Question about Coffee Makers & Espresso Machines
Coffee heatman 101 - Coffee Makers & Espresso Machines
Tip
Thanx heatman 101, i will check it out and report back, thanks for being so...
Your washing machine will not fill up with water. You have checked the hoses, cleaned the screens, and still no water. Now what is next?
First make sure that you unplug the washer to prevent a shock. Then you will have to get to the valve. For some washer this can be done by an opening in the back panel. And for other you may have to remove the entire top of the washer to access the valve body.
Hopefully you can get there without removing the wiring, so that you can check to see if you are getting power to the valves. Once you can get to the valve body, then carefully get a meter on the connection to the coils, then plug in the washer and start the cycle where the water would normally flow. If you have power at the coil and the water does not flow then you know that the coil is bad or the valve is stuck. There are ways to clean the valves but usually a new valve body will be under $40.00 and it is not worth the mess and the possibility that the valve will soon get stuck again. If you find the problem there, just replace the valve, it is much easier.
If you are getting no power to your valve then you know to look back in the wiring further. You may have a bad switch in the timer. Follow the wires and trace the back to see where the power is stopping at. If you have power going to the timer and no power coming out then you have found your problem there.
Troubleshooting appliances is often just a matter of following the problem back to where it starts. Be patient and be very careful when working with electricity. Always make sure you have the appliance unplugged when you are not actually checking for voltage. Also be aware that some appliances have power on what you would think to be the neutral.
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
on Apr 26, 2010 | Washing Machines
Water heats goes back int fill tank instead of the coffee cup
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 15, 2011 | Keurig B60 Coffee Maker
Heatman101, I am about to buy a one room HVAC unit for one large bedroom (14'x16') and my HVAC fellow recommended an Amana thru wall unit model # PTC093B35AE. He quoted $1200. What do you think of this...
Stay away from Heatman 101 as he does more damage than he's qualified to do much else so just stay away from him, period
end of discussion......
Clarita Ross.
a very dis-satified customer for
computer help.........& I certainlyhope I helped others......
August 26, 2011
Aug 07, 2010 | Heating & Cooling
Pressure valve is leaking water... read the posting dec 6 2009 by heatman 101, but do not have ideas on how to just simply stop water inflow to the boiler (no manual)
Hello,I hope you plan to change it.The boiler feed valve could be hard to locate as each installation in unique.Best to shut off HOUSE main and wait till boiler pressure drops and leak stops.Then it will be safe to work on.
Apr 20, 2010 | Heating & Cooling
Clothes smell like mildew after washing
Here is a tip that I wrote about that problem...it tells you how to clean your washer and also how to prevent it from coming back...
I will also include a tip I wrote on washer maintenance...
http://www.fixya.com/support/r3993813-stop_washing_machine_smell_mold_mildew
http://www.fixya.com/support/r4312694-washing_machine_maintenance
heatman101
Asker's Testimonial " heatman 101 Just wanted to say thanks for helping me with the mold on my Maytag. Your info is greatly appreciated! " - Landara
Apr 07, 2010 | Asko W6021 Front Load Washer
How do I clean the front door gasket area?
heatman101
Apr 07, 2010 | Frigidaire ATF6000ES Front Load Washer
How to make coffee with 101-cup percolator urn (Regalware)?
Simply fill with COLD water to the number of cups desired.
Place the stem and basket in the pot and put one 8 oz cup of coffee for every 20 cups of water into the basket...when doing 100 cups I add an extra 12 oz of coffee for a good coffee flavor.
Place the perforated lid on the coffee basket that is in the pot (if there is a lid--some do not have a lid). Put the cover for the coffee pot in place.
Plug in.
Turn on if there is a switch.
Give these large pots about 1 minute per cup, brewing time...that is a little over an hour usually to brew 100 cups. The coffee maker will percolate with the water coming up through the stem and over the coffee as the water heats. Usually there is an indicator light that comes on when it is finished.
If holding the coffee for awhile, it tastes best if you remove the stem and basket and it will maintain the heat without doing more "perking" and becoming stronger or bitter.
Be sure to wash it out and dry it well, leaving the lid loose or upside down for storage so that the pot doesn't become pitted. Blessings, Louise
Nov 14, 2008 | Regal Ware 426473 Black Satin Coffee Urn...
Coffee Makers & Espresso Machines Logo
14 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
