Question about Canon PowerShot SX20 IS Digital Camera
IMG_8122.JPG: Not enough quota is available to process this command (Import Photos and Videos) won't let me "try again"
Options are "try again," "skip this file" and "skip all files with errors". I can't get it to "try again", so i tried "skip all files with errors," and it downloaded the title i gave but none of the pictures, so when i went to my Pictures files, the titled file was empty.
  • 51 Answers
SOURCE: Unable to download pictures from canon A530 digital camera
Try removing the memory card and inserting it again.
Also, does the computer detect the camera properly?
Posted on Oct 18, 2007
SOURCE: Can't get videos off the camera
When you connect the camera to the pc there's a box with options for what you want to do. When I downloaded my photos and videos using the scanner and camera wizard it worked fine.
Posted on Nov 21, 2007
Stonebraker
  • 167 Answers
SOURCE: my pictures wont import
Google's Picasa program should be able to get those images for you, http://picasa.google.com/ (it won't be picky like Canon's Software).
If worst comes to worst:
1. Open My Computer
2. Right click on the memory card
3. From the popup menu, click "Search"
4. In the left hand pane, you should see something reading "What do you want to search for"
5. Below that, click the item that reads, "pictures, music, video"
6. Start the search
7. Once the search is finished If your pictures and video appear copy and paste everything to your desktop (or wherever you want the photos)
Additionally, once you get everything off the card you should probably format it using the camera (see your instructions manual) to make sure you don't get that error again
Posted on Jan 05, 2008
  • 39 Answers
SOURCE: Video Format
If your computer has a SD card reader, you might be better off putting your memory card into your computer and just copying the data.
Have you made sure your iPhoto is up to date? Perhaps a new update caused this problem.. Maybe you should try an older version of the software. Also, you might want to try other software. (I think you are on a mac?), you might want to try the software that came with the camera, if it works on your computer.
Posted on May 05, 2008
tomhar
  • 20 Answers
SOURCE: need to change file name
This is one of those "it depends" kind of answers. I'll assume that you have copied the picture files from the camera to your computer. If not, let me know and I'll help you through that -- while possible to rename the files when they are on the camera (actually on the "compact flash" memory card), it's not a great idea.
So the pictures are in a folder somewhere on your computer, probably "My Pictures" if you're using Windows, and somewhere similarly named if you use a Mac. On windows open My Pictures, and click the filename (IMG_XXXX) once, then once again and you should be able to type a new name. On Mac, use Finder to locate the file, click it, and select Edit > Rename.
That's the hard way. Chances are you are using some program to help manage the images -- to import them from the camera, to edit them and so on. If you're using the Canon software, forget it -- use Picasa (free from Google at picasa.google.com) on Windows, or iPhoto on Mac (there's a Picasa version coming for Mac soon -- it's awesome). Once in Picasa or iPhoto, renaming should be pretty obvious.
The trick to remember is: the pictures are pretty much just regular computer files like word processor documents or similar -- you can rename them probably in a similar way that you do with other files.
Hope this helps!
Tom
Posted on Jan 14, 2009
LCD is blinking on and off and staying off.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link
Dec 09, 2013 | Sanyo Televison & Video
Tip
How to Rejuvinate Your Motorbike Leathers
So here's how to. Its actually real simple but can be time consuming if doing a colour change.
Can be used for your old faded set, ones you've had a slide in or even if your looking for a colour change.
[B]1.[/B] Go to any shoe repair shop that sells Leather spray dye's in lots of colors.
[B]2.[/B] Also you need the leather deglazer.
[B]3.[/B] Prep leathers, clean, dry and deglaze the area you want to color.
[B]4.[/B] Mask the area you want to color , this is what is time consuming. it gets real messy.
[B]Pic of lowside damage[/B]
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/1-5.jpg[/IMG]
[B]5.[/B] Apply dye roughly 4 or 5 coats (if changing colours, less if just touching up). This takes awhile cuz it take long to dry inbetween coats and work on one area at a time.
[B]Pic of Repair (still fresh)[/B]
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/2-4.jpg[/IMG]
[B]6.[/B] When all finished let the Leathers sit to fully dry and cure for 4 days to a week if possible.
[B]And now for the all important pics.
This is what the suit looked like before
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/3-3.jpg[/IMG]
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/4-4.jpg[/IMG]
[B]And after the new colour scheme:[/B]
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/5-5.jpg[/IMG]
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/8-1.jpg[/IMG]
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/7-2.jpg[/IMG]
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/6-2.jpg[/IMG]
[B]Some close ups:[/B]
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/9-1.jpg[/IMG]
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/13-1.jpg[/IMG]
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/12-1.jpg[/IMG]
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/11-2.jpg[/IMG]
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/10-1.jpg[/IMG]
[IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/15-1.jpg[/IMG]
on Apr 27, 2010 | Motorcycles
Need to download videos to computer. Help?
