Question about Indesit Refrigerators
Door seal indesit FB 560/561
Seal size 100 X 70 top door seal size 70 X 70 bottem door
5 Suggested Answers
  • 1075 Answers
SOURCE: Indesit WD12 washer dryer with a leaking door seal
this is no easy job and you will need a copy of the work-shop manual; sometimes they can be downloaded of the internet. There are no real specialist tools, but im telling you now there will be a lot of very red knuckles .good luck.adrian
Posted on Feb 27, 2009
  • 236 Answers
SOURCE: Replacing a DoOr Seal
as i remember it, you will have to take off the door front panel and slot in the seal from inside of the lower door. if im thinking of the wrong model and the advise is wrong i will get back to ya.
Posted on Mar 16, 2009
blueextc3221
  • 15935 Answers
SOURCE: refitting the door seal on my Indesit W160
A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn't cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
Step 6--Removing the door. After you remove the three screws in Step 5, there is only one screw to remove in step 6 on my model. It was hidden behind a plastic cover that makes the hinge look pretty. You'll see on the inside of the door that two plastic prongs/tabs extend into holes in the hinge. If you push on them laterally and pull out, the tabs will pop out. Outside the door on the left side of the machine, you'll see the plastic cover that is connected to those plastic tabs and is hiding the hinge. On the outside cover piece, there is a flat tab that extends up into the plastic housing above it. If you gently pull the cover downward and out the whole plastic cover will come off revealing the one screw that needs to be removed to take the door off.
Step 7--Removing the Kick Panel. The middle screw is more difficult to reach than the sides. You may need an extension for your screwdriver and/or shims or a helper to prop up the washer while you remove the middle screw.
Step 8--Removing the washer casing. The step says to remove the screws and set the casing aside. My model (2005-ish) has wires connected to it. Rather than being able to remove it, it swings open like a door with the wires as the hinge. I simply used a box to prop up the outside part of the door so it did not sag and stress the wires.
Step 9--After you remove the old rubber bellow, you will likely see a lot of dirt, mold, and junk where the bellow was. Clean that stuff off with a cloth sprayed with a gentle cleanser before installing the new bellow. We replaced our bellow because of mold and mildew and bad smelling stuff. That dirt and junk is part of the problem. Clean it up before you install the new clean bellow.
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 17, 2010
  • 670 Answers
SOURCE: water drips out of bottem of door and i change the
I have the same problem with my dishwasher. I have replaced the door seal and it still leaks. It seems like the channel where the seal fits is just a little too deep for the seal. As a temporary fix, I pull the door seal out of the channel about 3/8 inch on the side that leaks before closing the door to run the dishwasher. When the door closes, it pushes against the seal and that seems to work for me. A more permanent solution would to be to add about a 1/8 inch filler gasket into the channel then put the door seal back. That way the seal will press on the the gasket instead of bottoming out into the channel. Hope this helps you.
Posted on Dec 07, 2010
I need to replace a washing machine door seal (indesit wm12x). Do i need to remove the top or can i do it from the front ? Any other tips on the procedure would be great. Thanks
It would be adviseable to rempve the top, and also tilt the washer to the rear, as it makes it easier to change the seal, and gives you more room to get your hands in.
Please rate my comments.
Thanks.
Oct 30, 2009 | Indesit W 123 Front Load Washer
How do I change the door seal on my indesit washing machine?
Take the top off, remove the retaining rings around the existing seal, remove the seal by un-peeling it from the front frame
Make sure that you check to see if the old seal has a shape which must be fitted back in the same way (Is the seal a uniform shape all the way around)
Refit the new one and re-fit the retainers
Used a little washing up liquid to get the gasket into place
Make sure that to tighten up the retainers
Oct 03, 2009 | Indesit WA 125 Front Load Washer
Mar 16, 2009 | Indesit 24 in. D63 Free-standing...
How to fit new door seal on Indesit W103 washing machine
this is not an easy job,go online and down load a copy of the machines manual even check out indesits web page.adrian
Feb 23, 2009 | Indesit W 123 Front Load Washer
Feb 22, 2009 | Indesit W 123 Front Load Washer
We have just bought a new door seal for a indesit washing machine please advise how to fit.
Hi to replace the seal take off the metal ring with a small screwdriver at the spring on the front of the machine than take off the seal then take the top off the machine and locate the screw on the metal ring undo a bit then take off seal replace and put back the new seal in reverse order as I have written
Jul 18, 2008 | Indesit Washing Machines
Indesit D4000 Dishwasher seal
you will find the door seal has some shape to it at the two corners,if not fit the seal from one of the bottom corners first with about 3-5millimeters passed the frame that the seal fits into,then push in all the way round to the other end,the seal has a flap type shape on it which should be fitted with the open end apearance of the seal (flap)pointing towards the door
May 30, 2008 | Tappan 18 in. MDR251RE Built-in Dishwasher
Indesit washing machine wd10uk
Hi, you will have to remove the door seal fastener first, the just push the door seal inside the drum.
Mar 30, 2008 | Indesit WA 115 Front Load Washer
Indesit washing machine model WM 110 6kg
There are shops in Dubai which could help you. And lots of Philipinos in Dubai - they could surely help.(!) Wil try to get you an email of a shop.
Jun 14, 2007 | Indesit WA 115 Front Load Washer
Refrigerators Logo
20 people viewed this question
Top Indesit Refrigerators Experts
Dado
Brian Coughlan
John Tripp
John Tripp
Are you an Indesit Refrigerator Expert? Answer questions, earn points and help others
