Question about Hilti TE 7-C 120V Rotary Hammer Drill
How to remove tps2 from hilti hamer drill - Hilti TE 7-C 120V Rotary Hammer Drill
SRF518
  • 232 Answers
SOURCE: grease for hilti te 24
any liquidy grease like lubriplate or milwaukee type Y grease part no. 49-08-5270
Posted on Oct 20, 2009
Testimonial: "thanks doc"
  • 123 Answers
SOURCE: will a Hilti TE 17 to drill 1" holes in sandstone?
The TE 17 is at least 29 years old. It will do up to an inch. However there are no parts available for this tool. Also be carefull if it has a black fill cap on top of the gear housing then it does not have a safety clutch. If it has a red one then it does have a clutch.
Posted on Mar 05, 2010
  • 61 Answers
SOURCE: Cordless Hammer Drill Sfh 151 A 2.0Ah: Hi, How do you change the chuck on the Hilti SF 15...
Hi. open the chuck to the max. inside the chuck you will see a screw. remove it. put the drill in reverse. hold the chuck. a vice may be needed. pull the trigger. this may work, however in my experience, they are very tricky to get off. I have never had a faulty chuck but have had many faulty gearboxes. i have had to buy ney chuck to fit with the new gearboxes because i couldn't get the good chuck of the damaged gear box. good luck.
Posted on Jun 06, 2010
FixYaSteve
  • 57 Answers
SOURCE: how to remove sda cuck from hilti te2 110v drill
Manual for Hilti Te2 is here.
Per Page 11, "Pull the chuck release ring towards the front and remove
the chuck completely. When fitting the chuck, pull the
release ring towards the front and hold it in this position.
Push the chuck onto the guide tube as far as it will
go and release the ring. Rotate the chuck until it engages
and the ring snaps back into its original position |3|. The
TE-C interchangeable chuck or quick-release interchangeable
chuck may be tited to the TE 2-M with chuck
interface |2|."
If this helps, please vote. Thanks!
Posted on Jun 14, 2010
  • 123 Answers
SOURCE: te70 hilti hammer drill
The TE-70 is permantly lubricated. You would only add lubricant if you took the tool apart. You can add a small amount of grease to the end of your bit occasionally before putting in the chuck. This keeps the chuck parts lubed.
Posted on Jul 23, 2010
On this drill , to which side is the slider for the hammer drill. Looking from the top, to left or right ?
Wat voor een merk machine en welk model hebben we het over
Naar links of rechts draaien gaat tegenwoordig vaak met de kantelbare koolborstelhouder aan de achterzijde bij de ventilatiesleuven. anders met een kleine hendel welke onderaan de handgreep zit of een hendeltje boven de schakelaar als het een klopboor betrefd ipv een roterende hamer altijd rechtsom draaiend (altijd dezelfde draairichting gebruiken voor de klopstand net als je een gat kan boren de klopstand is de stand meestal recht bovenop de machine is welke pas als je de machine op een werkstuk zet merkt dat deze in de klopstand functioneert want bij alleen draaien van de machine zonder tegendruk op de boorkop hoor en merk je niets in tegenstelling je dat wel bij een roterende hamer kan horen welke een volkomen ander werkingsprincipe heeft en met een duidelijk hoorbare slagcilinder en slagstuk werkt. een klopboor machine is niet bijzonder geschikt om in echt zwaar beton te boren maar in steen is het afdoende tevens is het niet gebruikelijk om gaten voor te boren in steen wat in metaal wel gebruikelijk is , een roterende hamer is wel geschikt voor beton , maar een roterende hamer is eveneens meestal (uitgezonderd merken als Hilti en Duss )niet gemaakt om langdurig achtereen te gebruiken en vooral niet om langdurig breekwerkzaamheden mee te verichtten. de breekhamer is wel speciaal gemaakt voor langdurige belasting en met name de machines welke op lucht werken.
Apr 13, 2016 | Hammer Drills
Hi i have hilti drill machine i dont how to open and removed the drill bit,please help me
what you need to do is twist the collar of the chuck to remove bit and reverse the procedure to lock it into place.
Aug 03, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
Where can i get genuine spares for this drill from, went off to hilti for brushes & they said beyond economic repair.
I would think that Hilti would sell you the parts if you plan on doing this yourself. These days it seems the way of the world to just throw stuff out and replace with new, its sad but true, I admire you for wanting to fix this. I would do the same thing. just order the parts from Hilti and hope for the best, the worst is you still don't have a hamer drill that works, but at least you will have tried. and that's worth a lot. (personal opinion)
Mar 22, 2011 | Hilti 227949 SFH 151-A 2.0-Ah Drill/Driver
I nide a chuck for a hilti model te 805 chiping hamer
That chuck is not just one piece. If in the U S contact Hilti @ 1 800 879 8000
Jan 20, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
Will the bits from the te-c3x fit my te-17
Yes. New bits will fit old Hilti drills. Old Hilti bits do not fit the new (last 15 years) Hilti drills.
Apr 07, 2010 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
Hilti drill wears the groves of the drill bit to the point where
There may be a problem with the selector switch on the side of the machine. remove it and check for damage
Jan 19, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Grease for hilti te 24
Oct 20, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Gear grease for hilti drill/driver
The genuine hilti grease isnt that easy to get. but I have used a stadard lithium grease in the past without any problems.
Feb 09, 2009 | Hilti 3431126 SF 144-A CPC Drill/Driver
Hilti TE 7-C 120V Rotary Hammer Drill Logo
Top Hilti Drills Experts
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
