Dirt Devil Featherlite Bagless Vacuum M085845Vacuum
Problem for Dirt Devil Featherlite Bagless Vacuum M085845Vacuum
Suction when I vaccum the floor but not in the hose
By sesmith723 on Jun 07, 2009
I have tried all the 3 of the solutions postes and still can not get any suction in the hose.
Solution #1
posted on Jul 02, 2009
Not Rated)
galati2k
Rank: Wiz
Rating: 84%, 145 votes
remove the filter from the dirt cup and try again,if you have suction the the filter is clogged.the other is the intake hose that goes into the top of the base where the clear tube is.disconnect the hose from the base tube and take a coat hanger and bend the end into a hook.open the litte flapper door and stick the hanger down in the tube and see if you can pull out a clog of dirt.last but not least,disconnect the top hose completelyfrom the vacuum and see if you can blow through it.if you can't then the flex top hose is clogged.open the little flapper door on the top of the base and turn on the vacuum,if the intake hose isn't clogged then you should have suction.that will tell you that the broblem is in the flex hose or the filter
Was this helpful?
Yes
No
Popular Solutions for Dirt Devil Featherlite Bagless
Questions and Unsolved Problems for Dirt Devil Featherlite Bagless
Do you recommend Dirt Devil Featherlite Bagless Vacuum M085845Vacuum?
Answer
Answer
the main part of the vacuum is not sucking up the dirt..what do I do ..i don't have the manual and... (More)
Answer
it just stopped working. it is only about 1 year old, the filter is new. stopped the other day... (More)
Answer
My roller is clogged with hair and is difficult to move. How do I remove it to clean away the hair?
Answer
I have a bag less featherlite dirt devil vacuum I bought n 2008. Whenever I vacuum dust goes... (More)
Describe your Vacuums problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuum Experts
Top Vacuum Repairmen
in Surprise, AZ
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
