Question about Taylor & Digital Scale Lithium Scale
How to change from kg to lbs - Taylor & Digital Scale Lithium Scale
2 Suggested Answers
SOURCE: can not change from Kg to Lbs
Flip over the scale, on the back there is a black button, slide it to pounds.
Posted on Apr 05, 2010
How do I change from cm/kg to inches/lbs?
Convert inch pound to kg cm - Conversion of Measurement Units
www.convertunits.com/from/inch+pound/to/kg+cm
Quickly convert inch pounds into kg cm (inch pound to kg cm) using the online calculator for metric conversions and more.
Jan 21, 2016 | Schiller Cardiovit At 2 Light Ecg Machine
No can do. Cm is distance and Kg is weight. Inches are distance and pounds is weight. Thats like "how can I convert an orange into an apple. RJ
Conversion from kg to lb
Multiply by 2.2 to get lbs. In this case, 84 kg should convert to approximately 184.8 lbs.
Aug 19, 2014 | Cars & Trucks
How do you change from kg to pounds?
To change to lbs. Press button to turn on, while it is flashing, you press button again, that will change it to lbs. You must do it while it is flashing.
Mar 30, 2014 | Rapala 50lb Digital Scale
To convert 15:3 to kg
"15:3" is a ratio, "kg" is a measure of mass (or weight). Your question is like asking how to convert one-half to pounds.
Do you want to convert 15 lbs to kg? That would be about 6.80 kg.
Or do you mean 15 lbs 3 ozs? That would be about 6.89 kg.
Or do you mean 15.3 lbs? That would be about 6.94 kg.
Or, since 15:3 is 5, do you mean 5 lbs? That would be about 2.27 kgs.
Dec 05, 2013 | Office Equipment & Supplies
How much air pressure to put in shocks with 2 riders
2006 Touring shocks =
Table 2-6. Rear Air Suspension Pressures
Shock Loading Recommended Pressures
PSI kPa
All Models Except FLHRS, FLHX - Standard Shocks
Solo rider up to 150 lbs. (68 kg), hereafter referred to as "Average" 0 0
Solo rider 150-200 lbs. (68-91 kg) 0-10 0-69
Solo rider 200-250 lbs. (91-113 kg) 5-15 35-103
Average rider with passenger up to 150 lbs. (68 kg) 10-15 69-103
Average rider with passenger up to 200 lbs. (91 kg) 20-25 138-172
Maximum GVWR (see Section 2.1 Specifications) 20-35 138-241
FLHRS, FLHX Only - Low Profile Shocks
Solo rider up to 160 lbs. (73 kg), hereafter referred to as "Average" 0-5 0-35
Solo rider 160-200 lbs. (73-91 kg) 0-10 0-69
Solo rider over 200 lbs. (91 kg) 5-10 35-69
Average rider with passenger up to 150 lbs. (68 kg) 20-30 138-207
Average rider with passenger over 150 lbs. (68 kg) 25-35 172-241
Maximum GVWR (see Section 2.1 Specifications) 40-50 276-345
111WWAARRNNININGG
Use this table as a starting point in determining suitable rear air suspension pressures. Do not exceed
maximum GVWR when loading vehicle and do not pressurize system in excess of 50 psi (345 kPa) for
FLHRS, FLHX models and 35 psi (241 kPa) for all others. Excessive load weight and/or air suspension
pressure can adversely affect handling and lead to loss of vehicle control, which could result in loss of life
Aug 30, 2011 | 2006 Harley Davidson FLHR Road king
Changing the AC belt in a 1994 ford aspire. any diagrams or tips? How long should the job take?
Power Steering Pump
See Figures 9, 10, 11 and 12
  1. Remove the air cleaner intake tube and air cleaner assembly.
  2. Loosen the power steering pump bolt and the adjustment locknut. Make sure the belt is properly seated on the pulley before adjustment.
    1. Turn the adjustment bolt to set the belt tension.
    2. Use Rotunda offset belt tension gauge 021-0028A, or equivalent, and following the tool manufacturers instructions, adjust the belt to the following specifications:
      New belt: 110-132 lbs. (50-60 kg). Run the engine for 10 minutes, then readjust the tension to 110-132 lbs. (50-60 kg). Used belt: 95-110 lbs. (43-50 kg).
    3. Tighten the power steering pump bolt to 27-38 ft. lbs. (37-52 Nm).
    4. Tighten the adjustment locknut to 14-19 ft. lbs. (19-25 Nm).
    5. Install the air cleaner and intake tube.
May 06, 2011 | Ford Aspire Cars & Trucks
How to convert from kg to lbs on the defrost cycle
.45 kg = 1 lb
2.22 lbs = 1kg
So if you know kg and need lbs. multiply the number of kg by 2.22. for example if you have 4 kg
4 x 2.22 = 8 lbs
May 10, 2010 | Panasonic NN-H275 Microwave Oven
How do you change the weight settings from kg to lbs
I don't know if you can change the setting but 1 kg is 2.2046 lbs so 100 kg would be 220.46 lbs for example. Multiply kg times 2.2046 to get lbs
Mar 08, 2009 | Nintendo Wii Fit for Wii
Taylor & Digital Scale Lithium Scale  Logo
26 people viewed this question
Top Taylor Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
