Question about EliteGroup P4VMM2 Motherboard
Wont register the ide hdd
For some reason i cant get the ide hdd to work, the drive is fine, the cords are fine and the ide connections on the mobo are fine, they all pick up the dvd, but not the hdd.....if anyone knows where i can get either a copy of the motherboard instal disc, or the right drivers that i need.
Thanks heaps dudes
  • 3 more comments
  • phatmole Nov 01, 2007
    unfortunatly, it doesnt seem to do what i want
    i found a few versions of the 4in1, but alas, i still cant get it going. problem is, when i try from f6 on  win install it either says no txtsetup file, and when i try from a dos prompt, it says not enough memory to load it....any ideas?
    i agree, it should pick it up in the bios, but nup. the spun part is, ive tried the dvd drive on the primary, secandary and the bios has registered it at all points. yeah, i checked the jumpers, lol, i also tried all possible settings with a start up....zip. the drive works, i used my other pc to format the drive (should i test it again?),
    the strange thing is the motherbaord drivers on the ecs site, there are ide drivers there ( ive tried them, still nothing).
    for some reason, the motherboard wont register the ide..., thanks heaps for you help by the way dude, your a champ, if you have any other ideas im up for them
  • phatmole Nov 02, 2007
    ok, ive tried to bypass the whole ide thing with limited success. using a pci to sata card ive been able to get it to register that the hdd is there, but still on trying to install windows, it tells me it can find no drives. admittedly, i know little about sata.
    was this a good plan ?, any ideas how to get it to load win on to the sata drive?
    (i would have tried your suggestion, but now my monitor is stuffed on the main pc, black screen...when it rains..lol...it pours)
    yep, got the floppy drive, and all is good...until, after the whole f8 to agree on the windows install, it comes up to insert my windows disc ( it is), then it tells me it coulfd not read the disc or it is not a valid windows disc...(it is, windows xp pro). lol, where am i going worng now...lol
  • phatmole Nov 05, 2007
    that was it, the cd was damaged. its all up and running now....however, now theres another minor (probally major) hicup.
    sorry its taken so long to reply dude, and again, thanks heaps for your assistance.
    lol, ok, the other problem...the system is freezing at random times...any thoughts?.
    sorry again for the delay and thanks again for you help dude.
    Mole.
  • 196 Answers
Do a google search for ecs p4vmm2
This should take you right to the download page where you can get the VIA 4 in 1 drivers. The url is too long to copy.
Double check  the master/slave jumpers on the hd.
Posted on Oct 26, 2007
  • 2 more comments
  • Hugh Vandervoort
    Hugh Vandervoort Nov 01, 2007
    There has to be something else wrong. You don't need to press F6 to load IDE drivers. Have you checked the Slave/Master jumpers?
    Does this drive show in the BIOS?
    Has this drive ever worked? Is it formatted?
    It's entriely possible this drive is damaged in some way.
  • Hugh Vandervoort
    Very weird.
    Is this a standard brand HD? Look very closely for damaged pins.
    I think I would:
    Put it in the other PC and format it NTFS (You're using XP, right)?
    Set the jumper to master and install it on the Primary IDE channel IDE cable in the master position (because we know the Master position works). Do this without the DVD attached.
    Boot up, check if it's found in the BIOS. If no luck, we're missing something.
  • Hugh Vandervoort
    Hugh Vandervoort Nov 02, 2007
    I'm not sure what card you're using, but I would assume that you now need to load the drivers for the (now) SATA drive when you install Windows. That's the screen where you press F6.
    Usually this is done with a floppy disk, if you have a floppy drive.
  • Hugh Vandervoort
    It sounds as though your CD is damaged. You may be able to clean it, or just borrow one from someone, using your own product key.
GA-EP41-UD3L problem with SCSI/IDE
Sounds like the motherboard bios is only capable of booting from drives connected to the motherboard's ide connector and not additional / or external ide connectors. Looks like you would have to have 1 HDD and the CDRom Drive on the built in ide connector and the other hard drive on the extra ide connector you added. Although that would probably stop the other HDD from booting. Have you thought about putting both operating systems on the same drive. I do it all the time.
Feb 11, 2012 | Computers & Internet
Fujitsu P5010 with Ide 1 malfunction.
Look on eBay - I saw a hard-drive adapter for the cd-slot there last month.
Also, you sure its not the hard-drive failing?
You can also get a laptop to pc adapter to test it.
Apr 04, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
IDE Ports not working on ASUS P5LD2-VM Mobo
Good Day sir, hi, Have you tried to enable the IDE on BIOS setup. If the Bios setup did not solve the IDE problem, check the IDE port of the HARD drive, check if there are bent pins.
If still wont work, you can buy a PCI to IDE/SATA card, this is an expansion card in PCI format with IDE and SATA port.We use this card incase the IDE or SATA on the motherboard gets bad. Connect it on the available PCI slot. Then connect the IDE cable of the Hard disk to this card. Thats it.
Nov 10, 2009 | ASUS P5LD2-VM Motherboard
I have a new mobo and I have only one IDE connection and I have about seven SATA connections. I have two IDE harddrives and two IDE CD/DVD-RW drives which are using the IDE connection on the MOBO. I...
If you are doing this in windows xp, you will need to install the scsi drivers that are for your chipset (the motherboards traffic control basically) These are on the cd that came with your mobo. Another thing you can try is to set the bios to ide emulation mode (probably called safe mode/compatibility mode) for the sata channels.
