Question about Miele CVA4070 Coffee Maker
Can I put the drip tray in the dishwasher - Miele CVA4070 Coffee Maker
I have a kenwood KDW12ST3A dishwasher. i have lost the manual and the dishwasher is displaying code E4.What does this mean ??
HERE IS A LEAK AND IT IS BUILDING UP IN THE BOTTOM DRIP TRAY!. It is filling up the drip tray and tripping the micro switch. Remove the lid(2 screws at rear),givng access to screws on top of right side panel,remove right side panel, you will have to remove plastic cover on bottom front first to give access to screws on side panel. This gives access to the hoses and such, where the leak is most likely coming from. I would buy some inch and a half to 2 inch hose clips first, as the clips on the machine are not really reusable.The machine will have to be put on its left side, you may have to remove the bottom drip tray also, this holds the micro switch and the polystyrene float. You may have to run the machine to see where the leak is coming from, It is time consuming, but very "doable", remember electricity and water do not mix,unplug and make sure everything is dry, particularly yourself!.
Apr 26, 2011 | Dishwashers
My dishwasher is tripping my electricity - do you know why??
i had this awhile agow it was that the underneath drip tray was full of water touching electrics SO SWITCH OFF PLUG MAINS BEFORE YOU START ANYTHING had to empty tray and dry out with hairdryer no problems since then
Jan 28, 2011 | Bosch Dishwashers
Fault code 30 has come up on my dishwasher how do i fix it
-30 is a leak in the system and is filling up the drip tray at the bottom. The float is attached to a micro switch and will halt the program and start the pump to drain the washer. You can tell by feeling in under the tray for water.
Nov 04, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Diplomat dishwasher bleeping showing FA
We have just experienced an FA audible error on our Diplomat ADP 8332 dishwasher...after pulling the dishwasher out and removing the low front panel we found the drip tray full of water. We tipped the dishwasher onto it's front and removed the drip tray and found a float pressure switch...it appears that once the drip tray is full the float switch activates and causes the FA fault (prevents the dishwasher from continuing) drain off your drip tray replace all covers and you should be good to go!!
Sep 16, 2009 | Dishwashers
Strong odour coming from non-removable tray under new fridge
do not frustrated .firsly you should look for any THING THAT block the drip tray from geting out. usually it can be pulled out by PUSH ASIDE THE DRIP HOST SOMTIMES BLOCKING THE DRIP TRAY MOVEMENT IN OR OUT.
LATER CLEANED THE DRIP TRAY & REINSERT IT BACK TO ORIGINAL SITE
Sep 24, 2017 | Kenmore 44273 Side by Side Refrigerator
LE Code Help - DMR57 Series
I had the same problem. On the bottom of the unit is a tray the catches any water that leaks from the tub. In the tray is a sensor that shuts off the unit and water if it get wet. Take the tray off and see if water is in it. If so, you have a leak somewhere. You might be able to dry off the sensor and get it to work but if you have a leak, you want to know. Best way to check is put the dishwasher up on two milk crates, leave the tray off and turn it on the rinse cycle and see if any water drips.
On my first unit, the rubber seal was installed wrong at the factory. They replaced the seal, but the error came up again. When checked out, the tub was leaking too. The dishwasher was replaced with another one. After one wash, the same problem occurred. LE error. I took it back and got a different Samsung model. It just stopped working after only two weeks. Evidently the touch pad sensors are bad because it will not turn on. Needless to say I'm getting tired of installing dishwashers. I think I will go for a different brand.
Feb 10, 2009 | Samsung 24 in. DB5710DT Stainless Steel...
My ice maker is turned off, but water slowly seeps into the tray
Try turnig off the fridge and let it defrost,keep the doors open and put pans of hot water in the freezer,wait 6 to 12 hrs.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Jan 31, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Baumatic bdw13
the top tray has a nozzle on rear,which pushes into a screw on rubber seal on inside rear of appliance.this splits and stops water being fed to sprayer on top tray.phone baumatic parts dept,only a few pence,but sent mine free!
Jan 09, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Hotpoint dishwasher bf1620 - 1st light indicator (heavy soil)flashing. information from hotpoint and manual useless
Hello!
I found out from hotpoint that the first flashing indicator means that the 'float switch' has been activated meaning that the base tray 'may' be leaking. I don't know whether this is a tactic to get their repair man out to fix it.
I was wondering whether there is a way to reset the switch and try re-running a programme as my base tray doesn't seem to be leaking.
I hope this helps a bit
May 02, 2008 | Dishwashers
Miele CVA4070 Coffee Maker Logo
15 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