Couple ways to do this:
1. Camcorder should have come with a cable to connect to computer. If you connect it Windows should prompt for import.
If not go into folder where videos are store on camera, select the videos, copy/paste them into folder on computer.
2. If your computer has an sdhc card slot on it remove the card from camcorder and put it into computer. Again Windows should prompt for import, or you can copy videos manually.
There's also plenty of other software designed for importing and managing photos/videos, that may be a good option.
If you are unsure, having someone help you through the process in person may be good.
Sep 04, 2013 | Canon HFR400 Camcorder -
Downloading photos from Sony DSC-P100 to computer running Windows 7
Please check below for information about the compatibility of your Sony DSCP100 camera.
Windows 7
* Drivers:
The drivers needed to connect your Sony camera to a computer and transfer files are already included in the operating system.
Not Supported: The Windows 7 Starter edition is not supported.
Check here how to transfer video clips to a computer running a Windows operating system:
1. Turn on the computer.
2. While the camera power is off, connect it to the computer using the supplied USB cable.
3. Make sure the camera is using a fully charged battery pack or connected to an optional AC power adapter and that it is plugged into a working electrical outlet.
NOTE: Avoid using a battery pack with little remaining charge because transferring may fail or image data might be corrupted if the battery pack shuts down too soon.
4. Make sure media with the recorded video is inserted in the camera.
5. Turn on the camera.
NOTES:
On the LCD screen, a USB indicator will display during and after the communication session.
If this is the first time the camera has been connected to the computer, the computer should automatically install the appropriate USB driver at this time.
6. Transfer the pictures or videos to the computer using one of the following methods:
6.1 Use the Import pictures and videos option.
In the AutoPlay window, click Import Pictures and videos using Windows .
In the Import Pictures and Videos window, click Import Settings .
In the Import Settings window, click the Browse button.
Click to select the location on the computer where you want to copy the movie files (for example My Videos ).
Click the OK button.
In the Import Pictures and Videos dialog box, click the OK button.
Click the Import button.
6.2 Use Picture Motion Browser (PMB) software
Using PMB version 4.3 or older
Using PMB version 5.0 or later
Copy and paste the video files from the Removable Disk window that represents the camera.
a. Open the My Computer or Computer window on the computer.
b. In the My Computer or Computer window, double-click the icon that represents the camera.
c. Click to select the appropriate camera folder that contains the video or picture files you want to transfer.
c.1 The DCIM folder (if available) contains still picture .JPG, or .ARW files and .AVI video files.
c.2 The MP_ROOT folder (if available) contains standard and high-definition .MP4 video files.
c.3 The AVCHD folder (if available) contains high-definition .MTS video files.
NOTE: Depending on your camera and the type of footage recorded, not all the files or folders above may be displayed.
On the computer keyboard, press CTRL+C to copy the camera folder and its contents.
Browse to the location on the computer where you want to copy the picture or video files, such as the My Pictures or My Videos folder.
Press CTRL+V to paste the camera folder and its contents into the computer folder you selected in the above step.
NOTES:
* Movie player software must support the MPEG-4 format to playback standard or high definition .MP4 recordings.
* Movie player software must support the MPEG-4 AVC/H.264 format to playback high-definition .MTS recordings.
* Refer to the developer of your movie player software for information about file format compatibility.
* For the video to be viewable in the PMB software, the folder where the videos or pictures were saved must first be registered in the software. Information about how to register folders is available in the PMB Guide in the Help section of the software.
Hope this helps (remember to rating this answer and leave a testimonial comments).
Oct 11, 2011 | Sony Cyber-Shot DSC-P100 Digital Camera
Jumpy Video in Flip Video Ultra HD
If you recorded a few video clips with the Flip Mino or Flip Ultra , and when you tried to import the video files from flip video camcorder to into iMovie ‘08, only to find out that you couldn’t. Apparently, you’re not alone, because you’ll find there are plenty of other people with the same problem.
Some Flip video camcorder will record video in mp4, but some in mpeg-4 formatted AVI files, the problem is iMovie won’t recognize AVI, you will need to convert AVI to DV Stream before import into iMovie.
