Question about Nikon COOLPIX S9500 Digital Camera Black
Will not charge
I got a Nikon Cookpix S9500 for Christmas. I am having trouble getting it to charge. I plugged it in to charge, and the green light began to blink. It was plugged in for two days and never stopped blinking. I unplugged it, and plugged it back in, and it began to blink. It blinked for several hours, then stopped blinking. I thought it was charged. When I turned the camera on, it gave me the message "Battery Exhausted" then went off. The camera would not turn back on, and when plugged into the charger, it does nothing not...not even blink. Suggestions?
  • 329 Answers
Sounds like you have a bad battery. Check your users manual for how to change it.
Posted on May 02, 2017
SOURCE: Battery EXTREMELY Exhausted
As the other person says Nimh rechargable batteries are the best....Also somewhere in the menu system you will find that you need to define which type of battery you are using, this may be the cause...Nikon UK have an excellent after care team if all else fails.
Posted on May 25, 2007
  • 11967 Answers
SOURCE: As I Purchased a New Nikon Collpix (S3000) camera,
It's not unusual for a defective battery/charger/camera to happen. Take it back and ask for a replacement.
Posted on Nov 11, 2010
  • 6771 Answers
SOURCE: My Nikon Coolpix S3000 says
The rechargeable battery probably needs to be replaced, I would take it to a camera shop let him have a quick look to make sure the charge light is coming on and try a new battery.
Posted on Jan 14, 2011
SOURCE: when i turn on my
when I turn on my Nikon Coolpix S210 digital camera on it says battery temperature is high and I cannot use my camera. Why?
Posted on Feb 22, 2011
SOURCE: Nikon D90 Memory Card Access Blinking
It's a deadly common problem of D90. Fixation:Simply go to the DSLR repair shop and ask them to change the power circuit board of the camera. Will take $60-70 if the board available. Reason of issue:The power control IC get short and feedback the battery power to the battery causing the draining out and other problem like the top LCD back lamp turned ON after turning on the camera. Careful:To avoid this issue in future, after full charge of the battery, do not put it in the camera right then. Wait for the battery to cool down for 5-10 min and then put it in. With the full charge, the battery hold high ampere for a short time. It could damage the power distributor IC suddenly if you put it in the camera right after a full charge. Best, Leo>>from personal experience<<
Posted on Dec 14, 2011
Nikon coolpix s9500 no power and not charging battery is new
Step 1) plug Charger adapter into mains. Step 2) Plug cable into camera. If you have the cable plugged into the camera and then plug it into mains it will not charge.
Sep 27, 2016 | Nikon Inc Nikon Coolpix S9500 - digital...
Light does not flash when charging battery
Please try this:
1) Make sure camera is OFF.
2) Plug Charger into the wall (not into camera)
3) Last think plug charger into the camera
Oct 15, 2014 | Nikon Coolpix S3000 Digital Camera
Cannot select the wi-fi network on
The Wi-Fi connection requires installing a Wireless Mobile Utility to the smart device prior to use. And the Utility must be On.
Compatible OSs: iOS 6.0 or later, Android 2.3 or later
The Wi-Fi connection will be disabled if:
  • The battery charge is low
  • A memory card is not inserted
  • An Eye-Fi card is inserted
You can consult the user manual for further troubleshooting at:
Nikon COOLPIX S9400 S9500 Reference manual Nikon Knowledgebase
Aug 30, 2014 | Nikon COOLPIX S9500 Digital Camera Deluxe...
Battery charging shows quick green light
Ill try to help you, I think the slow flashing green lite is when you first plug it in the longer its on it will flash quickly when almost finished mine blinks untill full then stays on try to wear your battery all the way down then try to charge again good luck
Mar 24, 2014 | Nikon COOLPIX L19 Digital Camera
My brand new Nikon Coolpix S9500 will not charge and will not turn on. I plugged it in to charge after using it for one week on vacation and the battery drained instead of charged. When I got home the...
i had this problem, and like a dunce just needed to read the directions more clearly. manual indicates that the cable needs to be plugged in by a certain order. see page 14 of the manual. can't believe that was all that was necessary to clear all my frustration!
hope that helps!
Aug 30, 2013 | Cameras
Memory contains images
You're in playback mode and haven't taken any pictures. Put the camera in photo mode or video mode.
Jul 25, 2013 | Nikon Inc Nikon Coolpix S9500 - digital...
My Nikon coolpix s8000 wont turn on
fuse , only need a fuse that it , but I need to open
Oct 06, 2017 | Nikon COOLPIX S8000 Digital Camera
Bought a Nikon Coolpix S3000 (orange) for my daughter after Christmas. It just stopped working one day; wouldn't charge, no lights or come on. The battery it came with is a Nikon lithium ION Battery...
Read page 16 of the manual. Do not use any other charger with this camera. Are you sure you have the battery inserted correctly? When trying to charge, does the green light blink? If so, when it stops blinking and turns off, the battery should be fully charged. Do not attempt to turn the camera on while the charger is trying to charge the battery.
Aug 17, 2011 | Nikon Coolpix S3000 Digital Camera
hey dear you must have got the battery and charger along that charge those batteries for 8 hrs and then use coz nikon doesn't have LI ion battery so u have to charge the cells instead
Jan 07, 2009 | Nikon COOLPIX L18 Digital Camera
Lens error
My camera is Nikon Cookpix s5, have same problem. I think it has to be error production of Nokon!!!
May 06, 2008 | Nikon COOLPIX S6 Digital Camera
Nikon COOLPIX S9500 Digital Camera Black Logo
57 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
