Question about Nikon COOLPIX S9500 Digital Camera Black
Will not turn on
I got a Nikon Cookpix S9500 for Christmas. I am having trouble getting it to charge. I plugged it in to charge, and the green light began to blink. It was plugged in for two days and never stopped blinking. I unplugged it, and plugged it back in, and it began to blink. It blinked for several hours, then stopped blinking. I thought it was charged. When I turned the camera on, it gave me the message "Battery Exhausted" then went off. The camera would not turn back on, and when plugged into the charger, it does nothing not...not even blink. Suggestions?
SOURCE: Battery EXTREMELY Exhausted
As the other person says Nimh rechargable batteries are the best....Also somewhere in the menu system you will find that you need to define which type of battery you are using, this may be the cause...Nikon UK have an excellent after care team if all else fails.
Posted on May 25, 2007
  • 11967 Answers
SOURCE: As I Purchased a New Nikon Collpix (S3000) camera,
It's not unusual for a defective battery/charger/camera to happen. Take it back and ask for a replacement.
Posted on Nov 11, 2010
  • 6771 Answers
SOURCE: My Nikon Coolpix S3000 says
The rechargeable battery probably needs to be replaced, I would take it to a camera shop let him have a quick look to make sure the charge light is coming on and try a new battery.
Posted on Jan 14, 2011
SOURCE: when i turn on my
when I turn on my Nikon Coolpix S210 digital camera on it says battery temperature is high and I cannot use my camera. Why?
Posted on Feb 22, 2011
SOURCE: Nikon D90 Memory Card Access Blinking
It's a deadly common problem of D90. Fixation:Simply go to the DSLR repair shop and ask them to change the power circuit board of the camera. Will take $60-70 if the board available. Reason of issue:The power control IC get short and feedback the battery power to the battery causing the draining out and other problem like the top LCD back lamp turned ON after turning on the camera. Careful:To avoid this issue in future, after full charge of the battery, do not put it in the camera right then. Wait for the battery to cool down for 5-10 min and then put it in. With the full charge, the battery hold high ampere for a short time. It could damage the power distributor IC suddenly if you put it in the camera right after a full charge. Best, Leo>>from personal experience<<
Posted on Dec 14, 2011
Nikon coolpix s9500 no power and not charging battery is new
Step 1) plug Charger adapter into mains. Step 2) Plug cable into camera. If you have the cable plugged into the camera and then plug it into mains it will not charge.
Sep 27, 2016 | Nikon Inc Nikon Coolpix S9500 - digital...
Cannot select the wi-fi network on
The Wi-Fi connection requires installing a Wireless Mobile Utility to the smart device prior to use. And the Utility must be On.
Compatible OSs: iOS 6.0 or later, Android 2.3 or later
The Wi-Fi connection will be disabled if:
  • The battery charge is low
  • A memory card is not inserted
  • An Eye-Fi card is inserted
You can consult the user manual for further troubleshooting at:
Nikon COOLPIX S9400 S9500 Reference manual Nikon Knowledgebase
Aug 30, 2014 | Nikon COOLPIX S9500 Digital Camera Deluxe...
Will not charge
Sounds like you have a bad battery. Check your users manual for how to change it.
May 01, 2017 | Nikon COOLPIX S9500 Digital Camera Black
My brand new Nikon Coolpix S9500 will not charge and will not turn on. I plugged it in to charge after using it for one week on vacation and the battery drained instead of charged. When I got home the...
i had this problem, and like a dunce just needed to read the directions more clearly. manual indicates that the cable needs to be plugged in by a certain order. see page 14 of the manual. can't believe that was all that was necessary to clear all my frustration!
http://www.nikonusa.com/pdf/manuals/coolpix/S9500S9400RM_EN.pdf
hope that helps!
Aug 30, 2013 | Cameras
Memory contains images
You're in playback mode and haven't taken any pictures. Put the camera in photo mode or video mode.
Jul 25, 2013 | Nikon Inc Nikon Coolpix S9500 - digital...
My coolpix L810 won't turn on. Green light comes on but goes out. Can't see screen. Lense was frozen but plugged into computer and closed.
have the battery full charge? sometime the battery is not charged although the charging indicator is full charge, maybe the battery is shorted out.
May 04, 2013 | Nikon COOLPIX L810
Nikon Coolpix won't charge no matter what
The internal battery, which is kept charged by the removable battery, has probably run down. Take it to a repair facility.
Apr 25, 2017 | Nikon CoolPix S4150
My Nikon coolpix s8000 wont turn on
fuse , only need a fuse that it , but I need to open
Oct 06, 2017 | Nikon COOLPIX S8000 Digital Camera
Bought a Nikon Coolpix S3000 (orange) for my daughter after Christmas. It just stopped working one day; wouldn't charge, no lights or come on. The battery it came with is a Nikon lithium ION Battery...
Read page 16 of the manual. Do not use any other charger with this camera. Are you sure you have the battery inserted correctly? When trying to charge, does the green light blink? If so, when it stops blinking and turns off, the battery should be fully charged. Do not attempt to turn the camera on while the charger is trying to charge the battery.
Aug 17, 2011 | Nikon Coolpix S3000 Digital Camera
Lens error
My camera is Nikon Cookpix s5, have same problem. I think it has to be error production of Nokon!!!
May 06, 2008 | Nikon COOLPIX S6 Digital Camera
Nikon COOLPIX S9500 Digital Camera Black Logo
37 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
