Question about Philips Televison & Video
Tata sky remote switches off philips led tv on pressing of guide button
chrispurs1
  • 372 Answers
SOURCE: Tv wont switch to Sky when remote control is pressed
Hi.
On the sky box do the following.
Check scart to tv is in the correct socket marked TV.
Try pressing services
then system setup
then picture settings.
Then try switching scart control to on or off.
If this sorts it great. If it doesnt check scart lead has all pins wired & not only A few.
http://dysonmanuals.llc.nu
Chris..
Posted on Jan 20, 2008
SOURCE: PHILIPS 32PF7331/12 LCD TV
Press tv on sky remote then press help ,channel list appears . goto tv set use onset channel change button to scroll to hd channel .press volume up button onset to select.
Posted on Sep 29, 2008
SkyGuy08
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
  • 3 Answers
SOURCE: I need to change the source on my tv to HDMI without my remote
Not sure if yours is the same but Philips codes work with Skyworth and if you hit the TV/AV button on the side of the TV and the table of options should come up. And then with the channel +or- go up and down till you are on HDM1 or where ever you want and then touch the TV/AV again when you are there.
Posted on Mar 28, 2010
SOURCE: timer LED flashing and tv screen not viewing
please help,pioneer xv-htd7 timer flashing...
Posted on Apr 11, 2011
I need the code number of tv to enable me to use sky remote control
Please try 0863 for Hyundai Televisions To program your Sky remote control using the 4 digit code
  1. Switch on the TV set
  2. Press the TV button on the Sky Remote
  3. Hold down the Select and Red buttons for 2-3 seconds until the LED blinks twice
  4. Press the TV button on the Sky Remote again
  5. Enter 0863
  6. The LED should blink twice, if not recheck the 4 digit code used and go back to 1
  7. Press the standby button on the Sky Remote (The TV should go to standby)
  8. Press the Select button to store
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Please keep me posted.
Thanks.
Lor04
Apr 06, 2011 | Hyundai Televison & Video
Sky hd remote code needed please
Sky High Definition SkyHD uses a new design of Slim line remote control. The Default TV code pre-programmed into the RCU is now for Phillips and is (0)065. The SkyHD RCU is programmed in the usual manner using either the instructions in the Digital Installation Manual or via the Sky Customer Service option in the Interactive on-screen menu.
The SkyHD RCU can also be programmed to operate Sky+ boxes as well as SkyHD:
Press the TV button.
Press and hold SELECT and i together until the LED flashes twice.
Press the number button 1 and then press SELECT.
(Obviously you can't have a SkyHD and a Sky+ Digibox both in the same room).
Note: To re-programme the RCU for Sky HD box operation only, repeat the above process pressing the 2 button in step three.
Keep pressing HELP and waiting a few seconds until you find the correct command that activates the AV source you require then press SELECT.
The HELP button will now directly activate the chosen AV source instead of toggling through the alternative options to reach it.
There are 18 AV source commands to be tried before the RCU blinks 3 times to indicate it is out of options.
The Sky Guide buttons (SKY, tv guide, box office, services & interactive) can now be directed to use the same AV source as the newly programmed HELP button.
Press SELECT and GREEN until LED flashes twice.
Press HELP then SELECT and the LED will flash Twice.
The Sky Guide buttons will now instruct the TV to switch to the desired AV source and the RCU will be in Sky Mode.
Discussion here: http://www.digitalspy.co.uk/forums/showthread.php?t=944054
You can also use a Sky+ remote to control a SkyHD digibox.
See codes page for SkyHD
Mar 17, 2010 | Televison & Video
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
Code for TV / Sky+remote
Problem: Need Sony manufactures code for the Sky remote.
Solution: Your TV Code for Sony is 0000
1. Turn on your TV.
2. Ensure that the front of your Sky Navigator is closed.
3. Press "tv”.
4. Hold down "select" and the red button together for about two seconds, until the red LED on the Sky Navigatore flashes twice.
5. Press "tv" again.
6. Key in the four digit code for your brand of TV. The LED on the Sky Navigator will flash twice. If the LED illuminates only once, re-check the code for your brand of TV and start again at step 5.
7. Press the standby button on your Sky Navigator. If your TV switches off, press "select". The LED on the Sky Navigator will flash twice. If your TV does not switch off, press "tv", then press the standby button.
Repeat this (press "tv", then standby button) until your TV turns off,
then press "select".
If you are still experiencing problems, please telephone for technical
assistance. you will find the "Technical Help" telephone number by
pressing "services" and selecting "Telephone Numbers".
The help given is based on information taken.... Hoped this has helpd you
Jan 13, 2009 | Televison & Video
How do i key in code for digibox
TO PROGRAM THE remote USING THE 3 DIGIT CODE:
1. Turn on the TV receiver
2. Press TV on the Sky Remote Control
3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
4. Enter three digit code from list for the receiver (early versions now flash twice).
5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
6. Now press the STDBY button and test other functions.
Repeat if necessary until a code is found that works most common functions.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
If after trying this, you still have problems, call your broadcaster's help desk. For your broadcaster's help desk number, select the Telephone Numbers option from the Services screen.
Dec 19, 2008 | Computers & Internet
TV REMOTE CONTROL NOT WORKING
1. Turn your TV on.
Oct 17, 2008 | Philips HDD065 MP3 Player
Hitachi CLE984
The code you need is 0145
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting
Jul 01, 2008 | Hitachi CLU-5713TSI Remote Control
32PFL5232D/37
The code is 0081 and this is how you do it.
'4 digit' or 'Brand Set' method
1. Turn on your TV.
2. Press TV on your Sky remote control.
4. Press TV on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press TV , then press the on/off button. Repeat this (press TV , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press TV guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide, you must now set the TV Guide function as follows:
8. Press TV on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice. The remote control setup process is complete.
Mar 11, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
I NEED THE CODE FOR ALBA TV MODEL NO. ALCD15TV8M
There are two code types for sky remotes, Brand Codes & Direct Codes.
The codes for Alba are:
Brand - 0043
Direct - 037, 065, 246, 399, 263, 064, 446
There is a small difference in the way they are set.
To program using the 3 digit code - Direct Code
4) Enter the 3 digit code
5) Press the select button to store
Press TV and any number to test, If this does not operate the TV set try below.
To program using the 4 digit code - Brand Code
Feb 18, 2008 | Televison & Video
Sky code for remote
The code for you sky remote is 0125.
4 digit' method
1. Turn on your TV.
5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice.
If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
7. Press tv guide .
If you did not see the TV Guide,you must now set the TV Guide function as follows:
10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
Feb 13, 2008 | Televison & Video
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
