Question about Microwave Ovens
Sanyo em g2553
Type of bulb
MicrowaveSvc
  • 9047 Answers
SOURCE: light bulbs failedon my Sanyo
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Aug 18, 2008
fieldy14
  • 456 Answers
SOURCE: replace light bulb on SANYO EM-U1000W Compact
PLESE BEFORE YOU DO ANYTHING RFER TO A GUI HOW TO DISCHARGE A HIGH VOLTAGE CAPACITOR OR SEEK THE HELP OF A MICROWAVE TECHNICIAN. As for changing the bulb, if you remove the case you will be able to locate the bulb, and merely a case or removing ad replacing with a new one. Good luck.
Posted on Nov 16, 2009
sonicboomele
  • 1557 Answers
SOURCE: How to install new light bulb
unlike the older models were there was a small compartment were you could take of a small covering and unscrew / replace the globe they are now a sealed unit if you take the entire top of youl see the globe and black globe holder dont try to unscrew it they dont unscrew if you can order a new globe holder included then simply install as per removal but be carefull microwaves hold a lot of power even when disconnected from power dont touch the capacitor or it will shock you
good luck
please rank me ..
Posted on Jul 04, 2010
HansPP
  • 2510 Answers
SOURCE: Is it possible to replace
Yes, but you will probably have to remove the unit outer cover. Make sure the microwave is unplugged as this is a lethal appliance.
Posted on Jan 16, 2011
Testimonial: "Excellent service, very helpful, thank you"
  • 8909 Answers
SOURCE: How do I fit a
Replacement of the lamp should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The lamp is sat in a housing and its position is adjacent to the vent holes that it shines through.
If you feel confident, disconnect it from the mains power, remove anything in the cavity.
Remove the microwave cover. Purchasing a new replacement lamp will be useful as it will give you an idea of what it looks like. Locate the dead lamp remove the lamp and fit the new one. Replace the covers. Plug it back in and try the lamp by opening the door.
Hope this helps.
Posted on Mar 08, 2011
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
I need a user manual for a Sanyo super showerwave 800w microwave. Model no. EM-G204 There aren't any on manuals online. Thanks Luke.
You can just type "EM-" (without quotes) in the search box at the Sanyo (Panasonic) support site here.
Check a few of the first results to see if they're close enough to help you.
If not, contact them via that page for more help.
Aug 22, 2012 | Microwave Ovens
How to replace light
there is either a panel on back of unit you can remove and light bulb is there, if not you will need to remove case to change bulb.
Nov 25, 2009 | Sanyo EM-S5002W Microwave Oven
Replace light bulb on SANYO EM-U1000W Compact Microwave Oven
Nov 16, 2009 | Sanyo Microwave Ovens
How do i change bulb in sanyo microwave EM-SL30N What do i do must i take the cover off what is the easy way please.
Make sure it is unplugged. Yes you must take the cover off and you will see the bulb. Gain access to it and replace it. Do not interfere with anything else.
Nov 09, 2009 | Sanyo EM-Z2100GS Microwave Oven
Lamp replacement in a sanyo microwave EM-D9553
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Jun 07, 2009 | Microwave Ovens
Changing Microwave bulb
Remove lid, you'll probably need a pozi drive screw driver and a tamper proof torx drive.
The bulb is located near the front.
Mar 15, 2009 | Microwave Ovens
REPLACING LIGHT BULB
i have a cookwork microwave the light stoped working
Sep 16, 2008 | Microwave Ovens
Light bulbs failedon my Sanyo model EM-G653 Can I replace them myself if so where do I purchase replacement bulbs.
Aug 17, 2008 | Sanyo Microwave Ovens
How do I replace the oven lamp in a Sanyo EM-G471?
While your exact manual may not be online, there are several Sanyo manuals here, and one may be close enough to help.
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at http://207.234.249.73/mwd/ge_lamp_replacement.jpg
There may be a panel on the bottom covering the light(s), too.
Once your over the range type is out of the wall, or if yours is a counter top model, the outer cover (wrapper) will need to be removed.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 27, 2008 | Sanyo Microwave Ovens
Microwave Ovens Logo
22 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
