Question about Plumbing
Price pfister f 534 70. I cant get the mounting ring past all the hoses and connections... is there a trick?
I have tried for over an hour all different ways to get the mounting ring past all three connectors. I can not get them through. Is there a trick?/
  • 164 Answers
In general, you pass through the connectors one by one. Also, the connectors can be taken out by turning/twisting the hose.
Here is a link for the installation instruction:
http://www.faucetdirect.com/mediabase/specifications/pfister_f_534_70_installation_120605.pdf
You may find how to put all the parts into the assembly.
Posted on Feb 22, 2014
4 Suggested Answers
SOURCE: I can't disconnect the quick connect sprayer hose Price Pfister
Squeeze the bottom half of the 2-piece black plastic cylinder that connects the sprayer to the faucet. Gently pull down on the hose. If the connector is not a 2-piece cylinder, you need to push the connector up, as if you were connecting it, and while it is pushed up tight, pry up on the small ring on the top and gently pull down on the hose. I know it sounds like you need 3 hands, but it works (even though it is a pain).
Posted on Apr 22, 2010
SOURCE: Replacement Price Pfister sprayer/hose
I called Price-Pfister and they sent out the parts free under their warranty, plus a few dollars for postage.
Posted on Apr 26, 2010
mkh5094
  • 145 Answers
SOURCE: i cant get the price pfister faucet out of kitchen...
There are several nuts on a faucet but I'm assuming you mean the plastic nuts that hold the faucet to the sink. They many times do jam up. To get them off you need to use a large flat head screw driver and a hammer and chisel them off. Chisel from the outside edge in toward the threads on two different sides.
Posted on May 23, 2010
How do I disconnect a price Pfister quick connect?
There is a tool that presses on the collet at the tend of the fitting. It look like an open ended wrench.
https://www.youtube.com/watch?v=dCbXw5bP9I8
Price Pfister Quick Connect Sprayer Hose Removal - YouTube
? 1:50
Feb 1, 2014 - Uploaded by brianmcdrummer
In a few easy steps I'll explain how to remove your sprayer hose from your diverter. ... Pfister Faucets 17,981 ...
trick to removing price pfister quick connect sprayer hose - YouTube
? 0:23
https://www.youtube.com/watch?v=vTJefezIvwg Aug 14, 2012 - Uploaded by Biren Patel
This shows you how to remove the price pfister "quick connect" hose on the end of the kitchen sprayer head ...
Pfister - How To ' Remove a Sprayer Hose Connection
www.pfisterfaucets.com/support/faqs/sprayer ... Order Parts, FAQs. FAQs. Resources. Step by step instructions on how to remove a sprayer hose connection for the Price Pfister 529 Series faucet.
Pfister - How To ' Remove a Diverter Tee Connection for the 26 Series
www.pfisterfaucets.com/support/faqs/diverter ... Information · Order Parts, FAQs. FAQs. Resources. Step by step instructions on how to remove a diverter tee connection for the Price Pfister 26 Series faucet.
Pfister - Removing quick connect HELP ' Terry Love Plumbing ...
terrylove.com > Home > Forums > Plumbing Forum, Professional & DIY Advice Dec 13, 2006 - 6 posts - ‎5 authors
Purchased a replacement sprayer (with hose) for a Pfister Contempra faucet. How the heck do you remove the old hose from the handle assy? How do disconnect price Pfister quick connect Google Search
Jan 08, 2017 | Price Pfister Plumbing
How to disconnect the quick connect spray hose in a Price Pfister Parisa
I also needed to remove the "hidden" flow restricters from my Price Pfister Parisa Kitchen Pull out faucet. The hot water side had never flowed the same as the cold side. Now both sides are flowing the same as should have been all along.
Nov 30, 2012 | Price Pfister Marielle Kitchen Faucet with...
How to replace a price pfister kitchen faucet sprayer
The sprayer should have a threaded fitting on the end of the hose. Unscrew old one from valve, pull hose out the top, feed new hose back down into cabinet and screw in to where old hose was attached.
Sep 23, 2012 | Price Pfister Pfister T26-4ypu Rustic...
Re: single handle lav. Ashfield: cold water flow is fine; hot water flow severly restricted. Have disconnected supply tube and flow is fine into a bucket so it is not a problem with valve or supply...
I have the same problem with my Ashfield faucet.
I am going to contact Price Pfister and try to get a new 'cartridge'.
On another note, my Ashfield towel rings are also broken. The connection where the two pieces meet is so weak it cannot handle daily use. I am going to bring this up with Pfister as well.
It doesn't seem like Price Pfister has very good products.
Dec 31, 2010 | Price Pfister Ashfield Single Control...
HI, parts can be found from amazon (entire assembly too), take a look here: Amazon com price pfister marielle kitchen faucet parts. Wish you best of luck. Cheers
Apr 10, 2010 | Price Pfister Marielle Kitchen Faucet with...
New Pfister Avalon Install: Spray Hose Works, Faucet doesn't
sounds like your diverter is stuck or improperly installed ,try tapping at diverter location to free up diverter the other thing to try is remove the little device on the end of spout make sure its not clogged with debri
May 04, 2009 | Price Pfister Marielle Kitchen Faucet with...
Plumbing Logo
44 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
