Staples mailmate mailmate turns on but won't accept any paper in the shredder
5 Suggested Answers
  • 6 Answers
SOURCE: mailmate by staples shredder won't turn on
I took my mailmate out into the driveway. got in my truck and ran over it two or three times. it doesn't work any better but I feel great.
Posted on Mar 10, 2009
SOURCE: No power to Staples mailmate
There is a 10mm 5amp @ 250v fuse on the main board that is probally blown . I unsoldered mine and soldered a pigtail fuse holder with a convient sized 5 amp fuse inside in its place . The shredder is not too bad to take apart , the head comes apart from the body of the shredder .Turn it upside down and you will see 6 or 7 phillips screws .Once these are removed the head assembly opens up and you will see the circuit board which is held in place by 2 phillips screws. A quick ohm meter test will reveal the fuse condition. It was an easy fix just MAKE SURE YOU KEEP THE UNIT UNPOWERED while you work on it or its unassembled.
Posted on Jul 18, 2009
JayBlair
  • 328 Answers
SOURCE: cant find standby operation
All shredders shut down within afew seconds if they do not detect paper inserted. Safety feature.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Jul 22, 2009
  • 3230 Answers
SOURCE: Staples Mailmate Shredder do not
First of all you try plunging them in to other power board, check the cable and the plug (check if the cable or plug not getting shorted), make sure the circuit breaker for the shredder outlet is on.
tell me is there any humming noise? or any sign of power getting in to it?
Please post back further comments for more information...
Thanks
Posted on Sep 07, 2009
Shredder is jammed
Disassemble it enough top expose the shredding mechanism, then remove all material that is jamming it.
May 27, 2016 | Staples M5 Mailmate Shredder
Mailmate by staples shredder won't shred
drive is seized-remove power cord- open cover rotate cutting drum slowly using motor drive gears - look for debris/gear teeth missing
Mar 02, 2014 | Office Equipment & Supplies
Constantly runs when on auto and won't accept paper
Shut off power and turn the shredder upside down. It is highly likely you will find shredded paper jammed in the mechanism, especially near the center where the feed sensor is located. A thorough cleaning should get your shredder operating again
Feb 02, 2013 | Staples SPL638X (CrossCut) Shredder
Jam
Having the same Problem!
Jan 23, 2013 | Staples M5 Mailmate Shredder
Staples mailmate shredder bin won't open
The bin may be overfilled, preventing the latch from releasing.
Mar 28, 2012 | Office Equipment & Supplies
Cant find standby operation
Jul 22, 2009 | Office Equipment & Supplies
Jun 24, 2009 | Office Equipment & Supplies
Mailmate by staples shredder won't turn on
Oct 25, 2008 | Office Equipment & Supplies
My mailmate shredder from Staples has jammed and I can't figure out how to unjam it.
unfortunately you will have to do it by hand!!!!!!!!
unplug, get a flat head screwdriver, take off top and turn upside down. you will see a lot of sredded paper where the teeth are, you need to clear all of that.
it may also be that you have a stale or something of that nature blocking the teeth.
Also do a reverse, I did one over the weekend and had to do it several times while cleaning it out, very messy so make sure you do it somewhere that you can easily clean up, also don't forget you are supposed to use a special lube paper once in a while. (Office Depot,/Max/Staples
Aug 24, 2008 | Office Equipment & Supplies
23 people viewed this question
k24674
jasbo
jasbo
