Question about HP DeskJet D2560 InkJet Printer
Orange light blinking on HP 2560 printer and document not printing
geemarie
  • 876 Answers
SOURCE: hp 5550 printer problem
Did it eject the paper? The paper may have been crooked or became so in the printer. Check the Paper jam area first. If there is nothing there, Let's try a simple reset of your printer.
Go to Control panel>printers and faxes>click on your printer icon and under documents click cancel all documents.
Turn the printer off
Remove the paper from the tray
Unplug it from the power source
unplug it from the PC
Now open the paper jam door and gently push the paper roller forward until it clicks
Now do everything in reverse order until you get to turning the printer back on. give it a few minutes and see if it resets itself.
when you reload paper, besure that it is aligned carefully and the holders are pushed into place.
Let me know if this helps. Good Luck!
Posted on Aug 13, 2008
SOURCE: hp 1160 light blinking
orange & green light on
Posted on Dec 23, 2008
  • 73 Answers
SOURCE: HP 6940 color cartridge light will not stop blinking
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
I might have an idea why this is happening....The print cartridges might need cleaning...
Follow the steps below to do this....
Step one: Remove the black, photo print cartridge, or the gray photo print cartridge
NOTE:
The black, photo print cartridge, or the gray photo print cartridge is in the right side of the carriage. -Lower the cover of the product.
-If the print cartridge status light flashes, proceed to Step two: Replace the print cartridge.
If the print cartridge status light is off, proceed to Step three: Manually clean the print cartridge.
Step two: Replace the black, photo print cartridge, or the gray photo print cartridge and remove the tri-color print cartridge
- Remove plastic tape from new ink carttridge CAUTION:
Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper electrical contacts.
NOTE:
The tri-color print cartridge is in the left side of the carriage.
-Lower the cover of the product. -If the print cartridge status light stops flashing, proceed to Step three: Manually clean the print cartridge.
If the print cartridge status light still flashes, replace the tri-color print cartridge. If the issue continues, service the product.
1. Gather the following items to clean the print cartridge and carriage:
o Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water can contain contaminants that damage the cartridge.
o Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
o Sheets of paper or a paper towel to rest the cartridges on during cleaning.
2. Open the product cover, and wait until the carriage stops moving.
3. Remove the print cartridge, and place it on a piece of paper with the nozzle plate facing up.
NOTE:
Clean the contacts quickly so that the print cartridge is not outside of the product for more than 30 minutes. If the cartridge is outside of the product for too long, the ink can dry and clog the nozzles.
4. Unplug the product.
5. Dip a swab in the clean water, and then squeeze it to remove most of the moisture. The swab should be only slightly damp.
6. Clean the print cartridge contacts. Do not touch the nozzles.
7. Clean the contacts in the carriage, inside the product.8. Either let the print cartridge sit for ten minutes to allow the cleaned area to dry, or use a new swab to dry it.
9. Reinstall the print cartridge.
10. Plug the product back in.
11. Close the product cover.
Good Luck!
If there is anything more I can do for you please let me know if not and the problem is solved please rate it, Thanks, JCE
Posted on Apr 14, 2009
  • 5 Answers
SOURCE: hp designjet 110 is not printing. paper is spooling then stops, retracts. orange error light is blinking. can't find users manual
check ur orange cartredge
& check ur orange printer head & clean ur printer head
ur problem is solve
because this problem is only cartredge & prinater head
Posted on May 13, 2009
  • 5 Answers
SOURCE: I cant print from hp laserjet 1320, orange light is always on.
there is something wrong in your cartridge may be its empty.. replaced a new one
Posted on May 19, 2009
Will not print copies
This link gives U full information about the control panel errors.. Pl go through it before replacing consumables..
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00476294&cc=us&dlc=en&lc=en&product=1146331#N1316
Apr 04, 2014 | HP Photosmart 3180 All-In-One Printer
Orange light blinking, cleared paper jam, changed printer cartridge, won't print subsequent documents.
Double check all doors/ rollers for small pieces of paper stuck in the rollers. Sometimes just opening the door in question and closing will reset the paper jam sensors. Paper jams can be smaller than your pinky finger nail. So double check,
Comment if it still isn't working.
Oct 21, 2011 | HP Deskjet F335 All-In-One InkJet Printer
Have a deskjet 710c inkjet printer the inks seem to be stuck over to the right and the 2 orange buttons are blinking. ... * Solve It! Solve It! Bid * * * ... have a deskjet...
I found this on the HP website. http://h10025.www1.hp.com/ewfrf/wc/document?docname=bud09179&cc=us&lc=en&dlc=en&product=59307&tmp_track_link=ot_search
POWER light On c00106963.jpg RESUME light Blinking c00106965.jpg PRINT CARTRIDGE light Blinking c00106961.jpg Problem
The BANNER lever needs adjusting.
Solution
1. Turn the printer off.
2. Move the BANNER lever (next to the paper tray) up and down a few times.
3. Turn the printer on.
If these solutions did not fix the problem, have the printer serviced.
Oct 27, 2010 | HP DeskJet 710c InkJet Printer
Hpdeskjet problem
A light blinking under the cancel button usually indicates a problem with the color cartridge.
Go to this page for instructions on resolving that issue - about halfway down the page is a picture of your printer control panel with both the left and right light blinking. The section explains that it's to help if "One or both print cartridge status lights are on and blinking."
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01368924&cc=us&lc=en&dlc=en&product=3374277
Jun 04, 2010 | HP DeskJet D2560 InkJet Printer
Hp printer power light keeps blinking -- wont print any document
Turn both your printer and computer off then after a few minutes turn back on. This should cancel the print job.
May 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
DeskJet 940c InkJet Printer: I have an hp deskjet 940c printer. The orange lig...
the moving ink frame is probably pointing to a symbol such as replace color ink( three dots on ink cartridge picture). Replace color ink. You are probably printing your black and white documents with colored ink--always select black or greyscale.
May 17, 2010 | HP DeskJet 940c InkJet Printer
Orange ink light blinks. printer will not print.
turn on/off, unplug, plug in, should reset configs.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome trouble shooting site
hope this helps and good luck
Apr 29, 2010 | HP DeskJet 932c InkJet Printer
Blinking orange light
Printer lights blink in certain patterns to tell you about specific problems.
open this link and resolve the issue
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00575443&lc=en&dlc=en&cc=us&lang=en&rule=26028&product=467982
Mar 24, 2009 | HP Deskjet 6980 InkJet Printer
Document is not printing
Press the feed button. If that doesn't work, turn the printer off, wait a few seconds, and turn it back on again.
Feb 03, 2009 | HP DeskJet 932c InkJet Printer
HP DeskJet D2560 InkJet Printer Logo
56 people viewed this question
Seeker5211
Seeker5211
