Question about Xerox WorkCentre 3220 All-In-One Laser Printer
Workcentre 3220 random garbage printing
Gibberish printing
HOW TO RETRIEVE ITEMS IN MEMORY IN XEROX 3210/3220 WORKCENTRE FAX ?
dear Is there any error or masage disply on the screen. Pl. revert back.
Thanks.
Dec 18, 2014 | Xerox WorkCentre 3210/3220 Multifunction...
PCL6 ERROR - Imcomplete Session by time out
Update your firmware, follow the steps included in the zip available at www.xerox.com. Or switch to the PS driver which most xerox's prefer. Also if its a .pdf file. Click advanced and choose, print as image.
Mar 04, 2014 | Xerox WorkCentre 3220
Kyocera prints garbage
driver issue. download latest driver and update printer firmware
Feb 09, 2013 | Kyocera FS-920 Laser Printer
I get lines when using the auto feeder.
Only clean the **** glass through which passes the document, there must be a pointthat by passing the paper becomes a line
Apr 30, 2012 | Xerox WorkCentre 3220 All-In-One Laser...
I get "Send Error (SMTP)"
It took me a while to figure this out. Your 3220 must be connected to ethernet (I havent tried it with the 3220 connected directly to the computer). Also, this works with a free email with domain Godaddy account, so YMMV.
1. Open your web browser and navigate to the 3220's CentreWare IS. 2. Click on "Protocol/SMTP Server" 3. Check "Host Name" 4. Type smtpout.secureserver.net/80 for server/port 5. Check "SMTP requires authentication" 6. Enter your username/pw 7. Click "Save Changes"
If you are asked for a username/pw to save the settings, the 3220's default are admin/1111.
Now click on "E-mail/E-mail Setup" on the navigation. Make sure your default [From:] address is your sender email address (they must match). Click "Save Changes"
As a final recommendation, I strongly suggest that you create your address book (E-mal/Local Address Book on the navigation) to make it easier to send by email, otherwise you will have to manually enter email addresses using the 3220's keypad (very slow!). Create groups for sending scans to several emails without having to select each individual email from the 3220's panel (also slow!).
Hope this helps.
Dec 31, 2010 | Xerox WorkCentre 3220 All-In-One Laser...
I have EnGenius EOC-3220 (EOC3220) i can not reset with my null serial cable please help me
Depending on the serial cable you have, you may need a modem (crossover) adapter between the cable and the EOC-3220. A good diagnostic is the following: with the EOC-3220 unplugged from power, connect your serial cable and make all the proper baud rate etc. settings in your serial communications program. When it is running, plug the EOC-3220 into power. If you don't see any garbage characters appear on your screen when you plug the power in, your comm program is probably not set up properly. If you see garbage characters but they are not immediately followed by good information from the EOC-3220, then you either need a null modem adapter inline, or you have a dead EOC-3220. If you've never communicated successfully with an EOC-3220 before over the serial channel, the only way to know if you have a dead one is to try again with a known-good one.
Aug 12, 2010 | EnGenius EOC-3220 (EOC3220)
Printing gibberish then feeding several lines, printing gibberish
If text did not line up as planned, your TOF ( top of forms adjustment ) isn't correct. Just correct it using the button on the panel. If after printing 1 page or so and then it begins to go out of place, most probably you hv set the page lenght incorrectly. To correct, enter the MENU on the panel and set the correct page length.
Lastly if printing garbage, most probably you have selected the wrong emulation on the MENU. Correct by entering MENU mode ( press ' SHIFT+MENU ' button together ) and select the correct emulation.
Hope this helps.
KM HOO
Mar 04, 2009 | OKI MICROLINE 590 Matrix Printer
Prints gibberish
You need to ensure you have the correct drivers for your computer. Adobe uses PostScript drivers to print out .pdf files. Some drivers are Printer Control Language (PCL) and do not work well with .pdf.
Dec 25, 2008 | Brother HL 2700CN Laser Printer
Xerox WorkCentre 3220 All-In-One Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
