Question about Exercise & Fitness
Baldor motor from a Spirit ST200 Programable gets hot..starts to smell after 25 min use
2 Suggested Answers
  • 33 Answers
SOURCE: Belt won't turn.
HI, please replace the control board
Posted on Oct 02, 2009
I have vw passat v6 2002 it started smelling hot when I drive for more than 5-10 min. Even seen steam or smoke only small amount once. There is some oil or something leaking too. But no fluid change
when it smells hot and there is vapor to be seen , it is boiling and over heating
take it to an accredited VW specialist shop and have it repaired as the next cost is another motor
Feb 12, 2016 | Cars & Trucks
Baldor motor wiring diagrams
The diagram is almost always either on a label on the side of the motor or on a label inside the little connection hatch.
Jul 26, 2014 | Baldor 7.5hp 3450RPM 213T Frame ODP...
Spirit treadmill st200
That machine is way too old to put any money into it. The fix for that particular problem is to replace the deck and belt.
Oct 21, 2017 | Exercise & Fitness
Motor gets Hot
I'm not familiar with the treadmill specifically, but here is some general information that might be helpful. When a motor is under heavier load, it draws more current and therefore gets hotter. If for example, you were able to stop the motor shaft from rotating with an extreme load, it would draw what is called STALL CURRENT which is very high. So the problem seems to be that the load is out of specification. I'm assuming it would probably get hot if it was running with nobody on it as well. That would mean that the drive mechanism driven by the motor is not moving freely. If you can somehow decouple the motor from the treadmill drive system so that it has no load, and then move the mechanism by hand to see if it feels like there is a lot of resistance in the belts, pulleys or whatever drives the treadmill, then you need to lubricate to make it move smoothly. Or if you cannot decouple the motor, just look for all the bearings and pulleys and lubricate those but be careful not to get oil on drive belts or surfaces that require friction such as the surface of the belts or treadmill band. Don't ignore that the motor could get hot enough to start a fire so it is important to resolve this. It is possible that there are shorted windings and the motor is no longer good. If you can decouple the motor and run it no load, and it still gets hot, that would be an indication of such a shorted winding problem. Hope this is a little helpful. G
Feb 07, 2014 | Spirit Esprit ET4 Treadmill
I need a multi 110/230 volt wiring diagram for a baldor non reversible motor
http://www.baldor.com/support/literature_load.asp?ManNumber=MN1240
You didn't give a model,here's a manual on their motors and the wiring diagrams,they start on page 2-9.It should get you there,or you can check out their other manuals on the same page .Take care!
Jan 13, 2010 | Target Portable Masonry Saw PS1411S...
Smells hot. does not dry. sticks on 20 min all cycles
just a quick suggestion
check your exhaust outside for proper airflow
Oct 11, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Belt won't turn.
Sep 29, 2009 | Spirit Esprit ET4 Treadmill
Bad smell from ac unit in my house
does it smell like literally , dirty socks?if so it is dirty sock syndrome, a plague of heat pumps for years. if it smells like an electrical melting or burning of wires then time to call a pro.it could be a weak capacitor or a weak fan motor. if it is dirty sock syndrome then its the microbes that thrive when temps are middle temps and reproduce when temps are hot and cold in intermittent days. hot one day and cold the next equals call for cool then call for heat and hot steam from heated coils cause s bacteria to grow and microbes to spread across coil. when you switch back it causes the smell.if the coil is clean you can spend a chunk of money on sanitizers but best bet is to run it cool for hot weather and hot for cool weather. the transitional periods are what create the smell. avoid semi cool and semi hot periods. this condition is common to acs from all brands . lots of stuff on the internet about dirty sock syndrome
Oct 31, 2008 | Sharp CV-P09FX Air Conditioner
Exercise & Fitness Logo
18 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
