 wireless but my internet will not activate because I need to have a smart card reader activated
I need my smart card reader activated on my compaq using a wireless netgear network
SOURCE: INTERNET TROUBLES WITH ATHEROS AR5005G WIRELESS NETWORK ADAPTER
how do you do that?
Posted on Mar 31, 2008
  • 218 Answers
SOURCE: Wireless problem with laptop, HP DV9000
Follow the link below, read about this problem, and then call the special HP phone number. They are repairing these computers under a special enhanced warranty policy, even if the regular warranty is expired. Good luck!
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01087277#c01087277_identify
Posted on Jan 04, 2009
SOURCE: Activate Wireless netwerk connection HP Compaq 6710b
have hp computer,unable to switch on wireless connection.im just a novice.HELP
Posted on Mar 16, 2009
SOURCE: insert smart card into reader
u have not properly removed it when it is used.u insert u r card and press continue and properly remove it
Posted on Apr 16, 2009
  • 81 Answers
SOURCE: hp compaq nx8220 (insert smart card into reader)
you need to push and hold control, alt, and delete to initialize the start up.
at this time it will ask you for your username and password.
Posted on May 31, 2010
I was able to connect to my HP Compaq Presario V2000 Laptop to my WiFi Network using NetGear. When I reconfigured the network I could connect to all other network like Dell Lptop , Nokia Smart Phone and HP...
Hi!
Your Compaq V2000 has an Intel Pro Wireless 2200 BG wireles adapter. (doesn't support N, but that's not the point I think)
If your new network configuration is based on WPA/WPA2 encyption, this adapter has some known problems to establish a connection. It works great with WEP, but not so well with WPA.
Sometimes the issue can be solved by installing the latest versions of drivers and software for the wireless adapter.
If it still doesn't work, a known workaround is to disable via device manager all other network adapters in the computer (ethernet adapter), leaving active only the Intel Pro 2200 wireless adapter.
Hope it helped,
Bogdan
Sep 25, 2011 | HP Compaq Presario V2000 Notebook
My WNA3100 USB wireless adapter connects to the Internet via the NETGEAR Smart software. However, the computer is not reading it as an active wireless connection. Instead, the NETGEAR software says I'm...
I Would guess, that windows is leaving the handeling of the wireless connection to the NETGEAR software, and therefor not registering the device ad connected.
To make Windows regain controle take a look at this: http://www.bukisa.com/articles/115878_how-to-let-windows-configure-your-wireless-network-connection-in-xp
Mar 13, 2011 | NetGear WirelessN 300 USB Adapter WNA3100
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
Good day to all. I have a problem of my NETGEARWPN824V3
To access the Smart Wizard installation and configuration program on your router:
  1. Connect your router to a computer by plugging one end of an Ethernet Cable into any of the four LAN ports on the back of your router.
  2. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  3. To install your router, simply click on the "Setup Wizard" link at the top of the left-hand navigation menu once you are logged into your router.
Configuring Smart Wizard for WEP encryption:
  1. Click Start then go to All programs. Look for NETGEAR wireless adapter folder then select the NETGEAR Smart Wizard.
  2. NETGEAR Smart Wizard wireless utility should appear on your desktop screen.
  3. Click on the Networks Tab. This will automatically scan for all the available wireless network within your proximity.
  4. Select the SSID of the wireless network that you want to connect, then hit the Connect button.
  5. On the Settings tab, click WEP under the Security option then select Enter Key Manually.
    Note: If the network key consists of 10 characters, set it to 64 Bits. If the network key consists of 26 characters, set it to 128 Bits.
  6. Type the 10 or 26 characters (Hexa decimal) keys on the space provided.
  7. In the Profiles field, assign a name to help you remember this wireless network settings in the future, then click Save Profile.
  8. Click on Apply to validate the settings.
  9. Once connected wirelessly, go to About tab and check for an IP address.
Configuring Smart Wizard for WPA encryption:
  1. Click Start then go to All Programs. Look for NETGEAR wireless adapter folder then select the NETGEAR Smart Wizard.
  3. Click on the Networks Tab. This will automatically scan for all the available wireless networks within your proximity.
  4. Select the SSID of the wireless network that you want to connect, then hit Connect button.
  5. On the Settings tab, select WPA under the Security option.
  6. Type the WPA password/passphrase inside the empty field next to the WPA drop down menu.
Best of luck and have a happy and safe 4th of July weekend!
Jul 02, 2010 | NetGear RangeMax WPN824 Router
I have installed uninstalled my laptop to the netgear wireless. It won't connect to the secured wireless but only to tthe unsecured It then says TCP?IP disabled for this connection
Hi and welcome to FixYa,
Initially, which is the Netgear, the WiFI / AP router or the wireless networking card of the laptop?
Offhand, that there are at least two (2) networks that could be detected by the laptop indicates that the WiFi is both receiving and transmitting (it works and therefore the issue is settings & configurations). Which of the networks is yours; the secured or unsecured?
Alternately, determine the SSID of your WiFi network and the PASSKEY used or the security system used (if one is used in your system/network). Additionally, are you using the Netgear Smart Wizard Wireless Assistant or the Windows built-in Wireless Network Connection?
For the secured system, use the PASSKEY determined as per above; for the unsecured, it may be employing MAC filter, try manually inputting the IP Address, Subnet Mask and Default Gateway.
Postback result(s) / updates.
Good luck and thank you for asking FixYa.
Oct 14, 2009 | Computers & Internet
Insert smart card into reader
Apr 16, 2009 | HP Compaq nc6220 Notebook
Need to know the solution
After a small amount of trouble, I have configured my Win 98 laptop to use
Netgear WG111v2 wireless modem to connect to my wireless router. I used
the driver from the CD that came with the modem, following the instructions and
got to the point, after rebooting a couple of times, where I was connected to the
router, but could not reach another computer on my network (or the outside world).
I double-clicked on the wireless model icon in the system tray and noticed that,
on the NetGear SMART WIZARD panel, the WEP key was set to use the
"Create from passphrase" option, even though I supplied the already generated key (the
hex numbers) during installation of the modem. (The modem was using the key
as a passphrase to create another key.)
To fix this, on the SMART WIZARD panel, I
selected the "Enter key manually" option and, er, entered the hex key (the one
the router/access point uses for security) manually.
I hit "Apply" on the Wizard and, lo and behold, I was pinging the rest of my network.
I rebooted one more time (I had some leftover bad settings in my "Network Connection"
TCP/IP entry for the WG111 connection; I reset them before the reboot
to allow my network to automatically assign an address) and I was then able
to view my favorite site (bythestadium) from my favorite browser (firefox)
Nov 20, 2007 | NetGear WG111 802.11g/b Wireless Adapter
HP Compaq nc6000 Notebook Logo
16 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
