Question about dr. Tech Solar Transmitter Wireless Weather Station WA-1070T
Wind speed not working - dr. Tech Solar Transmitter Wireless Weather Station WA-1070T
Why does my wind speed not work
put a new battery in the wind generator outdoors .
Oct 08, 2015 | Celestron Deluxe Weather Station
Tip
How to replace a run capacitor
A Run capacitor has 2 terminals, they go to the Run and Start winding terminals, in this case the Line 2 leg of power is wired to the Run terminal on the run capacitor, that is due to the fact this is a single speed motor and speeds are on the Run winding, had there been 2 speeds, the Line 2 leg of power could not be wired to the Run capacitor but would be going to the High or Low speed terminals, conversely the Run terminal on the compressor can accept only 1 lead.
All electric motors get 1 leg of power directly to the Common lead, the remaining leg of power Always goes to the Run winding or speeds on the run winding if a multispeed motor.
Some compressors have a shared capacitor with 3 terminals, they share the leg of power to their Run windings however to Hermetic it will be say 30 MFD and to Fan it will be say 5 MFD, but as to capacitor theory they get Run and Start Always
Power can be wired to Run on the capacitor as long as the motor is a single speed.
But power ALWAYS goes to Common directly while the remaining leg of power goes to the Run winding or Speeds on the Run winding as in High and Low speeds.
on Oct 14, 2013 | GE 1 Pcs. Of 50uf 370v Ac Motor Run...
The top speed of a small plane is 180mph, in still air. One windy day, the plane flew 100 miles into the wind at top speed, in the same length of time it took to fly 135 miles with the wind, at top speed....
Suppose the length of time taken is T and the wind speed is W. Also we will assume that the ground speed of the plane is exactly its top speed plus or minus the wind speed, with no losses anywhere. So
(180 - W) * T = 100
(180 + W) * T = 135
180T - WT = 100
180T +WT = 135
Add these 2 equations together
360T = 235 so T = 0.653 hrs or 39.17 min
Now subtract equation 1 from equation 2
2WT = 35 This is the equation you ask for in your question
W = 35 / 2 / 0.653 or 26.8 mph
Check this
(180 - 26.8) * 0.653 = 100 OK
Nov 12, 2014 | Office Equipment & Supplies
My fan motor is not working totaly
PROBLEM; My fan motor is not working totally!
So, i guess that your fan motor is working partially
because it is not working totally.
Please try to be more vague, if you posibably can be.
You will loose 10 points if you actually give any one an idea of what could be wrong with your fan.---ha-ha! sorry,it just seemed too funny to me.
Sounds like:----option #1------- your fan motor is either not running at proscribed speed (fer instance, high is not high enough or low is too low.) This is usually caused by lack of oil on the fan motor bearings.,easy to oil the bearings & dirt cheap too.
but could be caused by an almost burnt out fan motor.In that casethe Motor is not fixable, & needs 2 -B replaced, but dont bother to. It is cheaper to buy another fan at wal marts.
option #2
that portions of the 2 speed or 3 speed selector switch are not totally making contact.
or --option # 3, one of your motor windings could be burnt open.
So,let me start with --#3-- the worst case senarieo
Diagnostic proceedure for Dr. Fixit
You need to supply 120 volts ac in turn to winding lead #1, then to winding lead #2 and then to winding lead #3----
There are 4 wires on a 3 position fan speed switch.
1 wire for low speed,1 wire for medium speed and 1 wire for high speed. This looks like the letter Y with each leg of the Y
[ around the outside of the Y ] being one speed winding. THe neutral return wire would hook up to the center of the Y and this would give you your 3 circuits, depending on which outside leg
that the speed selector switch selects. lo,med or hi--- the neutral return wire at the center of the Y will compleate the circuit, one winding at a time ,depending on speed selector switch setting, for all 3 speeds.
All 3 speed windings need to work for the fan motor to work totally.
If one speed winding is burnt open, the fan motor will only work partially, 2/3rds ,that is. You can still use the fan by cutting off the lead of the bad speed winding and using the other 2 windings.
If 2 wings are bad and dont run, the fan will still work partially with only 1 speed.
If you have no-- or intermittant contact on your fan speed switch,
you will have to order a new replacement switch. This is assume-ing that all 3 speed windings worked properly at their respective speeds , when you tested them earlier , with the speed selector removed from the circuit for testing of the motor windings to see if they each work with the selector switch out of the circuit
If you know that all 3 speed windings run ok , with the selector switch cut out of the circuit, then you know that the speed selector switch is bad.
Firstly,unplug the fan from the electricity so that your hair does not stand up on end, which would surely be a shocking experience.
secondly,
remove the old speed selector switch, noting down on paper, what color wires go where and put the same color wires from the new switch back in the same place that that color wire of the old switch came off of.
(i know this sounds funny, but it really totally works.)
use electrical tape and/ or wire nuts to make electrical connections, if necessary.
With the new switch installed, the 2 or 3 fan motor speed settings will now totally all work.
most electric fans have steel rotor shafts with bronze bearings.
they "call" them oilite bearings,susposedly because the bronze bushing (it is really a bronze bushing) but called a bearing, is oil impregnanted and susposed to be good for the life of the fan.
that is only true if you expect the life of the fan to be ONLY 18 to 24 months which is the average time that the factory oil lasts.
the oil dries up the longer the fan runs and the shaft makes the bronze bushing begin to heat up due to increased friction and eventually wear the round bronze bushinhg egg shaped.
