Question about Toys
Freightliner fault code 128 032 5 SID - Toys
3 Suggested Answers
SOURCE: I have a (columbia freightliner 2005) I need to
ill look them up
Posted on Jul 06, 2014
  • 45468 Answers
SOURCE: 2012 freightliner cascadia DD15 fault code ECU 1... prior to the fault code the engine bogged down really bad and solid yellow and check engine light come on.
an answer from just answers reports this
ecu 1 fault means the engine ECM has an internal fault and needs to be replaced
most of the time with this code it is not the ECM itself but usually a wiring problem going to the ECm
there should be 2 fuses for the ECM either next to the ecm in plastic covers by a starter or in a plastic box
check all wiring going to and from the engine and battery grounds
especially the grounds
check for wires rubbed through and loose terminals
take it to a service dealer for a proper diagnosis as it costs money wasting time trying to find the fault yourself as a truck standing still is not earning it's keep
Posted on Jun 05, 2016
Abs light is on all the time sometimes I get a code
Abs sensor will need replacing, cleaning them won't help, you need a code reader to see which one needs replacing then you need the code reader to delete the fault code
Feb 11, 2015 | Freightliner Columbia & Century Class 120...
We have a 2009 Freightliner Columbia that keeps giving fault code "ecu 128 51d 153". Any ideas on what this is?
not in my range of expertise as commercial vehicle but there should also be a FMI code number to go with the fault code , follow link to the freightliner web site where you can download owner manuals etc that may give you more info on your problem also a freightliner forum would be a good source of info , keep me posted if you wish
Driver Operator and Maintenance Manuals
Jun 08, 2014 | Cars & Trucks
What is a bh164 fault code on an M2 freightliner?
2006 freightliner m2 code bh 164 don't star engine I don't now why !!!
Oct 10, 2011 | Cars & Trucks
Active faults 1 at startup screen
if you press and hold the mode button it should beep then you will get the component location. ecu 128 for example is in the engine- mid 136 is the abs. once you see that, press the mode button again and you will get the code. sid 123 for example- press mode button again and you will get the failure code. FL 02, could indicate when it is reading a high or low reading, short or open... etc. once you have the three parts of this code then you should be able to contact your local dealer to find out what the code means. Truck diagnostics are not always easy... active codes really just give technicians a place to start... hope this helps
Dec 16, 2009 | RTO Ho Herpa Freightliner Truck Tractor
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
