Question about Excel (SS8SATAS5128400R)
Nested IF functions in excel
I am writing a formula that can calculate a persons payable tax based on different tax brackets. I have so far:=IF(C6>6000,0.15%*(C6-6000),0) where C6 is the persons gross income and 6000-30000 is the first tax bracket the first part seems to work but when i add the second part:=IF(C6>6000,0.15%*(C6-6000),0),(IF(C6>30000,0.3%*(C6-30000))) ireceive an error message where am i going wrong?
  • ppproduction Oct 29, 2007
    10 bucks US for that I want my money back and I thought false values for If statements were optional
    Brigadier General:
  • 6,966 Answers
Your first IF condition is “=IF(C6>6000,0.15%*(C6-6000),0)”
Where:
C6>6000 is your logical condition
0.15%*(C6-6000) would be the value if your logical condition is TRUE, and
0 would be the value if your logical condition is FALSE.
Your 2nd IF condition is “(IF(C6>30000,0.3%*(C6-30000)))”
Where:
C6>30000 is your logical condition
0.3%*(C6-30000) would be the value if your logical condition is TRUE, and
? would be the value if your logical condition is FALSE.
You are missing the value if it is FALSE.
Hope this be of some help/idea. Post back how things turns up or should you need additional information.
Good luck and kind regards.
Posted on Oct 26, 2007
  • Louie  Role
    Louie Role Oct 30, 2007
    Your query was "where am i going wrong?" and the response given was "You are missing the value if it is FALSE." based on the assumption that what you intend for the IF function to determine is the next value or condition (next tax bracket) and the alternate if not met.
    Alternately, should you simply want the cell/result to state that C6 is not within the condition/bracket you specified, the formula should be:
    =IF(C6>6000,0.15%*(C6-6000),0)=(IF(C6>30000,0.3%*(C6-30000)))
    which will display "FALSE" if the condition of TRUE is not met.
    Perhaps to better set your mathematical arguments right, you may want to replace the initial value of "0" and instead use a condition/formula that leads to another condition/formula if the initial condition is not met.
    To be of further assistance, pls provide the tax brackets and with what % that you intend to use as well as different values for the
    persons gross income, say about 5 of them.
    With respect to the "
    10 bucks US for that I want my money back", may I suggest that you take that issue with the admin of the site since I have no control over that.
SOURCE:
I need a formula to calculate sales tax. the tax caps at $300 dollars.
=IF((A1*7.5%) > 300, 300, A1*7.5%)
  • IF Sales Amount * Tax Rate is greate than $300 then make it $300 no matter what the value is.
  • IF Sales Amount * Tax Rate is less than $300 then make it the value of Sales Amount * Tax Rate.
Sep 29, 2015 | Microsoft Office Excel 2003 for PC
What taxes, if any, are included within a pro forma?
A pro-forma would usually include all the taxes that are payable by the vendor on behalf of the buyer. These are usually state sales taxes, or in some countries, may appear as a value-added tax (VAT) or goods & services tax (GST) applied as a percent markup of the transaction. The taxes included in a pro-forma should be those that apply to the transaction being taxed.
Is it a good? A service? A commodity, a major asset? Are there other fees & charges levied by local government that do not attract sales taxes?
The answer is:
It depends on what you are taxing, and in whose jurisdiction you are levying the tax and what rules apply to the calculation of the tax. Familiarise yourself with your applicable tax legislation.
Aug 31, 2014 | Microsoft Excel for PC
What are the formulas in grading the grades uisng microsoft excel
Formulas are used to specify calculations based on values in designated cells. Excel supports basic calculations as well as statistical, trigonometric and other specialized functions.
Formulas used in Excel must follow a certain syntax.
  1. All formulas begin with an equals sign (=).
  2. Some formulas use operands such as +,-, *,/ for addition, subtraction, multiplication or division.
    For example, the formula =A1+A2+A3 would add the contents of cells A1, A2 and A3.
  3. Other formulas refer to different functions such as SUM, AVERAGE and others.
    For example, the formula =SUM(A1:A3) would add the contents for the range A1 through A3.
