Question about AT&T Spirit 6-Button Stard Misty Phone
Where is the admin switch on Spirit System
Trying to program the system back to tone dialing after a problem last night.
5 Suggested Answers
SOURCE: AT&T Spirit Phone
You’ll need either a 6-button or a 24-button set SPIRIT CS administration.
First the control unit ADMIN switch must be ON, the administration overlay must be in place on station 10, and the set must be plugged into control unit jack 10 (call processing is interrupted only at station 10).
After moving the admin switch, and before dialing Ftr 7 -
From station 10 press intercom, Press speaker, Dial *0, Dial 1, Then Press Ftr 7.
Each line indicator light will show the current dialing type for that line. If the light is OFF, that line is set for touch tone dialing. If the light is ON, the line is set for dial pulse
dialing.
To change the dialing type for a line or lines, press the line button(s) and dial the appropriate digit from the table below. You may press more than one line button to make the change on more than one line. If you enter a digit without first pressing a line button you will hear the error tone.
Be sure to turn the admin switch back off when you’re finished.
Posted on Aug 05, 2008
Vit Avaya BP
  • 211 Answers
SOURCE: no dial tone
do you still have a problem?
Posted on Jun 15, 2009
SOURCE: I have an AT&T Spirit
Have you try to reset it? If no, Just try to reset it to factory settings.
Remove the AC Adapter from the AC power (either at the base or at the wall outlet) and immediately connect it again. Remove battery from the handset and immediately replace it. Place the handset back into the charger for about 5 seconds. That should reset the phone and put the phone on default.
Take care.
Posted on Oct 08, 2010
  • 6771 Answers
SOURCE: I have a base corded
There is two approaches we can try, unplug the power and the phone cord from the wall outlet for 10 minutes to see if the processor will reset, If that fails! take the main base apart to see if there is an open fuse on the main board, if yes! replace to see if it will restart the phone. But! if you find the fuse is good it means the board has been compromised and the phone will more than likely need to be replaced.
Posted on Feb 08, 2011
One of my phones stopped ringing on my nec dtu 16d phone
Ringing is assigned in system programming, very little chance it was changed by mistake. If Do-Not-Disturb was turned on, that could make a phone stop ringing. If it's just one line on a phone, maybe the system got put in night mode by mistake and night programming isn't identical to day ring. If you have direct access to the phone line check it for dial tone. Often virtual lines are used and you can't check for direct dial tone. On very rare occasion the ringer stops working, which can't be fixed.
Jul 11, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
Hello, please i want to know how to set up speed dial on the KXT7730 that is not the main line ie not on 0, or 101 on the switch board
Guessing that you already know about SYSTEM speed dials, then the 12 buttons on the right side of your phone are the PERSONAL speed dials. When you get dial tone on the intercom, you can dial "9" and the system will either give you a dial tone, or the highest line in the system. If that is not a working line, you need to fix that first (system program 400 assigns lines in service).
Once you have that, a PF button is programmed by pressing PROGRAM, the button, and dial 9 + your number dialed the same way as if you had pressed a CO button then STORE. You can keep pressing PF buttons and programming numbers. Then press PROGRAM or pick up the handset and drop it back down to end programming.
Carl
Apr 21, 2011 | Panasonic KX-T7730 Corded Phone
I have an AT&T Spirit phone system. I"ve moved and taken the system with me. The phone now calls out on a pulse mode. Automated answering systems that I call will answer but will not respond when...
Take care.
Oct 08, 2010 | AT&T Spirit 6-Button Stard Misty Phone
Toggling between greeting 1 and greeting 2
Hi, what do you want to change? What feature is programmed on the button?
