Question about Lexmark E250dn Laser Printer
Photoconductor says exhausted - Lexmark E250dn Laser Printer
What does PC Life Warning mean?
You get the PC life warning when the photoconductor kit is near exhaustion. You have to prepare are replacement.
Please click on the link below to get instructions on how to reset pc count. Whenever you install a new photoconductor unit, you must also reset the page count on the printer.
http://bitly.com/rgOZIm
Aug 02, 2011 | Lexmark X364dn All-In-One Laser Printer
Hi yes i have a Lanier LD015f. I just received the photoconductor. Hoow do you replace it?.
Hi, you should have received instructions with the photoconductor, but replacing it is pretty straightforward.
To remove the old photoconductor:
- Open the front door and the right side door. - Remove the toner hopper. - Unplug the connector going from the photoconductor into the machine. - Pull out the photoconductor.
To install the new photoconductor:
- Remove all of the tape, paper, and packing materials. - Slide the photoconductor into the slot left empty by the old one. - Attach the connector and route it behind the plastic guide. - Reinstall the toner hopper. - Close the right side door and front door.
If the machine was on when you replaced the photoconductor, it should automatically detect the new one.
Dec 01, 2010 | Lanier UNKNOWN
It show 84 replace photoconductor
84 replace photoconductor on the display indicates that the photoconductor has reached its expected life rating. You may continue to print but will be at risk for developing print quality issues. It is recommended that photoconductor unit be replaced. After replacing a photoconductor unit, you will also need to manually reset the PC counter, Thanks
Sep 22, 2010 | Lexmark Lemark E352DN Laser Printer
We are receiving the error message "84 oc life exhausted". What can we do to solve?
84 PC Life Exhausted indicates that the photoconductor unit has reached its functional life. The photoconductor kit will need to be replaced. The printer will not function so long as the Exhausted message remains on the display. The only way to clear the message is to install a new photoconductor. After replacing the photoconductor unit, you need to manually reset the pc page counter as well. Thank you for choosing Lexmark.
Sep 01, 2010 | Lexmark Optra SC 1275 Laser Printer
How do I install a Lexmark E352DN Photoconductor
Here's an article on How to Change the Photoconductor Unit/Kit on a Lexmark E250d(n), E350d, E352dn, or E450dn Printer. Just click on this link: http://bit.ly/aykTXL. This should give you an idea on how to install the photoconductor unit in the Lexmark E352dn printer.
NOTE: If you are replacing your old photoconductor unit with a new one, after installing it you will need to reset the photoconductor counter as well.
Aug 12, 2010 | Lexmark E 352dn Mono Laser Printer
Photoconductor trouble
You will need to get the photoconductor unit replaced.
You can get detailed information about the same from:
ftp://download.epson-europe.com/pub/download/205/epson20540eu.pdf
Sep 11, 2009 | Epson Aculaser C1100 Printer
E511 error code
  1. Check of Photoconductor Unit attachment. Re-attach Photoconductor Unit.
  2. Is the Drum of Photoconductor Unit rotating?
  3. Remove Photoconductor Unit. Turn gear of Photoconductor Unit until silver seal attached to Belt can be seen.Is silver seal dirty?
  4. Remove Photoconductor Unit. Is SENSOR TR-0 attached securely?
  5. Remove Photoconductor Unit. Are there any dirt or foreign bodies on the SENSOR TR-0 surface?
  6. Does the error recur when the power is turned ON?
  7. Remove Photoconductor Unit. The voltage of P416-2 ↔ P416-3 on PWBA MCU is 5 VDC when silver paper or other reflective object comes close to the sensing area of SENSOR TR-0, and is 0 VDC when the object is released?
  8. The voltage of P416-1 ↔ P416-3 on PWBA MCU is 5 VDC?
  9. Disconnect the P/J416 from PWBA MCU. Do all of the wiring below have normal continuity?
  10. Replace MOTOR ASSY P/R.
Jun 19, 2009 | Epson Aculaser C1100 Printer
How do i reset a new photoconductor in lexmark e450dn.
According to Lexmark E450DN service manual;
1. Turn off the printer.
2. Press and hold Checkmark and Right Arrow buttons.
3. Turn on the printer.
4. Release the buttons when 'Performing Self Test' displays.
The message CONFIG MENU displays on top line of operator panel.
5. Scroll down and select 'Reset PC Cnt.'
Sep 25, 2008 | Lexmark Office Equipment & Supplies
Solution to epson c1100 error message
Turn printer off and remove photoconductor unit, close covers and turn printer back on without photoconductor, error will appear that you need to install photoconductor, install photoconductor and wait til it calibrates, if same error appears photoconductor is a consumable part you will have to replace it then.
Pls dnt 4get to rate solution. TY
Mar 18, 2008 | Epson Aculaser C1100 Printer
Lexmark printer error at power up
pc stands for photoconductor or print cartridge or in layman's term toner
the toner has reached its expected life or toner has ran out
Oct 03, 2007 | Lexmark Optra SC 1275 Laser Printer
Lexmark E250dn Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