  4. Formulas can be combined with operands.
    For example, the formula =10*SUM(A1:A3) would add the contents cells A1 through A3 and multiply them by 10.
  5. Functions can be nested within each other.
    For example, the formula =SQRT(10*SUM(A1:A3)) would take the square root of ten times the sum of cells A1 through A3. When functions are nested, it is important that the number of left parentheses match the number of right parentheses.
Aug 19, 2011 | Microsoft EXCEL 2004 for Mac
How to calculate the percentage using the excel
Hide All
Percentages are calculated by using the following equation:
amount/total = percentage
Where percentage is in decimal format.
What do you want to do?
Calculate the amount if you know the total and percentage For example, if you purchase a computer for $800 and there is an 8.9% sales tax, how much do you have to pay for the sales tax? In this example, you want to find 8.9% of 800.
Example The example may be easier to understand if you copy it to a blank worksheet.
  1. Create a blank workbook or worksheet.
  2. Select the example in the Help topic. Note Do not select the row or column headers.
    Selecting an example from Help
  3. Press CTRL+C.
  4. In the worksheet, select cell A1, and press CTRL+V.
  5. To switch between viewing the results and viewing the formulas that return the results, press CTRL+` (grave accent), or on the Formulas tab, in the Formula Auditing group, click the Show Formulas button.
1 2 A B Purchase price Sales tax (in decimal form) 800 0.089 Formula Description (Result) =A2*B2 Multiplies 800 by 0.089 to find the amount of sales tax to pay ($71.20) Note To convert a number in percentage format to a decimal, divide it by 100. For example, the sales tax in this example (8.9) divided by 100 is .089.
Calculate the percentage if you know the total and amount For example, if you score 42 points correctly out of 50, what is the percentage of correct answers?
  3. Press CTRL+C.
Simple way Amount/Total*100
Apr 30, 2011 | Computers & Internet
I need help with a change of base formula problem.
It's simple here some logs:
log x base y = log x / log y
log (x*y) = log x + log y
log (x/y) = log x - log y
you just need to know that the default base of log in calculators is 10, so log x mean
log x base 10 = log x / log 10,
so write log x / log y for log x base y example:
log 8 base 2 = log 8 / log 2 that is how you write it on calculator, hope it was helpful
Jul 01, 2009 | Texas Instruments TI-83 Plus Calculator
Formula for calculating the days beween months
for example, cell A1 has date (01-01-2008) and cell A2 has current date (08-24-2008) and cell A3 shows total days, is that you want to know? if yes, apply formula as under...
cell A3......(properties set as General to show digits)................ =SUM(A2-A1)
Aug 25, 2008 | Microsoft Office Professional 2007:...
Multiple arguments in excel
Okay, here's a possible solution--based on my interpretation of your problem.
Suppose you have some value in cell B1, and the month (either Jan, Feb, or Mar) is stored in cell A1. The formula in C1, which performs calculations based on which month appears in A1, is as follows:
=IF(A1="Jan",B1*0.25,IF(A1="Feb",B1*0.3,IF(A1="Mar",B1*0.4)))
In this example, the value in B1 is multiplied by .25 if the month is Jan, by .3 if it's Feb, and .4 if it's Mar.
Nov 09, 2007 | Computers & Internet
Excel argument
If I understand correctly, you want to figure the normal wages at 40 hours and less. If there is more then 40 hours, calculate the normal 40 hours, then calculate the hours overtime (time and a half) and add them to get a total.
B5 columns are filled with this:
=IF(A5>$B$1,($B$2*$B$1)+((A5-$B$1)*($B$3)),A5*$B$2)
NOTE: The $ sign doesn't refer to money, it refers to an absolute reference so when copying a formula, the cell references with a $ sign are fixed and don't adjust according to the relative position to where it's being pasted.
Please rate as FixYa! or ask please clarify. ThankYa!
Oct 22, 2007 | Microsoft Excel 2003 (06503995)
Computers & Internet Logo
176 people viewed this question
Top Excel Computers & Internet Experts
Alexey Krenvalk
Alexey Krenvalk
Marvin
Marvin
Are you an Excel Computer and Internet Expert? Answer questions, earn points and help others
