Question about BAFX Products Camping, Backpacking & Hiking
I pulled the poles apart hoe to fix them - BAFX Products Camping, Backpacking & Hiking
2 Suggested Answers
  • 10865 Answers
SOURCE: i have a remington electric pole saw apart and do
hello red. here is a schematic of the polesaw showing how the parts fit together
http://www.searspartsdirect.com/partsdirect/part-model/Remington-Parts/Chainsaw-Parts/Model-RM0818B/1317/1503210/1010076P/00001?blt=06&prst=&shdMod=
Joe
Posted on Jun 24, 2011
How to remove extension on pole chain saw
im gonna assume this is one of them pole saws that lets you get the bottom limbs without a ladder , next im gonna assume (and have too since you didnt mention a mfg or model) that you would like to colapse the shaft back down to a more manageable length , also im gonna assume theres no visiable dammage to shaft ,wrinkes in metal or broken clips , locate the joints in shaft with your eyes , this should be obvious , see if theres a small button or clamp visable near this , press in on button or clip and pull firmly shafts apart it should seperate and come apart , carefull not to smear grease all over your clothes in the process , install any covers or caps that come with it (most do) so that dust and grime doesnt get into joint
Feb 26, 2015 | Garden
How do i pull the poles apart?
If you have a bath, I suggest that you run a couple of inches of hot soapy water and leave them to soak for half an hour.When you take them out twist and pull the tubes at the same time.
If they still do not come apart hold at 45% to the floor and tap one end lightly on the floor (not so hard that you damage anything) turn a little after each tap, then try again to twist an pull them apart.
When you do part them clean the joint where the tubes touch and then rub will a little cooking oil on a piece of kitchen roll, makes them easier to part next time.
Jul 24, 2014 | Numatic Vacuums
Electric pole saw was put togeather wrong and can't take pole apart.
check for a small button in the connecting parts of the pole press it in and slip the parts
on reassembly make sure that that button lines up with a hole and clicks in
Sep 16, 2012 | Earthwise 10" Cordless Lithium Pole Saw
How do I put the saw on the pole
1. Remove battery from chain saw.
2. Separate main handle from chain saw
power head by pressing both release
buttons on main handle and pulling
apart. The release buttons are just in
front of the trigger.
3. Align rib on chain saw power head with
groove in power head adapter on pole.
4. Slide power head into power head
adapter until units "snap" together.
IMPORTANT: Both release
buttons on power head adapter must be
fully engaged.
5. Align rib on handle adapter on pole
with groove in main handle.
6. Slide main handle into handle adapter
IMPORTANT: Both release buttons
on main handle must be fully
engaged.
7. Slide battery onto main handle until
release buttons "snap" together.
Be sure the battery is charged.
To extend the pole:
1. Loosen the clamping
lever. Pole will slide
freely.
2. Pull inner pole section out to desired
length of extension.
3. To lock pole in position, tighten clamping
lever.
Sep 12, 2011 | Remington Cordless 18-Volt 8-Inch Cordless...
Got the basketball poles stuck together and theyre not aligned
Dropping the stuck poles definitely WORKS! We had stuck basketball poles from a Spaulding 54 inch together wrongly. Dropped them on grass from shoulder height 4 times and they loosened enough to pull apart.
May 01, 2011 | Lifetime 3819 Impact 44" Basketball...
Lifetime Portable Basketball System- The pole are stuck.
Deddy456 was spot-on with dropping the poles from waist level. Worked for our Spalding that looked hopeless. Thanks!
Jul 04, 2010 | Lifetime 3819 Impact 44" Basketball...
HooverSpin Scrub and the brushes always stop spinning.
Greetings from GoVacuum,
The Hoover SteamVac's are notorious for this exact problem. There are several things that can be causing this probelm.
First, what you'll need to do is take the brush block out of the machine. To do this there are 4 clips on the brush block. You will need to turn the machine upside down, and pull down on the brush block to where it won't pull out any farther. There are 4 clips, 2 on top, and 2 on the rear of the brushes. (See picture I have circled one of the clips in red). Simply press these clips at the same time, and pull the brush block out of the machine. I'd say that 60% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. If the cleaning still fails to fix the problem, take the brushes back out of the machine.
One you have the brushes out of the machine, the first thing you should look at the brush stem that goes into the turbine inside the machine. This is the green pole pictured in middle of the brush block. Examine this pole to determine if the top of it has broken off. It should exactly how the picture shows it. Make sure that the plastic has not broken.
If the pole has broken, you will simply need to replace the brush block. If the pole is not damaged, the next thing to try is to turn the machine on while you have the brushes out. Look inside the machine, where the pole goes into the turbine (also important, make sure the switch for the brushes is turned to "Rotating Brush Speed Hi), this female receptacle should spin when the machine is turned on. It is important the try this when the foot pedal is released, and the handle down, and not in the upright position, as there is an internal switch that shuts the brushes off when the machine is in the upright position.
If you notice that the female receptacle where the brush pole is inserted is spinning, then your turbine is fine. If this part is not spinning, then most likely you will need to replace your turbine.
I hope this helps you with your problem. If not, please feel free to request a repair clarification and I'd be happy to walk you through the diagnosing. I also can provide you with a blown up parts schematic to your machine, please just get the model number off the back of the machine and provide, and provide me with the full model number. I would be happy to provide any technical support you need, just request a clarification on the repair.
Chris Jones
Mar 07, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Camping, Backpacking & Hiking Logo
82 people viewed this question
Top BAFX Products Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a BAFX Products Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
