Question about Symbol Computers & Internet
Symbol ap-5110 amber flashing light
2 Suggested Answers
  • 52 Answers
SOURCE: Does the Symbol AP 3021 Access Point accept WPA encryption?
on the info i could find it only supports WEP.
but if your issue is to be more secure look up if it supports a sort of mac filter.
this will only keep everybody out of your router but your signal will only be WEP encrypted.
Posted on Feb 09, 2009
Aironet 1100 ap amber led light
What controller are you using? You are correct - it is an IOS error. Usually the AP is not compatible with the WLC ios.
Mar 16, 2013 | Aironet 1100 802.11a/b/g AP...
Mointor dell flat screen
flashing amber normally just means it has gone into standby because it's not getting a valid signal, when you bought the other monitor did you use a different vga/dvi cable when you plugged it in? are both inputs the same? for more information on the padlock please read this page http://www.paulstravelpictures.com/Dell-LCD-Monitor-Flashing-Padlock-Icon/index.htm
Apr 29, 2012 | Computers & Internet
I have a motorola AP-300 which keeps on blinking amber light when i turn it on. how can i reset it or what's wrong with the AP?
From the installation guide for this AP, I find the following:
LED Indicators
The unit has LED activity indicators on the front of the case provide a status display indicating error conditions, transmission, and network activity for the 802.11a (amber) radio or the 802.11b/g (green) radio.
802.11a Activity LED Amber
The amber LED flashes three times per second until firmware is loaded. During boot, 802.11a mobiles cannot associate. After adoption, the amber LED is steady or flashes with 802.11a radio traffic.
The amber LED flashes once per second if an error prevents the 802.11a radio from operating normally.
802.11b/g Activity LED Green
The green LED flashes three times per second until firmware is loaded. During boot, 802.11b/g mobiles cannot associate. After adoption, the green LED is steady or flashes with 802.11b/g radio traffic.
The green LED flashes once per second if an error prevents the 802.11b/g radio from operating normally.
From this, it appears that the 802.11A radio is malfunctioning.
Here is the Motorola support web page for this device.
Dec 30, 2010 | Motorola AP300:802.11A/G, Internal Antenna...
Triangle symbol on our printer with a AMBER LIGHT FLASHING?
There is an issue with the media/paper. First thing is to make sure there is paper, and if so, that it's touching the intake rollers. Next is to check for jams, which are usually under the imaging drum. Open the front lid and remove the drum (it's in the front; follow the directions shown on the label on the front right.) Also, check for jams where the paper exits the printer.
Final two things. The lid could be ajar - simply push down firmly to ensure all the contact switches are closed. The last thing is an issue with the fuser, which may require replacing it. I highly recommend getting the service manual from HP, as it is easy to follow and has extensive troubleshooting.
Jul 01, 2009 | HP LaserJet 2550n Printer
FLASHING AMBER UNDER LIGHTNING SYMBOL
Is it an amber lightning bolt? (I am assuming thats what you mean by UNDER lightning symbol)
That is the charging symbol for your battery, it means your battery is being charged by your power adapter.
Jan 29, 2009 | Compaq Presario X1000 Notebook
I have 2 comtrend dh-10pf powerline adapters. one of the adapters status is a red flashing light and the AP light and the Ethernet light are blank. the second powerline adapter has a solid red status...
To start you need to factory reset both adapters,
plug them both into a wall socket next to each other, press the config/f reset button, hold in until ap light goes off, repeat on the other one.
Now you should have a red status light on both.
Press the config/f reset button on one for about 5 seconds, wait until ap light stays on, this one is now your access point (ap) that should be plugged in to your router when you have finished config.
Now press the ap adapter config button again for about 5 seconds until ap light flashes, then press the config button on the other adapter until ap light flashes, wait until they both stop flashing, wait a few seconds, the status light on both adapters should be green, and one adapter should have an amber ap light.
Hope this helps.
Jan 28, 2009 | Computers & Internet
Warning light
IT SOUNDS LIKE YOU'RE REFERRING TO THE TROUBLE SYMBOL FOR HEADLIGHT/TAIL LIGHTS. THE PROBLEM CAN BE WITH A BULB, FUSE, ELECTRICAL CONNECTION. CHECK YOUR USER'S MANUAL UNDER HEADLIGHTS.
Jul 08, 2008 | 2003 Audi TT
Reset to default a symbol spectrum24 ap-3021
On the Symbol Spectrum24 AP-3021 and what looks like all of the Spectrum24 AP models. There is not a reset button. We only have the RS-232 serial port to work with.
Start with the power off.
Short pin 2 and pin 3 together.
Plug in the power.
Wait 15 secs.
After the two network lights become solid.
Remove whatever you used to short pins 2 and 3.
(make sure to only jumper pins 2 and 3 - if you ground against the outer shield it will not work)
Cycle the power on the unit.
The password is Symbol and it is case sensitive.
Apr 09, 2008 | Symbol Spectrum24 4131 Access Point...
Computers & Internet Logo
42 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
