Question about Conair WCR20 Clock Radio
Is this a one set alarm clock?
I am wondering if the wcr20 alarm clock is a one set alarm? do you set it once and it repeats daily until alarm is changed? or does the alarm have to be reset everytime it is used?
I have numerous times in last 2 days how do I get an answer?. Here goes again . How do I reset time on sony dream machine serial no.4841857
1 Plug in the ICF-C218 in a well-ventilated area free of moisture.
  • 2 Press "Clock" if you are not in the U.K. and need to set the time manually. Hold it for two seconds.
  • 3 Press the + and - buttons until the year is set correctly.
  • 4 Press "Clock" once you've set the year, and repeat this process for the day, hour and minute.
  • 5 Slide the "Alarm Mode" toggle to either "Radio" or "Buzzer," depending on your personal preference.
  • 6 Slide the "Alarm Time Set" toggle to either the + or - side until you've reached the time you want your alarm to go off at. Hold it down to adjust in 10-minute increments
  • Read more: http://www.ehow.com/how_7396985_instructions-sony-icf_c218-clock-radio.html#ixzz2jjJEJSA3
    Nov 05, 2013 | Home
    Cannot reset time on sony dream machine model no. Oct-c218
  • 1 Plug in the ICF-C218 in a well-ventilated area free of moisture.
    Nov 05, 2013 | Home
    I can't set the alarm on a Bush dabcr2004/a radio alarm clock
    If anyone still has one of these, and is struggling to set the alarm, try this:
    For setting the alarm
    Press the menu button. Press right arrow button 5 times until you get 'clock' then press select.
    You'll see 'set alarm,' press select button again to say yes.
    You'll see a display with all the current settings: Alarm 1, the current alarm time and whether it's set for Daily or Once. Pressing the right arrow now advances the hours, the select button moves you on to the minutes, set these with the arrow buttons too.
    Select button now moves you to 'Daily' or 'Once' - again you change this with the arrows. Select button moves you on to choose Radio or buzzer (again, you change this with the left/right arrows and press select for your choice).
    All settings are done, you can power off now, or I think pressing menu took me out of settings mode and back to radio display.
    Turning the alarm on or off:
    Press menu, then right arrow 5 times for 'clock.'
    Select this and you'll see 'set alarm' - press right arrow button once and you get 'Alarm On/Off.
    Now every time you press select, the bell symbol toggles from visible to invisible, visible being 'on.'
    You can now press menu to get out of the settings mode.
    Jul 20, 2011 | Audio Players & Recorders
    Alarm setting I want to set an alarm to repeat daily as a alarm clock would for a g shock
    casio gshock...Setting the TimeG-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. To set the time, press and hold the the upper left ...">casio gshock...Setting the TimeG-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. ...
    Mar 10, 2011 | Casio Watches
    I can't turn the alarm off so that it won't go off daily. Right now it goes off everyday and I don't want it to.
    If you click the "alarm" button repeatedly you can pick what you want to wake up to. Do this until the only little picture lit up is the alarm clock picture. That will turn of the alarm.
    Jan 09, 2011 | GPX CI109 Clock Radio with Dock for iPod ...
    The alarm sounds daily. how can i stop it?
    There are two alarms, and the steps are the same. Make sure both are off.
    For Wake 1 alarm.
    1.Look on the face. One the left are two symbols, a 'bell' and a 'music note'. 2. Press the 'Wake 1' button on top, several times. Notice how the green circle on the left of the face switches back and forth between bell to music note. 3. HOLD DOWN WAKE 1 BUTTON, until both lights are off. The Wake 1 alarm is now off.
    Wake 2 alarm: Look at green circles on the right side of the face. HOLD DOWN WAKE 2 BUTTON until both circles are unlit. The Wake 2 alarm is now off.
    Get a piece of paper, write "HOLD DOWN WAKE BUTTON to stop repeating alarm" and tape it to the back of the clock.
    Aug 21, 2010 | GE 7-4853 Clock Radio
    Calender alarm only rings once
    in alaram setting keep alaram all the day so you can get the alaram daily
    Apr 09, 2010 | Palm Treo 755p Smartphone
    HOW DO U SET ALARM
    To create an alarm follow the steps below:
    1. While in standby mode, press the Menu / OK button
    2. Select Tools
    3. Select Alarm Clock (9)
    4. Highlight the desired Alarm, using the navigation keys, from the following:
      • Alarm #1
      • Alarm #2
      • Alarm #3
    5. Press the Menu / OK button
    6. Set alarm to On, using the navigation keys
    7. Set alarm time, using the keypad
    8. Select either A for AM or P for PM, using the navigation keys
    9. Press Menu / OK button to choose the Ringer Type from the following:
      • Single Tones (1)
        • Tone 1 through Tone 9
      • Ring Tones (2)
        • Ring Tone 1 through Ring Tone 15
      • Melodies (3)
        • Ball (1)
        • Caribbean Cruise (2)
        • Chorus of Clocks (3)
        • Right Here (4)
        • Guitar Man (5)
        • Latin Lady (6)
        • Minuett (7)
        • Mixed up World (8)
        • Pressure (9)
        • Simply Blue (10)
      • My Content (4), for previously downloaded music
    10. Select desired Repeat frequency, using the navigation keys, from the following:
      • Daily
      • Once
      • Mon to Fri
      • Sat & Sun
    11. Select the Snooze Interval, using the navigation keys, from the following:
      • 5 Minutes
      • 10 Minutes
      • 15 Minutes
      • 20 Minutes
    12. Press the left soft key for Done to save the alarm changes
    Dec 16, 2009 | Samsung SPH-M500 Cellular Phone
    Lost instructions for Lexon world time clock model Planete
    to set the alarm, press and release the "alarm" button; then press and hold the "set" button until the hour begins to blink. press "adv" until
    the hour AM or PM is correct;now press and release "mode" so that the minutes begin to blink. Set the minutes using "adv"; now press and release "set". Finally,
    press and release "adv" once to bring up (or remove) the alarm icon. Then press"alarm" once to return to the main display.
    To set main display, press and hold "set" until the hour begins to
    blink; press "adv" repeatedly until hour AM or PM is correct. Now
    press "mode" so that the minutes blink, and use "adv" to get the
    minutes right; then press "mode" so that the next item begins to
    blink; use "adv" to advance until it is correct, then press "mode"
    so that the next item blinks, and so forth until you're all done.
    Finally, press and release "set".
    Aug 10, 2009 | Watches
    The external display on my blackberry pearl flip is empty
    i had the same problem. i reset the alarm to go off immediately, then dismissed the alarm. i also reset the default theme. the clock came back to the external display and the daily alarm message went away!
    Mar 05, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
    Conair WCR20 Clock Radio Logo
    12 people viewed this question
    Top Conair Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Conair Audio Player and Recorder Expert? Answer questions, earn points and help others
