Question about RCA VCA115 VHS-C Adapter
My vhs adaptor will not work in my torshiba vhs player
I have a couple VHS-C tapes that drag
This may be caused by a faulty adapter. 1. try playing in the camera. 2. try a different tape. 3. try a different adapter.99% this is a problem with the adapter or the tape. It really sounds like the tape isn't turning freely, which can be caused by a brake sticking, or spindle in the tape or adapter.
Mar 16, 2012 | Televison & Video
I bought a panasonic cassette adaptor for my vhs-c tapes . it says svhs adaptor on the front of the box .will the ordinary vhs-c tapes fit in it and does the door open on the front or is it loaded from the...
You don't specify the adapter you have, but most load from the top. The main thing here is that VHS and VHS-C are both the same size of tape. Whether they are recorded in SVHS mode or not will not affect the adapter, just whether or not you get a picture. Theadapter only allows you to put a compact cassette (VHS-C) into a standard VHS VCR. The adapter will require batteries to allow it to place the VHS-C cassette tape into the proper position for use in the VCR.
Dan
Nov 24, 2010 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
VHS player ejects the adaptor
Please check to see it the battery on your adapter is worrking fine. Or else replace the battery . If mechanical type load up the tape before you load the cassette to the player. If this ejects again the adapter is not landing well into the mechansim. cleck within the tray for any foreign bits that is preventing the adapter from loading. Also if the end sensors are detecting , use a tape to cover the inner hole of the adapter. if the tape is tight in the adaptor- check for free state by turning with the finger.
If your regular tapes are playing well then you will get the fault without much of an issue but recheck on these tips. Helpful? good day
Jul 10, 2010 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
Where do I buy a Panasonic cassette adaptor VW-TCA7E VHS
You can get a cassette adaptor that will except any VHS-C tapes and play them back on any standard VCR from Maplin www.maplin.co.uk.
They are £14.99 plus post! It's unlikely that you just have to have the Panasonic one!
Jun 17, 2010 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
I inserted a vhs-c tape in to my cassette adaptor and the motor started running but it won't stop. I tried to remove the vhs-c tape but the switch does not respond. I can put the cassette adaptor in the...
That may be what you will have to do, in this case, unless you can somehow get that switch to work. I don't understand why the motor continues to run, but it's probably a broken plastic piece or other gear part that's not functioning. When you take the cassette apart, try to look for any broken parts, or loose components that you can reseat. You may have to end up buying another adapter. Wish I knew more to tell you, but that's all I can think of.
Apr 18, 2010 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
Is there a VHS adapter to view tapes on TV?
The 8mm recording system is totally different to the VHS system and therefore cannot be played in a VHS player. No adaptor is available such as the VHS-C to VHS adaptor.
Sony did release a dedicated 8mm Player/Recorder many years ago although these tend to be difficult to find offered for sale. RHN
Jan 03, 2010 | Sony Handycam CCD-TRV37 Camcorder
CASSETTE ADAPTOR VW-TCA7E tab won't retract when I place the video camera cassette in the adaptor and close the cover. The triangle-shaped tab is on the left side of the adaptor and when it has not...
I had a similiar problem, or so I thought, but my son has just found that it needs a battery, which I did not even know, so maybe yours just needs a new battery? the cover is near the tab, hope this helps
Apr 20, 2009 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
How do you use the Panasonic PV-P1 Vhs C Adaptor?
I do not know if this is the permanent solution, but I just rewound the tape to the beginning and ejected it. The cassette came right out of the PlayPak. I will let you know if this always works or not.
Nov 13, 2008 | Panasonic Electronics - Others
RCA VCA115 VHS-C Adapter Logo
52 people viewed this question
Top RCA Electronics - Others Experts
ray gallant
L Pfaff
L Pfaff
Robert A. Watson
Robert A. Watson
Are you a RCA Electronics - Other Expert? Answer questions, earn points and help others
