Question about Fisher Dishwashers
Belt has come off my fischer and paykel drawer dishwasher - is it easy to self repair
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 94 Answers
I was not aware that they used a belt ?
Posted on Oct 04, 2014
Krazytech
  • 725 Answers
SOURCE: F4 error on fisher and
No increase in water
temperature during
wash cycle. --->
Faulty element.
Electronics controller
faulty.
Faulty temperature
sensor.
Check the heater thermistor and the wires to both...
Posted on Jun 16, 2008
  • 81 Answers
SOURCE: reset fisher and paykel two drawer dishwasher
Have you tried turning it off and on at the power point?
Mat
Posted on Sep 24, 2009
  • 784 Answers
SOURCE: How can I empty some residue water from the Fisher
Go to diagnostic mode you can turn on the drain manually. The motor has 2 directions of operating: one for pump and the other for drain. When the LCD displays P1 it means wash, when it displays P2 it is for drain.
Posted on Nov 01, 2009
  • 784 Answers
SOURCE: I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Posted on Dec 29, 2009
SOURCE: fisher paykel drawer dishwasher is stuck open and
Hey I dont know if you have this problem, but with mine the gasket seemed to be blocking the opening, so you could close it, but you had to shove a lot. The FP help line said to just unplug and replug in the unit. I did it and lo and behold it worked fine again. It did seem to leak a little bit the first time I reran it, but that seems to have gone away. Hope this helps
Posted on Dec 31, 2009
Fischer and Paykel. Why won't it start?
hold down the lock button for 4 seconds and see if the light turns off.
if so then tada
Aug 10, 2015 | Dishwashers
Fischer and paykel dish drawer leaking
Replacing lid seals on the dishdrawer is not for the faint hearted.
In particular if you are replacing the lid actuator and motors that go with it.
http://www.genuineapplianceparts.net/ecart/item.php?item_id=386&category_id=58
Apr 06, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Keep blowing fuses
This means there is water collected on the base of the dishwasher cabinet under the bottom drawer. You will need to disconnect the dishwasher mains plug and take the bottom drawer out to dry the base out. Follow instructions in this manual (page 7 step 2) to remove the drawer.
Fisher Paykel DishDrawer Installation Instructions ManualsOnline com
Jan 08, 2014 | Dishwashers
Fischer and paykel drawer dishwasher has no power to drawer, power at outlet, was flashing F1 prior to shutting down, thanks
If you have a double drawer unit then please confirm what is happening with the other drawer. Most likely the base of the dishwasher under the bottom drawer has flooded and brought down the power with it. The power board sits under the bottom drawer. BE CAREFUL NOT TO TOUCH THE DISHWASHER BEFORE SWITCHING OFF THE MAINS POWER SUPPLY TO THE DISHWASHER AS THE CIRCUIT MAY BE LIVE AND GIVE A SHOCK. You will have to take the bottom drawer out and see what is happening under it.
Jan 16, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fischer paykal dishwasher drawer leaving white powder on dishes
If rinse aid levels in dispensor are ok then check if it is being used. the rinse aid setting may be set too low.
Dec 24, 2012 | Fisher and Paykel DD605SS Stainless Steel...
F1 code on my Fischer Paykal drawer dish washer . This is the flood sensor . It was. tripped when water was splashed in a plug that shares the same Circuit. How do I reset the sensor?
Not sure if the flood sensor will trip if the water is splashed into the mains plug. F1 can also occur if the power to the top drawer has failed. Flood sensor trips when water collects at the base of the dishwasher housing under the bottom drawer.
I think the problem you mention has caused the power to the top drawer to fail due to a spike when the splash on the power plug occured. This is very easy to see. Check if the display on top drawer is blank.
Nov 04, 2012 | Fisher and Paykel Dishwashers
F1 problem on Fischer and Paykel Dishwasher.
NO POWER TO LOWER DRAWER, CHECK POWER AT BOARD IN LOWER BACK CORNER BEHIND DRAWER,CHECK FOR BROKEN WIRE TO LOWER DRAWER,CAN ALSO BE THERMAL FUSE ON HEATER PLATE,COULD ALSO BE CONTROL BOARD IN LOWER DRAWER.GOOD LUCK there is a drawing taped inside behind the drawer. oops sorry about all caps prideapplianceser@sti.net
Dec 29, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Problems with fischer paykel self cleaning oven
Sounds like Clothes Washing Machine To Me!!--Methinks You have "Posted Incorrectly"--Stay Upright --Des.
Dec 15, 2008 | 2006 Fischer MRX 650
Hi and welcome to FixYA.com!
Here are links to the two most popular Fisher Paykel Wall Ovens:
OD/OS301:
http://www.fisherpaykelparts.net/partmanuals/545619C_Aerotech_UGM_USw1.pdf
OD/OS302:
http://fisherpaykelparts.net/partmanuals/599194C_Aerotech_ugm_USw.pdf
If neither od these is your model, let me know which one you have and I will locate a use and care guide for you.
Hope this helps and Happy Holidays from the FixYa crew!
Dec 15, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fischer and paykell dish washer tablet doesnt melt
if that is a drawer dishwasher ck manual i believe it it says powder only the fp drawer dishwasher doesn't use much water so desn't have a lot of spray force to dissolve tablets
Dec 13, 2008 | Washing Machines
Dishwashers Logo
Top Fisher Dishwashers Experts
Tony Houde
Tony Houde
Alan Matzke
NOEL
NOEL
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
