Question about Frigidaire ATF6000ES Front Load Washer
How to fix a clogged drain pump - Frigidaire ATF6000ES Front Load Washer
How do I fix a nd code
No drain check the drain pump for clog.if no clog replace pump usually will fix it
Nov 07, 2015 | Washing Machines
Water wont drain, think filter is clogged.
Hi tammylynn131,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 08, 2011 | GE Energy Star WCVH6260F Front Load Washer
Dont drain
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 31, 2011 | Kenmore 24032\24036 Top Load Washer
Oe code. Will not drain. Steps to fix?
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 30, 2011 | LG LDS4821 24 in. Built-in Dishwasher
My whirlpool quiet wash plus diswasher is not draining water. How do I fix it?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 14, 2011 | Dishwashers
WONT DRAIN PROPERLY
Hi
Daniel
Aug 08, 2011 | Tecnik TKL9260 Front Load Washer
My dishwasher doesn`t drain. there is water at the bottom at te end of every wash... what`s wrong? how can i fix it?
Hi
Daniel
Aug 06, 2011 | Whirlpool Dishwashers
My dishwasher does'nt drain, how can I fix that?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If it's still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 08, 2011 | KitchenAid 24 in. KUDP01IL - Multiple...
IT WON'T TAKE THE WATER OUT WHEN SPINNING?
The most common causes for water not draining are:
  1. Clogged drain tube
  2. Clogged drain hose
  3. Clogged drain pump
Removing the drain hose from the tube and inspecting it should give you an idea right away if the hose is clogged. The problem is most likely in the drain pump. Many times, items left in pockets will find their way into the pump and become lodged there.
May 12, 2011 | Washing Machines
Ld light
ld is a "long drain" fault. If it takes longer than 5 minutes for the water to pump out, the operating pressure switch will reset. Check your drain pump and/ore drain lines for a clog.
Apr 23, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
11 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