"EACH OF THESE CODES ARE PRECEDED WITH THE ""FEATURE" " KEY"
**CONFIG NORSTAR CONFIGURATION PROGRAMMING (INSTALLER)
**SCPLUS NORSTAR SYSTEM COORDINATOR PLUS PROGRAMMING
(CICS AND ICS 2.0+)
**ADMIN NORSTAR ADMINISTRATIVE PROGRAMMING (SYS Coordinator)
**BASIC NORSTAR BASIC PROGRAMMING (CICS & ICS S.0+)
**SET NORSTAR SET PROFILE
**LINE NORSTAR LINE PROFILE
**USER NORSTAR USER PREFERENCES (CICS & ISC 2.0+)
**TIME NORSTAR TIME AND DATE (CICS & ICS 2.0+)
*0 BUTTON INQUIRY
*1 FEATURE KEY EXTERNAL AUTODIAL
*2 FEATURE KEY INTERNAL AUTODIAL
*3 FEATURE KEY PROGRAMMING
*4 PERSONNEL SPEED DIAL
*501 SELECT ENGLISH
*502 SELECT FRENCH
*503 SELECT SPANISH
*6 RING TYPE
*7 DISPLAY CONTRAST ADJUST
*80 RING VOLUME ADJUST
*81 MOVE LINE KEYS
*82 DIAL MODES
*831 AA ON/OFF (CICS)
*832 CCR ON/OFF (CICS)
*833 AA/CCR RECORDING MAINTENANCE (CICS)
*84 AUTO LOG OPTIONS
*85 CALL LOG PASSWORD
*89 PROGRAMMED RELEASE
*9 RUN/STOP
0 SYSTEM SPEED DIAL
1 SEND MESSAGE
#1 SEND MESSAGE CANCEL
2 RING AGAIN
#2 RING AGAIN CANCEL
3 CONFERENCE / TRANSFER
#3 CONFERENCE SPLIT
4 CALL FORWARD
#4 CALL FORWARD CANCEL
5 LAST NUMBER REDIAL
60 PAGE GENERAL
61X PAGE INTERNAL ZONE (1-6)
62 PAGE EXTERNAL
63X PAGE INTERNAL ZONE (1-6) PLUS EXTERNAL
64 LINE POOLS
65 MESSAGE REPLY
#65 MESSAGE REPLY CANCEL
66 VOICE CALL
67 SAVED NUMBER
68 RESTRICTION /COS OVERRIDE
69 PRIORITY CALL
70 CALL TRANSFER (BLIND)
71 LINK (HOOK FLASH)
72 TIMED RELEASE
74 CALL PARK
75 GROUP CALL PICKUP
76 DIRECTED CALL PICKUP
77 CALL DURATION TIMER
78 PAUSE
79 EXCLUSIVE HOLD
800 TRUNK ANSWER
801 CALL QUEUING
802 GROUP LISTENING
803 SHOW TIME
804 WAIT FOR DIAL TONE
805 TEST SETS (2.0)
806 HIDE DISPLAY
808 LONG TONES
810 MAKE BUSY
811 CALL INFORMATION
812 ENTER CALL LOG
813 LOG IT
815 AUTO BUMPING
817 IRAD TRANSFER (CICS ONLY)
819 OUTGOING NAME AND NUMBER BLOCKING (4.1)
#819 CANCEL OUTGOING NAME AND NUMBER BLOCKING
82 CAMP ON
83 PRIVACY CONTROL
84 LINE REDIRECTON
#84 CANCEL LINE REDIRECTION
85 DO NOT DISTURB
#85 CANCEL DO NOT DISTURB
86 BACK GROUND MUSIC
#86 CANCEL BACKGROUND MUSIC
87 "SERVICE MODES (DR-3,4,5)"
#87 CANCEL SERVICE MODES
870 SHOW SERVICE MODES (CICS)
871 EXTENDED RINGING (ICS)
#871 CANCEL EXTENDED RINGING
872 ALTERNATIVE RESTRICTIONS
#872 CANCEL ALTERNATIVE RESTRICTIONS
873 ALTERNATIVE ROUTING
#873 CANCEL ALTERNATIVE ROUTING
88 VOICE CALL DENY
#88 CANCEL VOICE CALL DENY
FEATURE 900 CODES ARE USED FOR OPTIONAL EQUIPMENT SUCH AS:
"VOICE MAIL, ACD, DIAL BY NAME, DOOR PHONE, ETC."
