Question about Oreck Vacuums
Vacuum shut off vacuuming its out
Cuts out when handle in upwright position
AceKiller
  • 7 Answers
SOURCE: No suction in upright position
Check the adapters at the bottom. They're supposed to move cleanly when you lower the handle. It's pretty obvious if there's an air gap when you lower the handle, and you should hear the suction in the air gap.
And...call Dyson...their support is great!
Posted on Nov 07, 2007
  • 126 Answers
SOURCE: Brush won't spin when position of handle changes
The belt for this machine is very specific and only one size fits. It is not uncommon for vac shops to sell the wrong belt because the proper belt is not available from normal supply houses, so they will substitute something they think will work.
Also, assuming you do have the right belt, check the tension arm that drops down on the v-belt when the handle is brought back. This arm has a wheel/bearing with a plastic "tire" or trim that rolls on the belt to tighten it. Sometimes, this tire cracks and falls off and then the remaining bearing won't have the necessary tension to tighten up the belt.
Posted on Jan 27, 2008
reddevil6
  • 1673 Answers
SOURCE: VACUUM WON'T SHUT OFF
Need a model number to be sure, but alot of the Sears cannisters have a relay and it is found mounted in the motor comparment, it may be sticking in the on position.
Posted on Jan 29, 2008
SOURCE: beater bar on Dyson upright won't turn when handle is lowered
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
OLD IS IN NEW IS JUNK!
Happy New Year!
Posted on Jan 01, 2009
  • 3 Answers
SOURCE: Power cut off after handle was dropped on floor while vacuuming
connections inside the handle came loose. happens to me all the time. take the handle apart and connect the wires back.
Posted on May 29, 2009
My roller ball vacuum will run when the handle is lowered to use the floor vacuum but shuts off when locking the handle in the upright position.
Check the instruction book. Some machines shut off when handle is locked in upright position.
Dec 22, 2017 | Vacuums
Why does my vacuum keep cutting out
There is a break in the inner cable somewhere. have the flex replaced or if the break is near the connection to the vac get it refitted removing the faulty section. Get a competent person to do this !
Oct 18, 2014 | Vacuums
DYSON DC 25 SHUTS DOWN UNEXPECTEDLY?
clean all access ports up the handle. plugged somewhere.
Aug 04, 2014 | Dyson DC25 Vacuum
Cuts off when put in upright position
The agitator is supposed to stop turning when handle is in the Up position. The Suction will stay on. . is it?
Dec 15, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Kirby vacuum troubleshooting
The cord is attached to the handle. Putting the handle up is probably stretching or pulling on the cord. The cord may be bad or where the cord goes into the vacuum is called the switch. The cord may not be making go do contact with the switch, check these areas first
Oct 05, 2013 | Vacuums
Faulty switch
Your 8650 is an old vacuum. The switch is in the part of the vacuum where the handle goes down into. When you push the lever on the handle it activates the switch. To get to the switch take off the dust cover, remove the three Screws on the small cover where the handle goes in to see the switch. On older Riccar vacuums like yours sometimes the screw holding the handle in is loose which can cause the switch to not Always engage properly. To test this turn the vacuum on and wiggle the handle. If the vacuum vacuum cuts out you may only need to tighten the handle screw.
Jan 31, 2013 | Riccar 8650/8625 s Vacuum
Vacum will not turn off when switch depressed. Must unplug.
Hi there, if you need some help with your Dyson visit the support section at www.dyson.com.
Kind regards
Darran
Dyson Customer Service
Apr 12, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The shut off switch is stuck to the on position
This sounds like you have an internal problem with the electrical switch. I would recommend you take it to a vacuum dealer who has experience with this model. This is a relatively simple reapir for a pro shop to handle.
Jan 13, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
18 people viewed this question
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
