Question about Kenmore HE2 Plus Front Load Washer
Leaking on bottom near the weight
Replaced the pump, front gasket twice, repair man has been here 4-5 times. Still leaking underneath feels like its coming from a small groove in the concrete weight.
  • 11 Answers
SOURCE: Water leaking from bottom of door during wash cycle
I had a similar problem.  It turned out to be the overflow "sock".  It's a long plastic bag that hangs from the side of the tub.  You have to get the top open, and it will be on the left side.  Where it attaches to the tub, the plastic attachment has a rubber washer that gets flattened out after time allowing the attachment to get loose and leak.  Since I couldn't find the washer to replace it, I cut a piece of gasket material like you get from an auto parts place and placed it behind the foam washer.  This made the connection tight, and the leak stopped, thank God.
Posted on Oct 23, 2007
SOURCE: HE4t kenmore washer rubber drum gasket not attatched.
Removed the top and Front reinstalled the counter balance. the rubber gasket has a 1" tear in it which I patched with a rubber tire patch for now. Two of the locking nuts for the leveling of the machine were loose it went out of level causing the machine to rock and probably caused the counter balance to loosen up. My daughters come in from collage and over load it on weekends which adds to the machines demise. All have been warned.
Posted on Jan 19, 2009
aborcass
  • 2651 Answers
SOURCE: my kenmore elite front loader leaks
well you can remove teh boootm acess panel by removingthe 3 screws that run along the bootm of the unit . afete rthat you can set a cycle to wash ans see where the leak is coming from
Posted on Jan 28, 2009
mgprice
  • 744 Answers
SOURCE: can't remove front bottom panel to get to pump
Hello, lean the washer back, place something underneath it to hold it back( place 2 2x4 blocks either side), remove 3 screws with star driver...remove panel. You will see the drain filter right beside the pump. Good Luck! Mike
Posted on Sep 22, 2009
blueextc3221
  • 15935 Answers
SOURCE: leaking kenmore from bottom
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Why is coolant leaking from underneath the center of my cadillac deville 1997? I've replaced everything that has to do with the coolant. There is no water nor fog on the passenger side floor
Well, if the coolant is leakimg from the HVAC drain, then you need a heater core, no matter what. You really have to jack it up and look, but I can give you a couple of pointers......
1. The water pump is leaking. That happens a lot. The coolant is leaking near the front of the car, near the center, but ever so slightly towards the drivers side. You need a special tool to replace it and I think gm has an updated cover and gasket.
2. The water pump housing is leaking. The gaskets that seal it to the block are made of plastic and deteriorate often. The coolant will be leaking at the center of the car, maybe up by the water pump, or back between the engine and transmission.
3. The heater hoses. I have only seen this 2 time, but the metal pipes corrode along the fire wall.
4. You could need a radiator. I have seen the side tanks leak a few times.....
Just A couple of places to look, but you have to get under and look....
Nov 07, 2014 | 1997 Cadillac DeVille
Have a 94 Buick century. Replaced thermostate. Running hot. Looks as tho is leaking underneath front near pump. And also in passenger floor board can't see the leak from inside. It's just alwa
Whenever I see a system which is leaking from more than one or two places, I do a head gasket check because that tells me that the system is experiencing above normal pressures. the wet floor is a heater core. whether it's a water pump or some other thing near it only you can tell. Actually it rarely happens, but the wet floor could be the hose where it meets the heater core at the firewall; again, only you will be able to tell the difference. if the hose connection looks dry, assume that it is the core itself.
Mar 03, 2013 | 1994 Buick Century
Dishwasher leaks
Hello - Since you have previously replaced the bottom gasket and issue continues I suggest contacting a professional to move forward accurately. The leak could possibly be coming from the drain motor/pump or a loose hose connection located underneath.
Oct 03, 2012 | Frigidaire Professional Series 24 in....
TOILET IS LEAKING
Been there, done that. Does it leak all the time? Does it leak only when you flush? Please clarify this. If the gasket is off centered, it will leak there. The bolts could be leaking, got food coloring to use as a dye? You can do this while watching the bottom of the tank, as you flush. Hairline cracks in the porcelain can be seen, get out yur magnifier and look underneath the tank, as you flush.
Apr 15, 2012 | Home
WATER IS LEAKING FROM THE BOTTOM. IT'S COMING FROM FROM THE PUMP.
This is repaired by pulling the unit out and working from the rear and underneath, check for the leak, either replace the pump or gasket or hose, depending on where the leak is coming from. You may need some star screwdriver type tool.
Mar 24, 2010 | Maytag MDB7100AWB Dishwasher
Wife,s 97 buick skylark, 2.4 L., leaking water. need help!!!
I had the same problem a month ago. I thought it was the thermostat, which sits inside the lower water feed tube that runs from the radiator, under the car and up between the engine and trans axle to the thermostat housing and water-inlet housing attached to the water pump. I replaced it and it kept leaking. So I got under the car with a mirror and a light and found that it was leaking from a weep hole in the water pump. This happens when the water pump seal is bad. to replace the water pump you nearly have to take apart the back of the engine and the timing chain cover. The waterpump is mounted at the bottom of the back of the engine and is turned by the timimng chain. It took me two days to fix, and it was not easy. There are a couple of sites that have info, which helped me. It's about a $600 - $900 job if you take it to a repair shop.
Mar 31, 2009 | 1997 Buick Skylark
Leaking water from front of door
I replaced the seal part # 154576501. The notch is on the right facing the dishwasher. Just pull it out and insert the new one.
I've fought this problem for over a year, thinking it was an adjustment. I am now running it through the third cycle and I am positive it fixed my leak. Also, while you have the cover off, check and trim the tie-wrap around the wire loom. Mine was interfereing with the seal, but the seal was also slightly distorted allowing the splash to come underneath.
BnoGno
Nov 16, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Westinghouse 906 leaks from front door
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Oct 05, 2008 | Westinghouse 24 in. MDP531 RF...
Kenmore HE2 Plus Front Load Washer Logo
13 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