THE FOLLOWING ARE SOME COMMON USAGES:
9** "RAD PROGRAMMING (RAD 2, FASTRAD)"
9*0 RAD TRANSFER (ALL BUT CICS IRAD'S)
9*1 CHECK FEATURE CODES FOR VOICE MAIL
9*2 SMDR Admin
9*3 LOGGER TIME STAMP
9*3 VMI Codes(this was on an 8x24, came up on this code rather than F9*9)
9*4 NORSTAR DOOR PHONE PROGRAMMING
9*5 FLASH LOW RANGE CHECK FEATURE CODES
9*7 ACD ADMIN MAINTENANCE SESSION
9*9 VOICE MAIL INTERFACE (VMI) CODES
900 SMDR,enter an account number to be logged with the call
901 ACD LOGIN
901 VMI Admin
902 ACD UNAVAILABLE
903 VOICE MAIL HIGH/LOW RANGE SELECTION (DISABLED AFTER USE)
903 ACD CANCEL WRAP
904 ACD HELP
904 FLASH ACD LOW RANGE LOGIN/OUT
905 ACD CATEGORIZE
905 FLASH LOW RANGE DN IDENTIFIER
906 ACD RECORD CALL
906 FLASH LOW RANGE VM TRANSFER
907 FLASH LOW RANGE VM INTERRUPT
908 STAR TEXT (OBSOLETE)
908 FLASH ACD LOW RANGE BUSY MODE
909 ACD ANN. MAINTENANCE
909 FLASH ACD LOW RANGE QUEUE STATUS
910 FLASH LOW RANGE LEAVE MESSAGE
911 FLASH LOW RANGE OPEN MAILBOX
912 FLASH LOW RANGE OPERATOR CONTROL
913 ACD CALLS QUEUED
913 FLASH LOW RANGE SYSTEM ADMIN LOGIN
915 NORSTAR VOICE MAIL 2ND LEVEL ACCESS (PSWD=ACCESS2)
920 ACD ADMIN SESSION
921 ACD ROUTING SESSION DAY/NIGHT
922 ACD ADMIN STATISTICS SESSION
923 ACD GROUP STATISTICS SESSION
960 DIAL BY NAME (CINTECH NSVM OPTION)
961 DIAL BY NAME ADMIN (PSWD=1234)
980 VM SEND MSG TO ANOTHER MAILBOX
981 VM LOG INT MAILBOX
982 VM OPERATOR STATUS(PSWD=OPERATOR(67372867))
983 VM ADMIN PROGRAMMING (PSWD=1020000)
983 VM SOFTWARE LEVEL(LOGIN THEN OPTION 9)
984 VM TIME AND DATE(STARTALK Pswd=1020000)
984 AUTO FOREWARD TO VMAIL(NSVM4.0)
984 FLASH ACD LOGIN/OUT
985 "VOICE MAIL DN INQUIRY(RESET VM ADMIN PSWD 9,73738767793)"
986 VOICE MAIL TRANSFER
987 VOICE MAIL INTERRUPT
988 VOICE ACTIVATED NAME DIALING (NSVM 4.0)
988 FLASH ACD BUSY MODE
989 RECORD CALL (NSVM 4.0)
989 FLASH ACD QUEUE STATUS
Mar 11, 2010 | NorStar M7310 Corded Phone
Can not get kx-t7885 to get a dial tone. The phone is paired with it's base, and will get the panasonic dial tone but not an outside line.
How are you trying to get an outside line? By dialing 9? If the host system happens to be a TA series, you have to tell it how many lines you have, or that you don't have lines that have hardware ports but no dial tone, since systems select outside lines from the top down.
From System programming, program 400 defines connected lines.
Carl
Nov 22, 2009 | Panasonic KX-T7885 Cordless Phone
Computer modem and dial tone
Hello Mikenrgrsvll
This problem can be due to the software not handling a certain dial tone rather than a specific hardware fault. Around the world there is a variance in the signal quality of the dial tone which causes a report of no dial tone detection. Disable the dial tone detection to prevent the system from trying to detect a dial tone.
Disabling dial tone detection for modems:
Windows XP
  1. Click Start
  2. Select Control Panel
  3. Click Switch to Classic View to change the control panel view
  4. Click Phone and Modem Options
  5. Select the Modem Tab
  6. Select the installed modem (Example: Lucent Technologies Soft Modem AMR)
  7. Click the Properties button
  8. Select the Modem tab in the Properties window
  9. Click Wait for dial tone before dialing to remove the check from the checkbox
  10. Select the Advanced tab
  11. Add X3 to the Extra initialization commands field in the Extra Settings box
  12. Click OK twice
  13. Select Switch to Category View to change back the control panel view
  14. Close Control Panel
if this does not work trying re-installing modem drivers.
hope this helps, have a good day.
