Question about Sewing Machines
How do you reassemble the bobbin holder?
The bobbin case as well as the part that holds the bobbin holder fell out. HELP me reassemble please...
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Posted on Jun 23, 2008
SOURCE: bobbin case on my 524fb necchi has come apart
Almost all Necchi use a class 15 bobbin & bobbin case, a new case should cost around 7 to 10 dollars!
Dwayne
Posted on Mar 14, 2009
jpack76645
  • 23 Answers
SOURCE: needle will not pick up the bobbin thread, gets
Oh boy! I've worked on industrial sewing machines for over 30 years, but the home sewing machines are like comparing cadillacs to mopeds. No offense, but if you want performance out of a machine try an industrial. It will shock you with the difference. Be glad to help you find the right one.
Anyway, the problem you are having is quite common. First, make sure it is threaded right especially the moving spring on the needle thread tension) and the needle is new. This generally covers 75% of the problem. Make sure the bobbin thread is threaded correctly.
If you are still having the problem remove the bobbin/bobbin case and observe the needle/hook point relationship as you turn the handwheel. The hook point should pass behind the needle at the scarf of the needle (indention just above eye of needle) If it is not so the needle bar may have moved up on you. Did the machine get jammed?
I'm not sure about the rod you're talking about but lets try this first.
Posted on May 18, 2009
  • 7 Answers
SOURCE: bobbin case is disassembled. how do I put it back together?
It should be in your manual.... but if you don't have one, I'm gonna try this out. I don't know the official names, so bear with me.
There should be two plastic arm-lookin things that are turnable. Make sure these are turned outwards.
You should have three silver pieces. The one you need first is a half-moon looking thing with a knob comin out of the middle. (it also has some holes in it)
If you turn the big knob on the right hand side, there should be a moving piece on the inside of the bobbin case.
The half moon needs to fit in with that piece. Don't force anything cause we don't want the machine to break. >< The knob thing needs to be facing the outside, otherwise it's not gonna go in at all.
Once you get the half-moon thing in there, you have two more left. There's a big circle. WOO! CIRCLES! ANYWHO, The big silvery circle.. it has a knotch in it, and a little pokey-outie thing comin' out of it.
It needs to be positioned so that the knotch (on the inside of the circle) is up and the pokey-outie piece (on the outer side of the circle) is on the bottom. On your machine, there should be a place where the pokey-outie piece would fit perfectly into a little hole-type-thing. Put it in. :O
Now it's time to move those little black plastic arms towards the center. On your circle, there should be little grooves that they fit right on top of. ^_^
The only silver piece left should be the actual bobbin case deal. This should be a smaller circle with a movable arm and a silver thing pokin' out of it. (I told you, I'm bad at names!) Before you put this guy in, we need to have your plastic bobbin threaded. (I'm assuming this has already been done, correct me if I'm wrong.... they also have pre-threaded bobbins for sale, but hey, whatever works.)
Your bobbin needs to fit inside this last piece. (my first bobbin didn't, and I freaked out and ran to my dad... LOL) You need to make sure there is a trail of thread coming out of your bobbin that's about two to three inches long. Place your bobbin in the silver guy and there /should/ be a little niche where you can play with the thread and pull it through the silver guy's parts. (Your thread may break, don't worry, just try again)
When you move the thread around, it should come out where the little arm that sticks out is. Keep the 2-3 inch trail goin' on, you'll need it. Remember that first half-moon silver guy? Well, we're gonna stick our little assembly onto his pokey-outie piece.
The silver arm-thing on our assembly needs to go into the knotch that's in our circle, and push in so it clicks. (Sometimes mine clicks twice...) Make sure you have that trail of thread, and go ahead and flip the white plastic up, because you're DONE assembling it.
I'm going to assume you have your top thread in already (again, correct me if I'm wrong..) make sure that your top thread is through the hole in the needle, otherwise we're thoroughly screwed. Pull that thread until you have another 2-3 inch tail, and twist the big white knob on the right side of your machine (same one as before...) TOWARDS you. KEEP HOLDING your top thread, otherwise it'll disappear into the abyss that is your bobbin assembly.
When you turn the knob towards you, your needle should dip down into the abyss and come back up- with your bottom thread! HUZZAH! it SHOULD be a loop around your top thread. (I'd use contrasting colors for practice.. so you know what it'll look like)
The manual says to "grab the bottom thread" but seriously, I can't get me fingers down in there, so I just slide some scissors under the foot and between the two sides of the loop, and just slide 'em left. usually works just fine. Unless my tail for the bottom thread is too short, cause then it'll be hard to grab. You should be good to go!
I know this is pic heavy and kind of long, but I like to provide as much info as possible! Let me know if it helped!!
Posted on Jul 31, 2009
  • 76 Answers
SOURCE: Top thread gets caught on crescent piece holding in bobbin case
If you have the manual take a better look at how to put the bobbin in the case,
sounds like you are putting it in wrong,
make sure you put the bobbin in with the thread com-ming off the bobbin in the right direction (left or right) if not put in the right way you will get what you are saying
ALSO: bring up the bobbin thread your self by turning the hand wheal and bring the thread a few inches to the back of the needle and hold when starting to sew the first 2-5 stitches.
when you do not hold the thread the machine will pull the thread in the bobbin area and cause problems.
you will get use to holding and it will get easier.
hope this helps
Posted on Sep 03, 2009
Need help reassembling bobbin area.
You didn't state what model you have, and that makes it tougher to help you.
I'm going to take a guess here that the part that fell out is a silver U shaped part located on the right near the bottom of the bobbin basket (holds the case). If that's the case, it's called a "cushion spring" and can just be reinserted by hand. It is part of the assembly that prevents the case from moving while the thread is unspooling from the bobbin during operation.
