Question about Fisher and Paykel Fisher & Paykel Washer
Does GWL Fisher and Paykel have a diagnostic feature
  • 22 Answers
SOURCE: GWL-11 Fisher Paykel wont turn on and water on the floor
Look at my issue "eco smart won't drain, smells hot". Mine is top load.
If you see puddle on floor and eventually won't run at all and smell electric burn motor, it could be same issue I had.
Unplug washer. Tip washer back. If you see water dripping through the black motor area, you need to remove the black motor and the white plastic unit above it. Look for a white plastic clip that is attached to bottom of washing machine. Push that clip with your finger and twist the whole plastic unit/black motor. It all comes off in one piece.
Look on side of this unit and you will see 120V or 240V. Mine is GWL10US and is older model. Was told by repairman that new units use 120V. That is what you need to order. It comes as one piece and you just twist it back on. I had done most of this. Repairman came and 5 seconds cost me $65.
Posted on Oct 20, 2008
SOURCE: fisher paykel codes
There is a code book inside the top of the washer where the electronics are.
Posted on Apr 06, 2009
  • 3 Answers
SOURCE: Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Posted on Oct 09, 2009
  • 67 Answers
SOURCE: During the rinse cycle, our GWL 11 Fisher & Paykel
The problem is in the pump, so it will not pump out, you will need to find another way to empty it, removing the agitator will make the job easier.
When you get the water out the pump can be accessed from underneath, it turns anticlockwise to remove it,.
I would buy a new pump as it is most likely that is all that is wrong with it.
Posted on Apr 18, 2010
Testimonial: "My pump is definitely the source of the burning smell. Thanks for the quick reply."
  • 713 Answers
SOURCE: I have a Fisher Paykel Model GWL 11 washing
Yes I can help.Starting from left to right on the line that the lights are lit the fault code values of each are , Starting from the far left they go 1st=128 2nd=64 3rd=32 4th=16 5th=8 6th=4 7th=2 and 8th=1.Add up the lights that are lit on your machine and reply back and I will let you know what part is faulty.
Posted on Jun 05, 2010
I ran the diagnostic on my fisher and paykel gwl 11 and it has a fault code 51. Is that more than just a diverter value?
This is error code 51
51. (00110011) Phase 5 and 6 Eco - Diverter Valve Fault
Primary: The motor controller has registered a drop in water level in the
recirculation phase of the wash cycle, water is being drained instead of recirculated.
Or water has been sprayed onto the Valve from an external source and caused the
solenoid to blow.
Action:
Turn the power off at the machine but leave the power on at the wall, then measure
the voltage across the terminals of the wax actuator, if a reading of 230V is
achieved the motor controller has failed due to the valve and both will need to be
replaced.
Secondary: Check for blockage in the valve itself or a broken hinge mechanism.
Mar 12, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Washing Machine Model GWL 11
The power supply needs three resistors removed,R129,R130,R131.
and one 1megOhm put in it's place.
Feb 25, 2012 | Fisher and Paykel Washing Machines
GWL Washer won't spin only beeps; Diagnostic lighs:the third light is lit up green in the bank of lights on the left; the first light on the right is lit up orange and the third is lit up red. Thanks,...
GWL Washer won't spin only beeps; Diagnostic lighs:the third light is lit up green in the bank of lights on the left; the first light on the right is lit up orange and the third is lit up red. Thanks,Hepi
Jul 24, 2011 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL 15 will not drain, nor go into spin cycle. Cannot find a service manual for this machine.
normally thats a bad door safety switch,, bypass it with a Jumper wire , if it works with the jumper, replace the switch
Jul 13, 2011 | Fisher and Paykel Kitchen Ranges
Model gwl 15 us not draining
find black rubber drain hose under machine and squeeze several times to loosen soap and hair gunk.
start the mahine on the rinse cycle. This should start the draining process.
Dec 08, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher and Paykel GWL11 Top Load Washer won't drain
Could be something in the pump. The pump is on the bottom of the tub.
It has a locking tab which you release and then twist the pump a hair and it will fall out. Warning: Have rags ready! I have the original GWL service manual and the GWL 11 supplimental manual. Let me know if you want them.
Apr 28, 2010 | Fisher and Paykel GWL11 Top Load Washer
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Have an eco washer gwl 10. worked fine for years today stopped wokring. tried all trouble shooting and diagnostics. always coming up error code 43. replaced switch and no different. any idea?
Hi there
Try bridging the switch out(join the wires together) and if that doesnt work you may have to replace your motor controller module.
I hope this helps.
Nick
Aug 02, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher paykel codes
Apr 02, 2009 | Fisher and Paykel GWL11 Top Load Washer
Gwl 10 washer
Check that the pump isnt blocked.
Mar 01, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
11 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
