Question about LG 32LE5300 Widescreen 32 in. HDTV
How to reset my LG 32 LE 5300
Almost lost all channels. Need help to reset my LG LE5300.
2 Suggested Answers
pjhislay1
  • 822 Answers
SOURCE: i need an instruction manual
http://www.lg.com/uk/support/product/support-product.jsp
try that..............
cheers
Posted on Mar 27, 2011
White screen error code V3.05.8 on lg LE5300 led tv
Do a hard reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jun 11, 2016 | LG Televison & Video
I m having a problem with lg led le5300 26'' it is not catching any signal it has stopped playing any channel i have tried auto tuning so many times but no channel found.
Make sure your cable/antennae connection is OK and you're getting signal from over there by connecting another (working) tv set to it.
Mar 28, 2015 | LG 26LE5300 26 in. LCD HDTV
LG 32LD490 lost hd channels
A software [firmware] update is necessary. Contact the the authorized service centre for LG. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts.
Mar 30, 2014 | LG 32LD490 32" LCD HD Ready TV 1920 x...
LG LE5300 TV will not turn on
Unplug it for about an hour to let it reset itself first, if it still does not owrk, then you need to start looking at the power supply module first to see if it has any blown fuse, bad caps with domed tops, etc.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 05, 2011 | LG 32LE5300 Widescreen 32 in. HDTV
WELL MY 32 INCH LG THE REMOTE LIGHT ON THE VT IS OUT CANT TURN CHANNELS OR ANYTHING FROM THE SIDE BUTTONS OR REMOTE PLEASE HELP
Have you unplugged the LG TV, waited about 2 minutes, and plugged back in to try and reset the TV?
After you reset the TV, try using the key pad on the TV first before you use the LG remote.
May 18, 2010 | LG 32LC7D Television
Help I cannot get any tv channels on mo lg 32 combo
What is your TV source? If you are looking for OTA (over the air) signals, you may need to modify your antenna setup. An external antenna rotated to the correct direction usually works best. See antennaweb.org and tvfool.com for details of what stations you may receive OTA. Antennaweb is much more conservative in the channel availability list than TVfool is. On both sites, enter your street adress for the details.
If you had a recent surge through your antenna, then you may have to repair/replace the TV tuner. (My household lost three CRT TVafter a nearby lightning strike.)
(Antennaweb.org lists only my area as only getting 2 channels with an external antenna (one transmitter source - 10 miles away). We actually get more - the other channels are transmitted from ~30 miles away.)
Jan 01, 2010 | LG 32LG40 32 in. LCD HDTV
Lost channels on TV
do an anolog and digital channel scan see if that helps also unplug from wall and plug back in to reset see if that helps
Mar 25, 2009 | RCA F32650 32" TV
Lost ITV channels and C4
I think you need to get Sky because it will give you 100% coverage of all terrestrial channels. You may need to retune the television otherwise just get sky
Dec 31, 2008 | LG 32LX1D 32 in. LCD Television
LG 32LE5300 Widescreen 32 in. HDTV Logo
61 people viewed this question
