Question about Research In Motion BlackBerry Z10 Unlocked Quad-band GSM Smartphone - Black
My blackberry switches on but a black screen apears with te word blackberry in the middle then stays like that does not boot up or go on completley
My blackberry z10 does not boot up and does not go on
Kyocera hydro black screen
i had the same problem when i turn my phone on the buttons lights come on but te screen stays black and the phone doesnt turn on. the lights stay on
Oct 30, 2012 | Boost Mobile Cell Phones
Have a blue streak down middle of screen. all
I have exact problem. Is anybody know how to fix it? tv is 4 years old
Jul 15, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
My 32 lcd tv a black rectangle apears on aprox,
If it is a large black rectangle that blots out the middle of the screen then you need to check your CC (closed caption) setting. Make sure the closed caption is turned off. I'm not up to date on the newer sets, but a lot of the older ones had more than one CC setting. One setting ran the captioning across the bottom, another put it in a big black box in the center of the screen. Most places didn't support the full text so all that showed was a big black rectangle on the screen. Since I'm not sure exactly what your rectangle looks like, this is my best estimate of your problem. Hope this helps.
Jan 01, 2010 | Polaroid Televison & Video
I Was In The Middle Of Texting Lastnight.Then My Phone Just Shut's Off...Ever Since Lastnight I Have Been Trying To Turn It Back On..The Black Screen Will Show.Then The White Screen Will Come On With The...
First charge your mobile for atleast 1 hour,and switch it ON you have to remove the battery when mobile is turned ON and wait for few seconds re insert the battery then check
If problem still exsists connect your blackberry to computer check wheather its recognising the device If "yes" you need to take a back up of your hands set and re-install the operating system of your Blackberry.
To perform a clean installation of the BlackBerry Device Software using Blackberry Desktop Manager 4.5 to 5.0, perform the following steps:- 1) Open BlackBerry Desktop Manager. 2) Click Help. 3) Select About Desktop Manager. 4) Click the Device Software tab. 5) Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider
I hope I was able to help you.
Nov 12, 2009 | AT&T Blackberry Curve 8300 Smartphone
Dell B130 laptop boots up and you can hear all the boot up sounds, however nothing shows on the monitor. It's completley black.
connect to a desktop monitor if u see the screen
change the output screen (tv,lcd) then unplug the monitor if the problem not solved
there is a problem on lcd ,lcd cable or vga adapter
Aug 09, 2009 | Computers & Internet
Gateway 2" monitor won't display
blown capacitors this can be fixed I can help or advise you how to do it but it will require soldering internal components.
Mar 04, 2009 | Gateway FPD2275W LCD Monitor
My Screen might be out??
dear ...,
when switching on te laptop, does it make noises, does the fan run, the CD/DVD-drive
LED shows green light and the harddisk rattle little bit? - good for you if it does, as the system still boots up !
to check if the LCD screen is broke and not the graphics card malfunctioning:
hook it up to an external monitor (one usually used with desktop PCs)
when laptop is switched off, using the 3-pin input in the back or to the right side of your laptop, and make sure the external monitor's power cord is properly fused...
Now switch on the external monitor first and then your machine again, and wait for the laptop boot messages on the monitor!
see anything? if yes the laptop screen is broke and needs to be replaced.
If still the external monitor stays black the onboard graphics card is up in smoke and you're in big trouble then.
Good luck finding out!
Oct 22, 2008 | Toshiba Satellite M55-S135 Notebook
Black Box?
my tv was working fine. somebody hit the menu button on the tv or the remote and i get the black box appearing in the middle of the screen. and also the pip is staying on my tv it keeps showing "a snowy picture of pip sjpwomg channels 2 through 18 i cannot figure out how to get this off of my screen.
Feb 08, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Research In Motion BlackBerry Z10 Unlocked Quad-band GSM Smartphone - Black Logo
12 people viewed this question
Top Research In Motion Cell Phones Experts
Jerry Greenberg
Jerry Greenberg
Mishan Kasiparsad
Computer Repairing
Computer Repairing
Are you a Research In Motion Cell Phone Expert? Answer questions, earn points and help others