Hope this helps
Jay
Jul 08, 2009 | Office Equipment & Supplies
Ecs 6100sm-m mobo connections
you have a few options
1) buy a sata harddrive (faster then ide), use the ide for the second harddrive (backup) and cd/dvd rom
2) buy a sata cd/dvd rom use the ide on both harddrives (1 set to slave)
3) depends on your budget, buy a sata drive + sata cd/dvd rom so your main drive is on sata (faster than ide) then you only have your second drive as your backup drive on ide.
i had the same problem when i rebuilt mine, i went for the seperate harddrive and cd/dvd rom and my 320 gb ide as my backup drive
sorry to jump on this post aswell, see what others think
Mar 16, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
Gigabyte K8vm800M Motherboard Does Not Recognise Seagate SATA HDD
I HAVE THE SAME PROBLEM IN THE PAST. I REPLACE THE IDE HDD WITH SATA AND AFTER I BOOT IT SAYS NO HARDDISK. IT IS BECAUSE WINDOWS XP HAS NO BUILT IN SATA DRIVER.
WHAT YOU SHOULD DO IS CHANGE YOUR HARDDISK TO IDE OR INTEGRATE A SATA DRIVER INTO YOUR XP (USE NLITE) OR USE THE FLOPPY DRIVE TO RUN SATA DRIVER ITS INCLUDED IN THE MOBO WHEN BUYING.
Mar 16, 2009 | Gigabyte GA-K8VM800M Motherboard
IDE Problem (I Think)
Depends what kind of motherboard is. You may want to check with a different IDE ribbon cable. Make sure that the IDE controller is ENABLED within BIOS. Set the HDD as Master - see those jumpers next to the power and data connectors. Try with another (IDE) HDD and see if the controller is working. Don't asume the 1st HDD is working OK, you never know ...it may be broken now ...
Jan 09, 2009 | Computers & Internet
What new HDD will match my Maxtor DiamondMax Plus 8?
Mark,
You can use any size HDD in your computer as a slave and it does not have to be an exact match for the maxtor. You will however need the make sure that the connections on the new drive match. For example SATA drives will not attache to an IDE cable and vice versa. The drive that you mentioned is an IDE style drive so unless your MOBO has SATA connectors on it you will need to buy an IDE/EIDE drive.
Dec 29, 2008 | HP Compaq d530 PC Desktop
ASUS K8V-MX Motherboard with 250GB SATA HDD and 250GB IDE HDD Problem
Hi LP,
I’ am very familiar with ASUS motherboards. I am thinking you have posted two questions or more referring to the,
ASUS K8V-MX board. When you sign into you're FixYa account you than need to click on you're profile. Within you're profiles are the questions you have posted. Click that question to add or see the expert's answer. If you need another question (about the same item) re-post within that same question. You can even copy the link to an older post & past that link into you're next question. (Than I can read you're last question & my responce).
LP you have me all mixed up. I'll answer the question you have posted above. In the future please provide you're old post so I understand better.
There is nothing wrong with IDE 250GB drive or the SATA drive.
The problem you are haveing is setting the correct settings.
The ASUS K8V-MX can support two serial ATA SATA drives. The SATA drive's can only run at 1.0 version. 1.5GB transfer speed & not SATA II, the 3.0GB speed.
How to setup the SATA drive?
Please disconnect any other drives (IDE) & a second SATA drive that may be connected to the system. Except the CDROM drive.
Using you're manual the SATA drive should be connected to SATA1 port. Page 1-24 in you're manual.
Put you're windows CD into you're CD-ROM drive & boot the PC. You will see, Press any key to boot from CD... (press any key on your keyboard). Windows will start to install. Durring installation of windows the system will restart. You will again see, Press any key to boot from CD... (DO Nothing)!
Just allow windows to conintue on its own. Windows will continue to install it's self. This will happed once again, & again do nothing. Windows will finish installing it's self.
After windows has finished, load the ASUS CD into you're CD-ROM drive & install it's driver software. Restart the PC.
You must register windows. Do so.
Than update windows through windows update service. (This will take some time to complete). (Do not install service pack 3).
If you have an IDE drive 250GB in size & you installed windows on it. You must erase the drive or it will conflict with you're new installation on the SATA drive. To do this, look on the IDE drive & you will find a large white sticker. Printed on there is instructions of how to set the drive pin. Set the drive up as a slave drive. (This is only temporary).
Power off the PC & unplug the power cord. Connect the 250 IDE drive's power cable & data cable. Plug in the power cord to the PC & turn on the PC. Windows will load. Right click once on the start button & slide up to & left click on Explorer.
Find the 250 IDE drive, it should be drive letter D or E. Right click the proper drive letter & format the drive.
( Do Not format, Local_Drive C:\ ). Once the format is complete, power down the PC by clicking on the start button & click turn off the computer. Once off, unplug the power cord. Change the pin on the 250GB IDE drive to Master with a slave. Take the 40GB drive & change it's pin so the 40GB drive is a slave.
Connect the 250GB drive to the end of the IDE data cable & connect the 40GB drive to the next connector of the same IDE data cable. Re-check all power cables & data cables for good connections before closing the case. Plug the power cord in & power up the PC. Everything should run just fine.
Setting the pin for you're IDE drive's can be very confusing. Click on the link below. This will give you an idea of how to set you're pin for a master drive, master with a slave drive. If you post the name ST****** of you're two drives I can post the correct pin locations from Seagate's web site.
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
Have more questions about this post?
Mike
May 21, 2008 | ASUS K8V-MX Motherboard
Mobo only one ide connection socket for HDD & CD-Rom
yes you can add both your HDD and CD-ROM Drive with the same IDE, get a IDE data interface cable (BUS) atleast three connection point. Add 1 to mobo, second to HDD and top 1 one to CD-ROM drive. Just connect and dun wrry m sure it will work....so............:))
If any problem just Ask me
Thanks
Iqbal
Apr 07, 2008 | Computers & Internet
EliteGroup P4VMM2 Motherboard Logo
42 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
