Question about Duraflame Heating & Cooling
External thermometer - Duraflame Heating & Cooling
Hot tub reads 104 but doesn't feel like it
use an external thermometer to verify the temperature. if it is not the same reading, you may need to replace the temperature sensor.
Mar 31, 2017 | Pool & Spa
31215 Wireless Outdoor Thermometer manual
With mine, the battery in the weather station has to be changed twice as often as the one in the external unit. Even though the display on the home unit is visible, it doesn't have enough power to pick up the signal from the outside sensor.
I am not familiar with yours, mine is national Geographic.
The reviews on yours are very mixed, but lots of questions are answered.
Amazon com Weather Station with Wireless Outdoor Thermometer 31215 Home...
Jul 24, 2016 | Measuring Tools & Sensors
Best thermostat settings
Hi Elliott
Thats a personal thing....
Having an external digital thermometer helps!
It's a compromise between saving on electricity costs
and being cool
Cheers
http://romnini.com/2014/10/18
Jul 08, 2015 | Emerson Quiet Kool 10GV13 Air Conditioner
How to calibrate oven?
ovens are pre-calibrated by the thermostat and the resistance in the oven control switch
Apr 25, 2015 | Kenmore Kitchen Ranges
Ice maker doesn't produce ice
But a external thermometer and tell me what the temp is in the freezer. Post back youe results.
Oct 11, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
The temp control tops out at 390. The oil doesn't get hot enough to make french fries
You need a good external thermometer to check your oil temp.
Everything fries at 350-375 degrees.
Any hotter and the oil burns.
Oct 27, 2010 | GE Kitchen Appliances - Others
Will not heat up past 375
propane or electric? Are you going by the thermometer on the grill or using a external one?
Sep 06, 2009 | Weber Genesis Silver A Grill
98 328IS OVERHEATING AFTER CHANGING THERMOSTAT
Are you putting the thermostat in correctly? It it will not work backwards.
And to confirm that there isn't a different problem, take the thermostat out all together and see if it overheats.
Engine not fully warming up is not usually caused by the thermostat. Stats usually fail closed, not open.
You will want to check the water temperature sending unit or gauge after verify the water temperature with an external calibrated thermometer. You can attach and insulate the external thermometer to the housing where thermostat is located.
Reply back what you figure out. I will be happy to help you further.
Feb 03, 2009 | 1997 BMW 328
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Heating & Cooling Logo
Top Duraflame Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Duraflame Heating and Cooling Expert? Answer questions, earn points and help others
