Question about byD sign 3032 30 in. HD-Ready LCD Television
Sty 8332 d sign hd tv switch off whilewatching
Hi i have a sharp aquos lc-37d43u tv and I can't get it to connect to my computer .I tried HDMI and VGA but I just don't seems to understand how to make it work ;( Please HELP
prob with sansui sty 0330 LCD TV
hi,i have a sansui sty 0330 tv and the screen is flashing 1 second flash, 1 second good, then 1 second flash, 1 second good is going like this contineously
Dec 18, 2013 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
I have dish network and dont know what channel to go to in order to use my dvd player. I cant find my manual.
Hi my nameis Mike Houston of DISH Network and I was going over your post and see you wantto watch a DVD and not sure what channel or input the TV should be on. Whilewatching a DVD the connectors may be RCA cables (Red, Yellow, White), if those arethe connections you will want to put the TV on either Video1 or Input1. Whilethe DISH Network should be connected to the TV by Coax cable (it will have ascrew on connection). The TV channel should be set to ch3 or ch4, if you haveany questions please e-mail me at michael.houston@dishnetwork.com.
Dec 01, 2010 | Sansui DTV2760 27" TV
"No signal" sign on TV screen using HDMI selector
it sounds like a refresh issue, double check you selector and make sure it fits the refresh of the tv. i had this once with a sharp where the tv was 120hz and the selector was 60 and it created a no signal and when it did come in it was jumpy. if you have a 120 tv then selector should be the same.
Apr 27, 2010 | LG 42LH30 42 in. LCD TV
I have a SimpleTech SimpleDrive STI-USB235 160
Yes, you should turn the HD off when not in use. The direct drive mechanism is constantly turning when current is applied. Turning off the unit will preserve it. Four years is quite a long time for a hard drive and may need replacement soon.
Apr 19, 2010 | SimpleTech SimpleDrive...
How do I remove the Hd compatibility message from top of screen?
Go in ur tv menu go to Option go down the menu check the Program Title Dsiplay pick no.That should take away the HD signal sign.But some tv must have that HD sign,to tell u it in HD programings.
Apr 03, 2010 | ViewSonic VPW425 42 in. Plasma HDTV
I need a wiring diagram for five TL8012-S1 safety interlock wired into a SR103AM monitoring relay or a certified safety PLC
OK go to the web sites below and download PDF documents, They explain it all. It is pretty simple really. www.sti.com/ltr2/access.php?file=pdf/2520.pdf
http://www.alliedelec.com/images/Products/Datasheets/BM/STI/328-0064.pdf
Feb 15, 2010 | Omron Sti / 44519-1430 Safety Interlock...
Jvc 52" hd tv screen yellow
Have crack screen sign?Not fixable only require LCD changing,not buy able LCD screen only can buy it new from the tv compannies,but only sell as new tv only.
Jan 08, 2010 | JVC HD-52G787 52" Projection Television
Tv shuts down
does the main board have the flyback on it? if so the yokes or CRTs can be intermittently shorting which in turn triggers your shut-down.
turning it off or unplugging just resets the shut down circuit.
Sep 04, 2007 | Samsung HL-R4266W 42" HDTV-Ready...
byD sign 3032 30 in. HD-Ready LCD Television Logo
19 people viewed this question
Top byD sign Televison & Video Experts
Jaime Hernandez
Elise Lacoursiere
Elise Lacoursiere
Are you a byD sign Televison and Video Expert? Answer questions, earn points and help others