Fortunately, there is a simple yet effective way to work this out, check it out: Flip video converter for Mac [/url] is a program specially designed to make Flip Mino and Flip Ultra work well with iMovie, iTunes and QuickTime. It can convert flip video to DV, m4v for iMovie, and convert flip video to QuickTime. mov for QiuickTime. Mac Flip video converter is Mac friendly program, which is compatible with PowerPC and Intel Processor. You can count on it.
How to use Mac Flip Video Converter
Step by step to import flip video to iMovie files on Mac OS X.
Step 1 Download and install flip video converter for Mac
Flip video converter for Mac released its latest version 3.3.8 recently, and there are two folders included in the program, one is for Intel Processor, the other is for PowerPC, please choose wisely.
[img][/img]
Step 2 Import flip video to flip video converter
You will need to convert flip video files to DV or M4v that to be importable by iMovie.
If you have many video clips and want to load them at one time, just go ahead, the batch mode will let you do without any problem.
[img]http://www.iorgsoft.com/how-to-import/Flip-Mino-Flip-Ultra-video-file-video-file-to-iMovie/import.jpg[/img]
Step 3 Select the output format and output path for the video need to convert
In your case, you can select .DV as the output format. On the bottom of the panel, select .dv in the drop down list menu next to Profile…
Select a location in the drop down menu next to Destination.
Click Open…button will let you directly locate where the output file is stored.
Step 4 Convert flip video to iMovie compatible format
Hit Convert…button, this will instruct the program to convert the list of flip video immediately
Please wait patiently till the progress bar says conversion done.
[img]http://www.iorgsoft.com/how-to-import/Flip-Mino-Flip-Ultra-video-file-video-file-to-iMovie/conversion.jpg[/img]
Step 5. Now open up iMovie ‘08, and go to File > Import Movies, browse for them, and import to your heart’s content. That’s it!
[img]http://www.iorgsoft.com/how-to-import/Flip-Mino-Flip-Ultra-video-file-video-file-to-iMovie/import-to-imoive.jpg[/img]
Jul 18, 2009 | Pure Digital Flip Video Ultra Camcorder
We have some videos we want to transfer to the computer. We are running Mac OSX with the Leopard software. When I attach the camera, I see the point and shoot icon for a short time and then I hear a beep...
Put the batteries in the camera, then connect via the USB flip connection. The camera will show up on the desktop like a flash drive does. Open it when it shows up. Drill until you find the avi movies and drag them to your desktop. You may have to convert them to quicktime files. If you cannot use the software that came with the camera (it does work), you can import the sections into iMovie.
Jul 14, 2009 | Pure Digital Flip Video Ultra Camcorder
Snugli Problem
none of ur pics work.. maybe upload some more and ill try to help!
Jun 25, 2009 | Evenflo Snugli Front & Back Baby Carrier
Importing Error
The problem is probably the same one i had. After successfully importing videos and pictures from my SD card, Windows 7 started giving me that error. I discovered that it was caused by the fact that I had imported some directly to an external USB hard drive (E:) and had set the default import directory to it (I can't remember if I had done this dileberately, or if W7 remembered it).
Fix: Just before you start the import, click the more options link at the bottom, and change your default folder to the local drive or to an attached external drive, something that exists at the time.
Worked like a charm after that!
Bill
Singer/Songwriter
www.billandkateisles.com
Jun 07, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
Can't import video into Windows Movie Maker
Windows Movie Maker is a basic video editing and creating software developed by Microsoft. It contains features such as effects, transitions, titles/credits, audio track, timeline narration, and Auto Movie. The accepted formats for import by Windows Movie Maker are WMV, .AVI, MPG, .ASF, .WMA, .WAV, and MP3.
Puzzled about how to import DVD to Windows Movie Maker for further editing? iOrgSoft DVD Ripper can do that job. Not only rip DVD to Windows Movie Maker acceptable videos including AVI, WMV, MPEG-1, MPEG-2, ASF, but also convert DVD to MPEG-4, MOV, AVC (H.264), MOV, 3GP, FLV, SWF.
Tutorial: How to Rip DVD to Windows Movie Maker, import DVD to Windows Movie Maker?
Step1: Locate your favorite DVD to the program-DVD to Windows Movie Maker.
Step 2: Specify output video format compatible for Windows Movie Maker, like AVI.
Step 3: Click “start” button to start the process of ripping DVD movies to .AVI video.
[img]http://www.mp4kits.com/Guides/WMM/dvd-to-windows-movie-maker/importdvdtowmm/convertdvdtoavi.jpg[/img]
Aug 28, 2008 | Lite On Computers & Internet
Canon PowerShot SX20 IS Digital Camera Logo
41 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
