Question about Zebra S4M Thermal Label Printer
No image printing on the label for zebra s4m.
I have a zebra s4m label printer. It has a print head and the labels come out of the machine when we print but there is no image on the label. Why could this be?
3 Suggested Answers
  • 32 Answers
SOURCE: Zebra S4M label printer
Check the drive belt. It might be missing a tooth if the printer is older. I can assist if you want to check this.
Posted on Oct 27, 2009
  • 97 Answers
SOURCE: HELLO: PRINTS ONE LABEL
This could have a couple of different causes. Best thing to do is determine if the problem is with the printer or the software. Turn the printer off and back on again. After the power-on self test is done, just press the feed key. Does the printer feed just one label ? If so, then you know the printer has a good calibration on the size of the label. Now print a label. Does it skip one after printing ? If it does, now you know the problem is in the software because the printer is only going to do what it’s told to do. Check all settings in the label software / printer driver to make sure label size is accurate, correct printer driver is being used, etc.
So first check to see if the printer is ok by itself. If it feeds two labels after powering up, then the calibration is needs to be redone. Also make sure the media sensor is positioned over the label. This can cause skipping as well if out of position.
Hope that helps !
Posted on Apr 28, 2010
S4m quick books
change the default orientation setting in printer properties.
May 10, 2013 | Zebra S4M Thermal Label Printer
I am using a Zebra S4M Thermal printer with Zebra brand labels. I changed out the roll of labels with a new roll and it will not print. It completed the task like it always does but i only get a blank...
The new labels are probably not thermal labels. Test them by applying heat to the surface and see if they turn black. If they do not change, then they are thermal transfer labels and not direct thermal. Contact your label vendor and have them replaced.
Jun 09, 2011 | Zebra S4M Thermal Label Printer
Hi I am unable to print from Zebra S4M.. while printing the configuration it prints but does not print the test page or the label.
There a number of things that can cause that: 1) wrong printer driver was installed 2) cable to printer is faulty 3) wrong port was selected when the printer driver was installed
Check these and let me know!
Jan 20, 2011 | Zebra S4M Thermal Label Printer
Loaded ribbon correctly according to Zebra S4M Quick Reference guide....but won't print anything on labels.
The ribbon has wax just on one side. So, if nothing prints on the label, first thing I'd check if the ribbon loaded with waxed side facing label.
Jan 11, 2011 | Zebra S4M Thermal Label Printer
Zebra s4 thermal - label print "slides" down
Refer to your handbook and do a recallibration
Dec 05, 2009 | Zebra S4M Thermal Label Printer
I have a Z4M plus and it only prints half of the label. One half is well printed and the other half is blank. please help
Clean the print head. If half has got gummy from labels, it will not be able to print. You will need to use a solvent for the gummy adhesive... possibly Toluol... HOWEVER be very careful to keep that off ANY plastic parts.
Nov 26, 2009 | Zebra Z4Mplus Label Printer
Settings seem correct, but labels will print on 2 labels, or skip labels. Zebra s4m
The printer is not calibrated to the media length. You need to perfrom a calibration with the labels loaded. This is in the users manual on how to do it. The printer should be set to automatically do this when powered up.
Oct 20, 2009 | Zebra S4M Thermal Label Printer
i think it's a GAP problem, try to calibrate from the computer, if that's not solve the problem, find the CALIBRATE option on the LCD panel a. just follow the instruction to do manual calibrate
Aug 13, 2009 | Zebra S4M Thermal Label Printer
S4m is not printing
zebra s4m barcode printer ,suppose if i print 10 Labels only 2 Label come out balance 8 in memory .then printer comes pause, disply showing paper out /ribbon in/please help me....
Dec 30, 2008 | Zebra S4M Thermal Label Printer
Zebra S4M Thermal Label Printer Logo
21 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
