Question about Panasonic TC-P50X5
Lost power tv wont turn on has happen before it take a day to turn back on why
My haier htr20 tv wont power up..tv is completely dead.
Check the main power regulator section circuit.
May 20, 2012 | Haier HTR20 20" TV
Tv wont turn on
Green light of death, capacitors have to be replaced but it probably wont fix it anyways. Once this happens the TV is completely useless.
Jul 21, 2010 | Mitsubishi WS-65809 65" Rear Projection...
No power
Good Day, jennylo04;
You need help??? I need help, too!!
Please help me by providing a MODEL NUMBER. OKAY??
Thank you, big IRISH,.
Aug 07, 2008 | Televison & Video
Olevia 42"
Olevia LCD 542I - Had the same issue for a week until the tv would not turn on anymore, after several attempts it came back on. A few days later the tv turned off then only the standby light was on, then lost the standby light as well. After researching the problem it could be in two areas, either the power supply or main board. Removed the back and found the power supply had several capacitors that were bulging on the top and appeared the fluid was leaking, all signs of a failed part, removed the PS and replaced four capacitorst that had shown some issues. If you can removed the PS and check for a number on the board, mine was FSP271-4F02, and find someone who has some electronic circuit capablilty, the issue may be resolved at a fraction on the cost of a new power supply.
Apr 13, 2008 | Olevia LT42HVi 42 in. LCD Television
My 50SBX70B flicks than lost the power
Symptom: NO HOR SYNC
Cause: DEFECTIVE I008
Symptom: No Horizontal Sync. When PinP is called up, main picture may lock up for a 8 moment, then it goes back out of sync.
Cause: I008 defective (Sync Switch)
Jan 15, 2008 | Hitachi 50SBX70B 50" Rear Projection...
Doesnt turn on
Good day.
Try to check for the fuse along the units power supply and loose connections.
chris
Nov 21, 2006 | Sharp 25K-M100 25" TV
Panasonic TC-P50X5 Logo
24 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
