Question about Lands Phones
Binatone instruction manual 1001342
Need to reprogramming speed dial buttons
dahaka
  • 347 Answers
SOURCE: reprogramming speed dial on old Nitsuko phone
Helo libbyc,
What is the model of your Nitsuko phone?
Posted on Jul 25, 2008
SOURCE: lost instruction manual for uniden
i NEED TO KNOW HOW TO PROGRAM THE TIME AND DATE.
Posted on Oct 14, 2008
  • 68 Answers
SOURCE: need manual
Given that consumer telephones are inexpensive, the cost of repairing the speaker phone on the 960 (assuming you still have it) is probably not worth it.
Going off of my memory....to program a speed dial you would first press "Program", enter the telephone number you want stored and then press the one of the memory buttons to save the number to. If the number is to be saved on a lower memory position press "Lower" before you press the memory button.
AT&T's telephone product website has a section where user manuals for many AT&T and Lucent branded telephones.
http://telephones.att.com/telephones_ui/support/dsp_manuals_list.cfm
The 960 is no longer listed, but the many of the basic functions are similar to the 922.
Posted on Oct 29, 2008
SOURCE: How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Posted on Feb 05, 2009
  • 5 Answers
SOURCE: I can't change the speed dial numbers on my phone
You should only have to hit Feature - Redial and then select the soft key that you wish to re-program. Typically you will then type 1 and then the extension you want to program.
Posted on Aug 11, 2009
My binatone phone number q1009044638g is diverting calls and i can not get a dialing tone.how do ifix it
that isn't a model number, but a serial number.
Google
make model manual
or visit the Binatone website. In the manual look for Call Forwarding and how to turn off the feature.
There are some manuals here
http://www.manualslib.com/brand/binatone
Aug 18, 2016 | Binatone Lands Phones
When I first got this phone I could speed dial I guess I need to reprogram it? How?
I found the manual, so you can look up what you think speed dial is. The manual does not mention that option.
http://www.payphone.com/shop/instructions/VT-CS6219-2.pdf
Apr 19, 2015 | Vtech CS62192 Cordless Phone
I need instruction manual to program speed dial
I was unable to locate a user manual for that particular device, however the basic instructions for programming speed dial functions are normally very similar between most phones.
Generally there are ONE TOUCH Speed Dial buttons labelled something like M1, M2, and M3 on the dial pad somewhere.
There should also be another button labelled PROG or STORE on the keypad as well.
Normally to program a number into a ONE TOUCH speed dial memory location you carry out the following procedure:
Lift the handset.
Then press the PROG (or STORE) button.
Now just use the number keypad to dial the full telephone number that you want to store in a Speed Dial location.
Once the full telephone number is dialed, then push the M1 button to store that phone number in the M1 One Touch Speed Dial location.
The phone may or may not show some kind of confirmation that the M1 location was just programmed, then just hang up the handset.
Now when you lift the handset and press the M1 button, the phone should automatically dial the phone number you programmed into it.
Now just repeat the same process for the M2 and M3 One Touch Speed Dial buttons with other phone numbers if necessary.
To change one of the Speed Dial numbers, just carry out the normal programming procedure for that location using the new phone number and the old number will simply be overwritten.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Dec 02, 2011 | Southwestern Bell FM-480 Corded Phone
I need instructions for the binatone 510
I understand that the manual for the Binatone e3250 also covers operation of the Big Button 510. You can download the e3250 manual from
www.binatoneonline.com/manual.aspx
I hope this will help you.
Sep 01, 2009 | BellSouth GH5816 Cordless Phone
Jul 06, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
How do i reprogram model ge 2-9267a
pull out the plastic tab that holds the piece of paper with the names of the people you speed dial. the instructions are under there.  pick up handset - ignore dial tone or dial tone going away - press "memory store" button - dial the number - press one of the eight buttons for location - hang up phone. that's it - your new number overwrites any old number that was in there. (then write the name of person on the piece of paper.)
Apr 18, 2009 | GE Lands Phones
Problem with speed dial buttons
to program a speed dial button - <feature> *1 - select button / enter speed dial number / quit....you may have to reprogram each button.
Feb 23, 2009 | NorStar M7324 Telephone
Speed dial instructions
make sure phone is off not in talk mode- then press the memory buton-press desired number 1-9-press memory button again,the display shows enter name -press memory button to save the name.then the display shows enter number-enter the number then press memory again and you will hear a tone that confirms
Oct 05, 2007 | Uniden Cordless Phone
How do I reprogram the numbers on speed dial ? and or add them or delete them?
Canon left me on hold for 30 minutes then told me this wasn't their problem and I should call my dealer for service.  I'll try that now.  Nope - they didn't know either.
Eureka!  Lift the panel that covers the speed dial buttons and push the button labeled "data registration".  Using the arrow buttons find the speed dial info and figure it out from there.  Good luck!
Jan 19, 2007 | Canon LaserClass 2050 Plain Paper Fax
Lands Phones Logo
462 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
