Question about RCA Televison & Video
Hi, i just brought a rca led4045rq on 1/31/14 and its only now 2/5/14 but the tv made a loud screeching noise and turned off! had to wait awhile and even unplugged it to get it to re start but what ca
As stated tv is less then week old but made a screeching sound and turned off. had to wait and unplugged set before re starting. what causes this and why does it get hot. the label say nov,2013 so why am i having this prob? willing to fix myself no doubt but need to know what to do. thanks
tvtek
  • 1284 Answers
SOURCE: Speakers have died?
Probaby the stereo decoder IC went bad or a supply voltage to it is too low or noisy. If it has audio output jacks on the back of the TV, connect it to an external amplifier and see what that sounds like. If it is ok in stereo or mono mode then the amplifier in the TV is bad. This will prove that the stereo decoder is ok.
Posted on Feb 01, 2007
  • 192 Answers
SOURCE: Samsung DLP loud vibrating noise
The color wheel is the most common problem in DLPs that cause noise. To determine the cause: Turn the set off. If the noise goes away after about five seconds, then, the problem is the color wheel. If the noise goes away one to two minutes after shut off, then, the problem is a fan. You can find an Authorized Servicer in your area that can tell you the price of repair, by clicking on the Samsung link: http://www.samsung.com/Support/ServiceLocations/index.htm
Posted on Apr 22, 2007
tvtek
  • 1284 Answers
SOURCE: Loud pop - no picture
Your X and Y circuit boards are bad. It might require the replacement of the power supply as well. This is not uncommon for LG/Zenith plasmas to have this issue. Not a do it yourself repair.
Posted on Nov 25, 2007
SOURCE: No picture and No sound
I have the same problem here with my Philips 30PF9946/37
I'm not sure this can be diagnosed as an inverter failure, unless there is a another inverter board in there I'm not aware of. The only inverter I found (actually two) in this unit is the pair of KLS300A1 inverters which drive the CCFL tubes.
Since I personally get a green power and light AND the CCFL backlight comes on, it seems unlikely that the inverters have failed.
Would love to hear from anyone who can ident the failure in these units - there's certainly a LOT of these around that have failed in exactly the same way.
Posted on Mar 16, 2008
SOURCE: RCA TV stopped working
Time to go to BEST BUY and nuy a better tv
Posted on Apr 16, 2008
Sound goes off to a screeching noise
The sound board is usually part of the main logic board that contains logic, sound processor/amplifiers, tuner, source selctors. Not cheap.
But you should try hooking up a set of powered PC speakers to the Audio line out RCA (Red and White) jacks on the back of the TV to see if you get the sound OK there first, if you do then the power amps that drive the speakers may be bad or it may not be getting the DC voltage feeding it. If it works with RCA jacks, then just keep on using it that way, you may want to set the audio line out to be 'VARIABLE' in the sound set up so you can use the TV remote to control how loud the audio signal feeding the powered PC speakers to be.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Parts: www.shopjimmy.com
Jun 16, 2010 | Televison & Video
My rca tv hd61lpw62 power button blinks five times and wont turn on tv
i have a rca hd61lpw62 makes loud noise and i lose the picture still have sound tv repair man fixed it once and said he had to soilder ballist one month later doing the same thing this time he said it was the color wheel sounds like he is just guesssing you can wait a few moments and it comes back on help please
May 04, 2010 | RCA Televison & Video
LCD HDTV turns off, displays lines & static w/ loud noises
check in your manual and follow instructions on updating the software. you download the file to computer then move it to a memory stick (USB), then simply insert it into the tv
Mar 01, 2010 | Televison & Video
RCA HDTV DLP Rear Projection TV wont turn on
RCA Projection tvs are trash,should be off the market.
Mar 29, 2009 | RCA Scenium D40W20 40" Rear Projection...
98 gs300 loud screeching noise that last for about 5-10 seconds
The only four rotating items under the hood are
engine
power steering pump
A/C compressor
and smog emission pump.
==== I would check the fluid level on the power steering first. Check for pink fluid leak on the ground,
==== Check the A/C system with the wheel turn to one side and APPLY ALL LOADS.
Example: high beam on,A/C max,radio on and deforster on.
This will give you system a stress test.
All eyes on the pully and locate to part that generate the loud screeching noise.
My bet is on the power steering pump.
Please post more info on the comment window.
I will follow up on it.
Feb 12, 2009 | 1998 Lexus Gs 400
Loud screeching noise when it powers on
sounds like picture bulbs maby %30 i think it may need to go in for a check up they can pin point the problem hope ive been somewhat helpful thanks viper
Dec 31, 2008 | RCA Televison & Video
Will not turn on
sounds like your flyback has want out (cheap part around 70.00) but the labor will cost ya unless you do it yourself
Dec 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rear screen tv
replaced flyback transformer
Sep 17, 2008 | RCA F36650 36" TV
RCA HD50LPW175
Sounds like the color wheel is failing.
Dec 18, 2007 | RCA HD50LPW175 50" HDTV
Loud noise from tv
if this is a very annoying screeching or sqeualing type sound, it is, in my experience, the "color wheel" which is located inside the lite engine. this is a replaceable component whick costs about $110....i've done this repair many times with no problem....
Oct 30, 2007 | RCA D44LPW134 44" HDTV
Televison & Video Logo
29 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
