Question about Vertex Radio Communications
Need programming software for vertex VX231 - Vertex Radio Communications
Vertex vx-3000l windows loading software
You need the Vertex radio programming software for that particular radio model and the programing cable. This is available on the web if you search for it.
May 26, 2014 | Vertex VX-3000L VHF Low Band Mobile Radio,...
Help with Vertex VX-3200 Programming
You may have to find a windows XP or earlier machine. That software doesn't always play well with WIN7
Mar 06, 2014 | Vertex Vx-3200 / Vx-2500 Series Programing...
Will not transmitt
Are you programming the radio or did you buy it used? In the programming, a radio can be set for receive only. The other possibility is a bad battery. A battery has a huge draw on transmit and may not actually send a signal. Think of it like trying to start a car. I encounter this issue weekly. (poor battery) Post more information if you want me to help you. Such as: do you have the software, is it a fresh battery. How old is the radio. Let me know.
Feb 02, 2014 | Vertex Standard Vx-231 Vx231 Uhf...
How do i put a program in to my Vertex Standard VX-929 VHF 136-174 Mhz radio handheld portable transceiver
Nice commercial quality radio. You will need a commercial radio shop to program it. Otherwise you need the particular programming cable and software for that radio to do the job. The fact that you are asking this means that it more than likely it is beyond your area of expertise. If you searched the web for programming software and also programming cable you might succeed . Otherwise order both from Vertex USA, www.vertex.com. Much easier to go to a shop, BTW you need a valid FCC business or GMRS radio license to transmit.
Dec 03, 2013 | Vertex Radio Communications
Programming cable for vx-230 how it is made
Do you have the factory software and programming cable now? You must have those in order to program the radio on a computer.
Jan 25, 2013 | Vertex Vx-230 Series Radio Programming...
Can only use one channel on my vertex standard v-231
Hi, again Craig,
Now that I have the Make/Model of your radio, I can give you advice.
You wish to program your set with frequencies, so here is the best way to do so.
Join yahoo group SPECIFIC to your radio MAKE/MODEL, the team there will assist you with great advice and valuable info, plus you can download manuals, diagrams and other great stuff for your radio.
I hope you are happy with my advice.
Cheers,
Peter
Dec 12, 2012 | Vertex Standard Vx-231 Vx231 Uhf...
Vertex ce82 on my laptop says ce92win power on radio trying to program vertex 2200 mobile radio
Hi Shawn,
The problem is on the screen for you to see.....
You need to downgrade your CE OS to Win CE82, else you r Vertex software won't work, but downgrading is futile, so unless you can get hold of a friends Pocket book PC running Win CE OS 82, you may have problems.
This is a Win CE Operating System fault rather than Vertex software fault.
You say laptop, Win CE OS is for the smaller Pocket Book PCs as far as I'm aware.
If you're running that OS on a laptop PC, that can cause you lots more problems.
I hope this answer clears up the issue a little.
Regards,
Peter
Oct 21, 2012 | Vertex Vx-2200 Vhf 50w 134-174 Mhz 128ch...
Vertex Radio calibration
You've basically answered your own query.
But to get a manual and other great info: join yahoo group specific to your radio Make/Model, the team there will assist in your queries, plus you can download manuals, diagrams and other goodies(if available), all of this is free.
I hope this assists you.
Cheers,
Peter
Aug 14, 2012 | Vertex Standard Vx-231 Vx231 Uhf...
Problem with Vertex VX-820
Try "reading" the radio before programming it. It sounds like the programming software is using the settings from one radio to write to another. It's highly probable that the firmware is different on the two radios.
It's always a good idea to "read" a radio befor trying to 'write' to it..
Dec 14, 2009 | Vertex Radio Communications
Radio Communications Logo
Top Vertex Radio Communications Experts
Steve
eradiostore
eradiostore
k24674
Are you a Vertex Radio Communication Expert? Answer questions, earn points and help others
