Question about Samsung Refrigerators
Removing interior light from a Samsung RB31FDRNDSA/EU 60cm No Frost Fridge Freezer
Want to replace light in samsung fridge freezer - don't know how to remove cover
  • 3 Answers
SOURCE: Problems with my samsung fridge/freezer SR-L36/SR-L39
is whisker growth like ***** hairs?
Posted on Jun 04, 2008
SOURCE: Samsung SR-L39 fridge freezer switching off
tarsia upatvane
Posted on Aug 30, 2008
  • 1462 Answers
SOURCE: removing doors from a samsung rsg 5 dumh american fridge freezer
doors are removable. wiring to the door is plug and socket
Posted on Oct 15, 2008
SOURCE: liebherr frost free fridge/freezer
Try these solutions in these order:
1. Switch off the fridge and leave the door open overnight. Switch it back on in the morning.
Explanation: The sensor inside the fridge gets frozen and cannot control the temperature properly.
2. Switch off the fridge. Unplug it. At the back of the fridge (behind the unit, not inside) there is a large grid. Clean it with a hoover thoroughly. Open the fridge. Dry the back of the fridge if wet (inside the fridge). If frosted wait for it to defrost and then dry it. Plug in the fridge. Switch the fridge back on. This one worked for me.
Explanation: The dust in the grid deprives the fridge from cooling down and the unit can't control the temperature in the fridge section.
3. Switch off the fridge. -Unplug it. Empty it. Turn it upside down. Plug it in. Switch it on for 24 hours. Switch it off. Unplug, return to normal and switch on.
Explanation: This has to do with the pressure of the gas inside the compressor. I have not tried it but this advice as given to me by a qualified electrician when I commented the (in)famous F2 problem in Liebherr fridge/freezers.
Hope it helps. Regards. Albert
Posted on Jan 04, 2009
SolutionGuy
  • 331 Answers
SOURCE: Frost in frostless freezer, fan not blowing into warm fridge
There are 2 things that cause these to not defrost. Kinda like the "Achilles heel" of GE fridges. The first one is the Defrost heater itself. And the second is the evaporator thermister (GE calls it a "sensor"). They are both very easy to replace. The part numbers are; WR51X10101 (heater) and WR55X10025 (sensor). If you don't have a local appliance parts retailer, just plug those numbers into a search engine. I highly recommend getting both parts because if the sensor hasn't failed yet, it will. The same goes for the heater...
Now for the fun stuff... Turn the temp knobs all the way counter clockwise to kill power to the fridge. Unload all the food from the freezer and remove all the shelves and the basket. Remove the screws that are holding the evap panel (the flat panel on the back wall, it's about 2 1/2 ft tall). Remove the panel to expose the evaporator. You'll see the heater at the very bottom of the evap connected by 2 screws, remove these and pull the heater out. Your new heater comes with instructions on how to install it.
After you have done that, look at the top of the evap. On the left, you'll see a little white sensor clipped to one of the evap tubes (shiny little clip), that has 2 wires feeding it. Remember which tube it's clipped to then unclip the sensor and pull it toward you. Snip the wires right at the base of the old sensor and completely remove it (leave the wires in there). Now separate those 2 wires and strip about 3/8" of insulation off. At this point, you are ready to follow the instructions that came with your new "sensor". Oh! and if it's all frosted up on the evap? Take this time (before you re-install the panel) to use a blow dryer and melt it away. All that'll be left to do is rebuild it.
There ya go! Job completion time= ~45 minutes. Easy breezy, right?
If this has been helpful, please don't forget to rate my solution. Thanks!
SG
Posted on Apr 05, 2009
Freezer not freezing, moves from 8 degrees to 34 degrees. Fridge keeps constant 40. Someone said it was frost temp sensor? Cant even get into interior back pannel to replace now I have the part.
There are 2 thermistors for frost and 2 for temperature....Fridge and freezer compartment have one each.
Access to the thermistor sensors are from the inside of the fridge and freezer. You have to remove the shelves, trays and the inside panels to get at them.
The manual will show you how.
There are diagnostics you can run that will tell you which one is in trouble.
There are sensitive voltages that may be required to measure. So from a tech point of view you may need someone with electronics expertise to do the measurements.
The procedures and various measurements are too lengthy to tell you but I will give you the link to the service manual PDF and you or someone can do the diagnostics...The Manual is 87 pages long. Can you imagine a fridge needing that much documentation.
That said. I have the same fridge and have fought 3 different problems...not fun....
here's the link...
http://www.ajmadison.com/ajmadison/itemdocs/DA68-01778A-EN.pdf
Make sure you unplug the fridge before you go taking things apart...
Good luck
Maytag owns Samsung
Dec 29, 2009 | Samsung RB215LASH
My samsung is cold at the bottom of the fridge and warm at the top
Im assuming you mean the freezer is cold but the fridge is not . Most of the time these auto defrost fridges require a internal evaporator fan to draw the frost from the freezer to the fridge compartment. If the fan is stuck, it will not be able to transfer this frost. Before any major strip down, suggest you defrost fridge unit for approx 12 hours and start again. 90% of the time this will correct the problem. Almost certainly door was left open accidently for a period which resulted in this. Please let me know if not the answere.
Sep 24, 2009 | Samsung Refrigerators
Frost build up behind/inside back freezer panel
I have same problem, it usually happens after someone leaves door open too long or after 4-6 months. I usually place two frozen milk jugs full of water in the upper fridge and tape the upper fridge door closed at night before bed so the kids don't open and let the upper food get warm., Unplug the fridge and open the freezer and remove all drawers (place excess frozen food in freezer in garage) , leaving the freezer open with a towel in the bottom to catch the melting water from the back panels inside and the next morning wipe the fridge bottom clean and plug it back up and replace everything. I hate that I paid so much for this fridge and have to defrost a couple times a year. However found out too late to return back to the store. It seams like it should have a cycle that heats the back plate every so often to warm and evaporate the ice that collects, but I haven't heard or can't find anything on that.
Kimsukie.
Jun 16, 2009 | Samsung RB215LASH
Samsung fridge freezer
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 30, 2008 | Samsung Refrigerators
hey gordon is this model 4 drawer electronic control with the display in the ice door
Feb 16, 2008 | Refrigerators
Fridge running but not staying cold
you have a defrost problem, if SxS ref. most likely bad defrost heaters. They are behind interior back wall. Sounds like you have a GE.
Jan 05, 2008 | Refrigerators
Refrigerators Logo
32 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