May 04, 2009 | Acer Aspire One PC Notebook
Where can i find instructions for using features Norstar M7031
The feature codes will not help you troubleshoot the system at all. But here you go:
"EACH OF THESE CODES ARE PRECEEDED WITH THE ""FEATURE" " KEY"
(CICS AND ICS 2.0+)
*0 BUTTON INQUIRY
*501 SELECT ENGLISH
*502 SELECT FRENCH
*503 SELECT SPANISH
*6 RING TYPE
*81 MOVE LINE KEYS
*82 DIAL MODES
*9 RUN/STOP
0 SYSTEM SPEED DIAL
1 SEND MESSAGE
2 RING AGAIN
#3 CONFERENCE SPLIT
4 CALL FORWARD
60 PAGE GENERAL
62 PAGE EXTERNAL
64 LINE POOLS
65 MESSAGE REPLY
66 VOICE CALL
67 SAVED NUMBER
69 PRIORITY CALL
72 TIMED RELEASE
74 CALL PARK
78 PAUSE
79 EXCLUSIVE HOLD
800 TRUNK ANSWER
801 CALL QUEUING
802 GROUP LISTENING
803 SHOW TIME
805 TEST SETS (2.0)
806 HIDE DISPLAY
808 LONG TONES
810 MAKE BUSY
812 ENTER CALL LOG
813 LOG IT
815 AUTO BUMPING
82 CAMP ON
83 PRIVACY CONTROL
84 LINE REDIRECTON
85 DO NOT DISTURB
88 VOICE CALL DENY
9*2 SMDR Admin
901 ACD LOGIN
901 VMI Admin
902 ACD UNAVAILABLE
903 ACD CANCEL WRAP
904 ACD HELP
905 ACD CATEGORIZE
906 ACD RECORD CALL
Dec 08, 2008 | NorStar M7310 Corded Phone
Problems with norstar m7310 corded phone do not disturb feature
What do you want to change? What feature is programmed on the button?
(CICS AND ICS 2.0+)
*0 BUTTON INQUIRY
*501 SELECT ENGLISH
*502 SELECT FRENCH
*503 SELECT SPANISH
*6 RING TYPE
*81 MOVE LINE KEYS
*82 DIAL MODES
*9 RUN/STOP
0 SYSTEM SPEED DIAL
1 SEND MESSAGE
2 RING AGAIN
#3 CONFERENCE SPLIT
4 CALL FORWARD
60 PAGE GENERAL
62 PAGE EXTERNAL
64 LINE POOLS
65 MESSAGE REPLY
66 VOICE CALL
67 SAVED NUMBER
69 PRIORITY CALL
72 TIMED RELEASE
74 CALL PARK
78 PAUSE
79 EXCLUSIVE HOLD
800 TRUNK ANSWER
801 CALL QUEUING
802 GROUP LISTENING
803 SHOW TIME
805 TEST SETS (2.0)
806 HIDE DISPLAY
808 LONG TONES
810 MAKE BUSY
812 ENTER CALL LOG
813 LOG IT
815 AUTO BUMPING
82 CAMP ON
83 PRIVACY CONTROL
84 LINE REDIRECTON
85 DO NOT DISTURB
88 VOICE CALL DENY
9*2 SMDR Admin
901 ACD LOGIN
901 VMI Admin
902 ACD UNAVAILABLE
903 ACD CANCEL WRAP
904 ACD HELP
905 ACD CATEGORIZE
906 ACD RECORD CALL
Dec 02, 2008 | NorStar M7310 Corded Phone
AT&T Spirit Phone
dialing.
Aug 05, 2008 | AT&T Spirit 6-Button Stard Misty Phone
There was a power surge, and now my phone is stuck on pulse dialing, how do I get it back to tone? I can use the star key to bypass the pulse and put the phone on tone, but it only works one call at a...
Press speaker,
Dial *0,
Dial 1,
Then Press Ftr 7.
dialing.
Mar 07, 2007 | AT&T Spirit 6-Button Stard Misty Phone
Open Questions:
See all AT&T Spirit 6-Button Stard Misty Phone Questions
AT&T Spirit 6-Button Stard Misty Phone Logo
26 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
