Question about Minolta XG-A 35mm SLR Camera
Shutter does not work - Minolta XG-A 35mm SLR Camera
My Nikon coolpix l820 the screen doesn't work on camera setting but does on the video camera setting
hi,
when the still camera works the shutter of the aperture and iris is opening for a limited time, if it opens without limit the excess light will enter in and the result will be blurry picture, if the shutter is not opening the picture will be dark. in movie mode the shutter will be always in opened state, so I think there may be fault in shutter.
in some cases a slight jerk giving to cam when you depressing the snap button will reset the shutter and will work normally.
Nov 24, 2015 | Nikon COOLPIX Cameras
Nikon F4 - shutter replacement
Hi Miguel,
It would be better to send it to Nikon. For mere mortals swapping shutters may very much mess up the camera beyond repair. If you truly love the F4 have Nikon do the work and at the same time have them do a CLA as well.
Cordially,
May 10, 2013 | Nikon F4s 35mm SLR Camera
N65 shutter button failure
Follow this link: Nikon N65 Camera Body 35mm SLR. You can buy a working replacement body for $19.99. A camera repair man will charge you three to five times the replacement cost.
Jul 04, 2012 | Nikon N65 35mm SLR Camera
Shutter does not operate.
hiwhen you say shutter does not operate, it mean too general to answer. could you provide more detail?I will give how does shutter work. First, you press shutter button, it will activate two switchs (one is focus and meter and the other is release ) Second, mirror goes up and opening shutter curtain move up. Third, closing shutter curtain down and mirror down and picture come out. Of course there is also aperture control unit sequence.
Jun 04, 2011 | Nikon D40x Digital Camera
Film was in camera, frame 18. Batteries had failed at frame 17, had to depress "B Lock" button" and set shutter to 60 to release shutter. Replaced batteries with fresh batteries, battery...
This camera is somewhere between fifteen and thirty years old. It is highly unlikely that spares would be available, and it would be extremely expensive to have it repaired in any case, most artificers familiar with the internal layout having probably retired years ago. Maybe the camera should be retired too ?
Apr 16, 2017 | Olympus OM-4TI 35mm SLR Camera
Shutter wont close
Try setting the shutter to B and see if you can trip the shutter. If no go then it has mechanical problem. If it works on B but not on other shutter speeds, you have electronic problems.
May 16, 2010 | Pentax Program Plus 35mm SLR Camera
Shutter button flew off on Christmas day. Luckily was indoors. Found the spring and button, cellotaped together and worked fine until yesterday whilst taking photos, the shutter button suddenly stopped...
shutter mechanism inside may not be in contact with the actual shutter button...or shutter mechanism might have failed altogether.this one's definitely recommended for repair.
Apr 16, 2010 | Sony Cyber-shot DSC-H5 Digital Camera
OLYMPUS MJU-760 CAMERA SHUTTER IS NOT WORKING,IT IS OPEN
A) Please refrain from shouting, it is considered aggressive and impolite.
B) This will need professional attention, which will probably be more expensive than purchasing a replacement camera.
Jul 15, 2017 | Cameras
Shutter stopped working
If the metering lights go out when you press the shutter release fully down, then the camera needs the shutter capacitors replaced. If they stay on, it could be the release magnets on the shutter unit itself, or worse.
Aug 12, 2008 | Minolta Photography
Lower half of photos dadrk when printed
Set camera to B , open back door and release the shutter and keep it open while you inspect focal plain area. Is the shutter fully opened ? If you release again is the shutter opening completely and closing completely ? While the shutter is fully opened on B look through the shutter/ mirror box area is anything obstracting your view ? Seems like one of the shutter curtains is not opening properly and shutter will need servicing. Please note that it may not be economical to repair : $ 150-200 if the shutter block does not have to be replaced completely.
Apr 22, 2007 | Minolta Maxxum HTsi Plus 35mm SLR Camera
Minolta XG-A 35mm SLR Camera Logo
23 people viewed this question
Top Minolta Photography Experts
Greg Cann
Greg Cann
TC CAMERA REPAIR.Com...
Are you a Minolta Photography Expert? Answer questions, earn points and help others