Oct 30, 2014 | Singer Sewing Machines
Singer 8280 (prelude) I had 2 threads coming out from my bobbin area, so I decided to open it up and take a look. I accidentally took out the whole bobbin shuttle. The manual doesn't tell me how to...
Ok, hang on! This can get tricky! Remove the bobbin. Remove the presser foot and the needle. Remove the throat plate. This gives you plenty of room to monkey with your bobbin case. NOW, lay the bobbin case in its correct area and gently rotate it until it falls into place. It may take several tries. Once you're satisfied that it's secure, snap the holding clips into place and it should all fit nicely. THEN place your bobbin in the case correctly...check the diagram in the manual. Depending on the machine, some bobbins have the threads coming off counterclockwise and others have them coming off clockwise, but your manual should show. Sometimes, there's even a diagram on the throat plate or the bobbin case as well.
Good luck. Hope this works. If this solves your problem, please come back and rate my answer!
Jun 07, 2011 | Singer 8280 Mechanical Sewing Machine
How do you load the bobbin properly?
Well you may please follow the steps below -
1. Remove the bobbin from the sewing machine. Note: whether you have a drop-in, front or side-loading bobbin on your sewing machine. A drop in bobbin will load from the top, may be via a removable bobbin case cover near the machine-fed dogs. A side or front loading bobbin needs to be loaded into a removable bobbin case under the machine.
2. Choose the right size bobbin for the sewing machine.
3. Wind thread onto your bobbin. Your sewing machine should have a standard thread spool to hold the thread and a short, squat post wide enough for a bobbin.
4. Put the thread and empty bobbin into position on your sewing machine. Wrap the thread around the bobbin to start it. On most machines, disengage the needle by turning the smaller hand-wheel on the machine toward you. Push the bobbin post into position, securing the bobbin into place. Press gently down. Thread should begin to wind neatly onto your bobbin.
5. Break the thread, push the bobbin post back into an inactive position and remove the bobbin. Tighten the hand-wheel. Thread your sewing machine again if necessary before loading the bobbin.
6. Remove the bobbin case cover and put the bobbin into position. The thread should slide through a catch on the bobbin case and up through the cover.
7. Access the bobbin case for a front or side mount bobbin. Lift the catch and remove the removable bobbin holder. Put the bobbin into the holder and run the thread through the holder, bringing it to the front. Lift the catch and slide the bobbin holder back into the case. Hold your needle thread gently forward with your left hand and turn the hand-wheel. The needle thread will pass down into the machine and catch a loop of the bobbin thread. Pull this loop up and slide both threads to the back before beginning to sew.
Good Luck!!
Thanks for using FixYa!!
Sep 22, 2010 | Euro-Pro Shark 60 - 384
Bobbin holder
Make sure the needle is in the highest position before you try putting the bobbin holder in. The bobbin holder has a metal 'finger' which fits into a 'slot' in the housing and it only goes in if you have the needle up.
Mar 31, 2009 | Brother LS-2125 Mechanical Sewing Machine
Singer cg-590 floating bobbin keeps jumping out of it's holder.
I'm not completely familiar with the model, but even a floating bobbin holder as you described should have some sort of a hold down. There may see a small swinging arm on the bottom right side of the bobbin area that needs to be located over the bobbin case to hold it in place. Let me know if this doesn't work.
Feb 20, 2009 | Brother CS-8072 Computerized Sewing...
Anna had this problem with her Pfaff 332 sewing machine, I do too
I believe that the bobbin case holder has become unlatched, for lack of better terminology. I have one of these machines, and my first experience with one was exactly as you are describing. A friends grandmother brought it to me because it kept breaking needles and wouldn't complete a stitch.Put the bed table in the lowered position, leaving the free arm exposed. Remove your needle, presser foot, and bobbin case, leaving the bobbin door open. Next remove the two screws that hold in the feed plate, and remove the feed plate. Looking down into the bobbin area, manually turn the bobbin case holder. There is a small slot in the top of the bobbin case holder, look for it as you turn. A small latch protruding from the bed plate is supposed to be clipped into that slot, and if the latch is still there, you likely will not be able to rotate the holder into place: This is good news, it means nothing is broken. Loosen the three screws (two silver on the top of the bed plate and one black in the area where the feed plate goes) which hold the bed plate in place, but do not remove them. You should be able to lift the bed enough to get the holder into place, and then set the bed back down and tighten the screws. Reassemble everything, throw in a new needle and see how it goes!
Jan 30, 2009 | Sewing Machines
Bobin casing
Look in the bobbin area to see where the screw fell out. Check your manual. Sometimes they have a good picture of the bobbin area.
May 05, 2008 | Necchi 3537 Mechanical Sewing Machine
Bobbin problem: Huskystar by Husqvarna Viking E10 sewing machine
This has happened to me, even though I have been sewing for 30 yrs. When I take the bobbin holder out I realise what I have done wrong. When placing a bobbin into the bobbin holder the thread must be running around the bobbin CLOCKWISE. If incorrect take bobbin out of holder turn it over, so now the thread will run clockwise.If bobbin placed in holder and thread runs anti-clockwise, when you tried to turn wheel to bring bobbin thread up, it will either not do it at all or will make a huge tangle of the threads. Happy Sewing
Nov 17, 2007 | Sewing Machines
HELP ASAP!
The bobbin case is in the wrong position to lock into the shuttle holder.Try instead of holding the the release lever of the bobbin case open, instead position the bobbin case finger to the up position and insert the bobbin case by pushing it in with your thumb. You should feel or hear it snap into position. You may have to rotate it slightly to get the finger in the proper position.
Nov 17, 2007 | Brother XL-5340 Mechanical Sewing Machine
Sewing Machines Logo
11 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
