Question about Ingersoll Rand Air Tools & Compressors
To reset ingersoll rand intellisys navada n160
  • 44 Answers
Middle button x 2 then F1 then F2 go to service completed exept
Posted on Nov 26, 2014
SOURCE: ingersoll Rand SSR compressor shuts down loaded or
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Posted on Sep 25, 2009
  • 243 Answers
SOURCE: i have an ingersoll rand P185WJD Compressor that
possible that one of the protections switch it off check oil levels motor and screw can also be a sensor, can check these by briging them one by one. first indication is control lamp. or possible fuel problem check filters and tank. also check wiring complete. is weak point for ir machines. good luck.
Posted on Feb 10, 2010
  • 409 Answers
SOURCE: I am changing from 460 V to 230 V on a Ingersol rand Compressor
Recheck the way you have the motor leads hooked up, make sure they are correct. You did re connect the motor leads didnt you? You are not trying to run it on 230v single phase are you? Assuming it is a dual voltage motor, the leads will have to be re connected from hi voltage to lo voltage. Also when you cut the operating voltage in half the operating current(amps ) will double, all this info should be on the motor name plate. This motor does not use a capicitor to start it
Posted on Mar 17, 2010
compman66
  • 169 Answers
SOURCE: what type of oil for ingersoll rand model 2475 air
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
Posted on May 12, 2010
  • 5603 Answers
SOURCE: ingersoll rand SSR 100Hp w/
Look for any problem involving a dropped phase of the input power. It could be a transient one such as a poor contact that the sensor detects a glitch which then cures itself when you overide the watchdog of the system. Tighten all electrical connections and while doing so look for any heating indicators such as discolored insulation. The electronics can see very short failures that are punched through when running manually. That is what the smart controllers are for to protect the motor. The controller itself probably only uses one phase for its own power. The transient might happen in a tenth of a second.
Posted on Feb 24, 2011
How to change from BAR to PSI on INGERSOLL RAND INTELLISYS CONTROL for INGERSOLL RAND SSR-6-20-125 AIR COMPRESSOR
Ingersolll Rand website support section should be able to provide a manual.
Failing that contact customer services.
Aug 03, 2016 | Ingersoll Rand Air Tools & Compressors
How do I reset the service alarm on all Intellisys controllers of Ingersoll Rand?
when controller says ready to start you must press display select button then hidden left button which you can feel as a raised
arrea under the membrane between the display select button and the orange ringed centre button. the screen should say checking machine a nd then ready to start if it has reset. if it comes up with line pressure then you must get back to ready to start and repeat method. this assumes the compressor has the SE Controller with green LCD screen
Oct 02, 2013 | Ingersoll Rand Air Tools & Compressors
I'm working on a Ingersoll rand 100HP stationary compressor with an intellisys 39875158 controller.
Make sure the model of your compressor is design for 160psi if not the main motor trip off and safe valve pop. Goto Main Menu, Operator setpoint+select, Offline/Online+select, arrow up and down to change value.
Jul 04, 2012 | Ingersoll Rand Stationary Air Cooled...
Air Tools & Compressors Logo
207 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