Try giving your bearings a good healthy squirt of sae 30 wieght oil from a zoom spout-- [pull out straw squeeze bottle refillable oiler.]
I recommend oiling both the front and real fan motor bearings once a month.
This is the most common cause of fan failure.
Because I oil my fans bearings once a month,I still have fans that run from 1940,1950,1960 and 1970. The 1940 GE fan lasted 70 years and is still running strong.
Some newer fans have chinese ball bearings , but the ball bearings also die prematurely from lack of needed oil.
Sometimes, you can pry off the bearing race cover to get oil into the bearing.
a good trick here is to use wd40 if you think you cant get sae 30 into the bearing.
wd40 is a n extreemly light wieght oil that penetrates very well
and gets into places where you think it wont get into .
You can totally wet up a fan motor with either
sae 30 or wd 40 or both without worrying about the electric
motor being harmed by the oil.
the oil,sae 30 or wd 40 wont hurt the motor.
On badly rusted and nearly siezed fan motor bushings , or any electric motor as well, I use first wd40 for penetration and then sae 30 for good long duty lubricatin.
You may have to keep squirting ioil in the motor for 1/2 hour and end up with a puddle of oil under the fan motor, but about 40 % of the time ,you can bring back to life what yo thought was a dead motor. Perserverance is required and faith that you can fix the motor. 40 % of the time you get sucess to one degree or another and 60 % of the time ,its kaput for good.
I got all those fans i mentioned before because other people thought the bearing were seized and shot, and put the fans in the garbage pail where I rescued the fans from.
the bearings were almost siezed but far from shot becaue i got oil in to the shafts and bearings and another 12 to 20 years of life from the fans. However,i do oil them monthly in fan season, which is winter time for me, since I use fans to blow the hot air off of my wood stove.
Oct 10, 2013 | Dryers
Motor humms but wont engage
The start capacitor or start winding has gone bad. Or bearings are dry.
Don't run motor if it does not rotate full speed or motor will overheat and go bad.
Replace or repair motor.
Each motor has 2 winding circuits.
Start winding and run winding.
Both windings receive power same time.
Start winding has capacitor that releases sudden burst of electricity that starts motor rotation. Kind of like low speed on transmission.
Run winding then brings motor up to speed.
http://waterheatertimer.org/images/Motor-wiring-500.jpg
http://waterheatertimer.org/pdf/AO-Smith-motor-wiring.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 07, 2012 | Pool & Spa
How fast are typhoon winds
hello jackson.....
Typhoons form over the western Pacific Ocean. When similar storms form over the Indian Ocean they are referred to as cyclones, and in the Atlantic and eastern Pacific oceans these storms are called hurricanes.
Typhoons and hurricanes and cyclones are rated in strength according to the Saffir-Simpson Hurricane Scale. Category One hurricanes and typhoons have a sustained wind speed of 74 to 95 mph. Sustained wind speeds of 96 to 110 mph raise the hurricane/typhoon to Category Two. A Category Three hurricane/typhoon sustains wind speeds of 111 to 130 mph. At Category Four, a hurricane/typhoon has sustained wind speeds of 131 to 155 mph. When sustained wind speeds exceed 155 mph, the hurricane/typhoon is classified as a Category Five storm.
Joe
Thanks for choosing Fixya!!
May 21, 2011 | Kitchen Ranges
Maytag top load will not agitate and only spins on delicate cycle
could have a bad motor,there are two sets of windings in the motor or low and high speed.the delicate works on the low speed and everything else works on the high speed winding,you can check with a meter to make sure 120 volts is going to the motor.sometimes the motor will just hum and nothing else.you'll have to look at the wiring diagram to see what color wires are going to the high speed winding,if 120 volts is coming down but nothing happens you have a bad motor.
May 10, 2011 | Washing Machines
Winding the Bobbin
I have the same problem and was skeptical of the drop of oil solution but it worked. I had taken my baby lock ellure apart while investigating previously and found nothing else wrong. Tried a few drops of oil and after a moment it started winding noisily and then settled right in!! Working perfectly now!
Jan 20, 2008 | Baby Lock Ellure
St60 wind instrument
You might want to double check that all of the spade connectors that are used to plug the wind transducer into the ST60 wind display are firmly plugged onto the display's terminals.
Because of the blind connection, sometimes the terminal ends up lodged between the red insulator and the spade, rather than within the spade connector itself. This results in intermittent or missing readings from one part of the sensor or more.
Also make sure the display is in Master mode. You will need to get into its setup mode to confirm this. The other possible mode is repeater, which would be used if this were a secondary readout.
Dec 13, 2007 | Raymarine ST60 A22012-P GPS Receiver
dr. Tech Solar Transmitter Wireless Weather Station WA-1070T Logo
Top dr. Tech Measuring Tools & Sensors Experts
Lawrence Oravetz
ray gallant
JonSnell Electronic
JonSnell Electronic
Are you a dr. Tech Measuring Tool and Sensor Expert? Answer questions, earn points and help others
