Question about KitchenAid 22.0 cu. ft. Side-By-Side Refrigerator with AquaSense In-Door-Ice and Water
Mold on ice dispenser - KitchenAid 22.0 cu. ft. Side-By-Side Refrigerator with AquaSense In-Door-Ice and Water
Ice cubes wont come out when the dispenser tips it upside down
The ice mold tray has built up deposits that "glue" the ice cubes to the tray. This usually means you will have to change the mold tray. You could try vinegar or lemon juice to clean it but the trays are not that expensive.
Apr 12, 2014 | Refrigerators
Mold growing around ice dispenser area. Cant figure out how to get to the mold .
Pull ice maker out and clean it. Then make sure you have a fresh water filter on water supply. Mold in the freezer is uncommon if its truly freezing inside. You have dirty water coming in.
Oct 13, 2013 | GALAXY Microsystems 25.4 cu. ft....
Whirlpool Gold side by sideGC3PHEXNS00 not making ice but the water works. Already replaced the filter.
put your finger in the ice mold and see if there is ICE in the mold. if no ice then use a turkey baster and put approx 1/4 cup of water into the ice mold, slowly. in about 2 hrs you should hear ice drop and then refill with water. if there is ice in the mold, you most likely need a new ice maker.
Jan 02, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
Mold on Ice dispenser
If there is mold on the outside of the ice dispenser you should wipe it down periodically/ weekly or more often with a mild mixture of soapy water with a touch of bleach in it. Make sure that nothing in the refrigerator is blocking the port that ice is deliver through or that ice is not building up around the inside of it. And do not let water or ice lay stagnant in the door tray at the bottom of the dispenser.
Good Luck and God Bless
GodsAuthor
Aug 21, 2010 | Kenmore 53642 / 53644 Side by Side...
Mold/Bacteria formed between ice dispenser and dispenser lever Can dispenser be removed from lever for cleaning? If not, how to clean?
Use a bathroom mold and bacteria remover spray available from most supermarkets. Also spray down into the feeder on the inside of the door. Make sure you rinse the area thoroughly after use and run water through the water chiller dispenser and run some ice throughthe ice dispenser and throw these away. Then it should be safe to use.
Sep 30, 2009 | Kenmore Refrigerators
Shot Mold Heater?
The mold heater comes on shortly before the ice is dispensed. It warms up the mold so that the ice releases. The heater, if not working could cause the water to overflow as the ice can not be ejected if the heater does not work. That woud make the appearance that the ice melted and refroze.
Jun 04, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Ice dispenser has black mold around area that ice comes out
shut down unit press for ice the door will open wipe with warm water
Apr 07, 2009 | Electrolux 25.9 Cu. Ft. Side-by-Side...
No ice
pour some water in the ice mold and see if it will kick out a batch if it does get a water valve. If ice is already in the mold then replace the ice mold thermostat. If this is a newer ice maker get a hairdryer and make the mold rotate around. This sometimes gets the newer ones back on track.
Dec 05, 2008 | Whirlpool GD5SHAX Side by Side...
KitchenAid 22.0 cu. ft. Side-By-Side Refrigerator with AquaSense In-Door-Ice and Water Logo
23 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
