Question about Microwave Ovens
Panasonic Genius inverter microwave, 1100 watts NN-SD277B. Keeps blowing 20 amp ceramic fuses, changed the interlock door switches, still blowing fuses. The microwave is on its own designated circuit breaker. when i change the fuse it will receive power, lights work , fan works , but as soon as i try to start oven to warm something it immediatly blows fuse. Could it be i need to change the inverter?
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave keeps blowing fuse
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links with info on part testing:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
You can usually find helpful exploded view diagrams and order parts by
entering your full model number here: http://tinyurl.com/gv383
Please write back with your brand and model number if you need further help.
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
SOURCE: Panasonic Microwave inverter oven model,
10 Amp fuse blown inside oven.
Posted on Apr 19, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave Panasonic Genius Prestige Model
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
The TCOs you need to be concerned usually with have all black or white wires only. Please reply with photos of your interior if you have questions.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can order Panasonic parts here.
You can find an authorized Panasonic servicer here.
Posted on Sep 28, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic nn-p295 blows buss fuse when turned on for cooking
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer. But this is likely an inverter model, so it wouldn't have one and would be some other component in the inverter I'd say.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
http://www.gallawa.com/microtech/mag_test.html
The best place to order Sharp parts is Tritronics. Or you can call them toll-free at 866-779-5835.
Posted on Dec 26, 2008
  • 3 Answers
SOURCE: Microwave oven blowing 20 amp ceramic fuse
Chances are if the varistor fails, it fails drastically causing a short circuit across the supply. It will sit across the supply (it will look like a thick ceramic capacitor) and you can check for continuity after isolating that at one end. If it shows low resistance (it should show almost open circuit with a Digital meter), replace it.
It need not be the culprit. If you are familiar working with High voltage circuits ( they are lethal inside a microwave ovens as the current capability is high here), you can discharge the doubler capacitor and isolate the high voltage diode to check for shorts in the HT area.
Posted on Mar 18, 2009
MY EMERSON MW1119B STOPPED HEATING
Sounds like it's broken. Go for Panasonic next time, they make better microwaves. Here's one I was looking at http://bestmicrowavereview.com/panasonic-nn-sn651b-genius-1-2-cuft-1200-watt-sensor-microwave-review/
Jan 04, 2013 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave fuse keeps blowing on my Panasonic Microwave NN-9854P
I would check the door interlock switches and then if that doesn't fix it replace the invertor board and possibly magnetron.
Feb 21, 2011 | Panasonic NN-P295SF Microwave Oven
Kenmore microwave 80404400 no power
This is typical of the 20 amp fuse blown. It can blow due to slamming the door or even opening the door to quickly while it is running. It could also blow if there is a failure of one of the door interlock switches. This fuse is ceramic and looks similar to a cylinder automotive fuse and is located behind the control panel on this model.
Apr 20, 2010 | Kenmore 80412 Microwave Oven
My Panasonic Inverter Genius Sensor 1250W Lights
microwave is in lock mode. How do you unlock to use?
Feb 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Internal ceramic fuse repeatly blown.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount. See: http://www.microwavedisplay.com/doorsw.txt in this case.
If this unit has an inverter some parts are difficult for the average do it yourselfer to replace, such as parts which are spot welded, not using removable connectors.
In such cases, it's best to replace the entire inverter.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on them.
In Canada, you can find an authorized Panasonic servicer here.
You can order Panasonic parts from
Encompass or by calling 866-779-5835.
Jan 09, 2010 | Panasonic Microwave Ovens
Error F7
Microwave will not operate (cook). F7 error code
appears on the display.
Electrical circuit interruption between L1 and Neutral in
the microwave inverter circuit.
Possible reasons:
1. Check door, hinge and cavity front alignment and adjust
as needed.
2. Check the operation of all interlock switches.
3. Check over temperature protector for the magnatron.
4. Check all Cavity Thermostats for closed circuit.
5. Unplug the oven for at least 40 seconds. If this solves
the problem
A. Check the Cooling Fan for proper operation or
blockage
B. Check the resistance of the magnetron thermostat.
It should be 0 Ohms, replace if necessary.
6. Check that the control cable to the 1100 watt inverter
is properly connected to plug P2 on the display PCB
& Adjust or Reconnect
7. If interlock switches operate correctly, replace 1100W
inverter.
8. If problem persists, replace control assembly.
Nov 18, 2009 | Whirlpool GH9176XMS 1100 Watts Microwave...
Panasonic NNA554W blows 10a fuse when microwave comes on
Possibly the interlock monitor switch is bad or out of adjustment. This switch is designed to create a short circuit across the power line (and then blow the fuse) if you attempt to defeat the door interlock and operate the oven with the door open. A shorted capacitor or diode could also cause the fuse to blow. Because of lethal voltages inside and the possibility of microwave leakage if repairs aren't done correctly, you are best off leaving microwave service to professionals.
May 15, 2009 | Panasonic NN-SN657SMicrowave Oven
PANASONIC NN-S952WF FAN AND CAROSEL STILL CONTINUES WHEN DOOR IS OPENED. NOT SURE IF THE MICROWAVE CONTINUING AS WELL WHEN DOOR IS OPEN.
The door interlock system has beem compromised , meaning it shifted out of position or the interlock has broken. Dont continue using it like that it will eventually blow the fuse.
May 13, 2009 | Panasonic NN-S952 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
