Question about Indesit 24 in. D63 Free-standing Dishwasher
My electrolux esl624 dishwasher keeps tripping the element and inlet valve were changed
Esl624 tripping fuse even when off
Hi. Your dishwasher has probably a leak on the pressure side of the circulation and spraying water over all the electrics including the mains filter. this will trip the electrics without being switched on. It needs to dry out and the leak fixeded. check the hose from the cartridge heater to the top spray arm hose. You will need someone with insulation teater to test all components for earth leakage. good look.
Aug 04, 2012 | Electrolux 23 in. ESI602X Built-in...
ESL624 dishwasher. On any cycle the machine stops after about a minute or 2. Its as if it cuts out for some reason, It pumps out but it doesn't get to the point where it starts letting water in....
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Jun 28, 2011 | Electrolux 23 in. ESL624 Built-in...
WATER REMAINS IN WASHER AFTER CLEANING CYCLE
Possible that the drain is blocked/choked or the drain pump/valve is faulty. You must remove the drain valve/pump and make a good cleaning of the unit . check on the outside with the voltage sepcified to confirm.
Finally make sure that the program controller unit supplies voltage to the unit till the water drains off. if not the time and the drain flow can be low. Keep the washer tilted to the drain flow.
Feb 14, 2011 | Electrolux 23 in. ESL624 Built-in...
The detergent capsules doe snot get used during the cycle. It just stays in the holder and gets damp. any suggestions?
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 05, 2010 | Electrolux 23 in. ESL624 Built-in...
Not filling
Hi
When the Dishwasher is not filling in, you’ll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don’t get any value on the multimeter hen you'll need to replace the water inlet valve assembly.
Please post back for any further assistance.
Daniel
Aug 20, 2010 | Electrolux 23 in. ESL624 Built-in...
My dishwasher is having any water to it
Check water valve from sink.
Sometimes there is a sreen at the hose connection make sure it is clean
Listen for the automated valve to turn on. No valve operation no water. They can fail
Mar 24, 2010 | Electrolux 23 in. ESL624 Built-in...
Washing up liquid was put in the dishwasher...how do I get rid of it?
cold water and keep draining it take about ten times it should come out of it
Dec 06, 2009 | Electrolux 23 in. ESL624 Built-in...
Electrolux ESL 6225
before you operate the dishwasher get your water as hot at the sink as you can this will prevent filling the dish washer with cold water and i would use powder or liquid now if you not sure of your heating element turn your washer to dry close the door for about 2-3 minutes get a glass of cold water open the door and pour water on the element if it sizzles its working
Feb 12, 2008 | Electrolux 23 in. ESL624 Built-in...
Electrolux esl624 heater element replacement
open the door remove the plinth (2 screws) then there is 2 screws higher up remove these (some people remove outer door panel to get easy access) then leaver the front plate up. then you can see the wires on the heater and the bolts are between them. hope this helps
Feb 10, 2008 | Electrolux 23 in. ESL624 Built-in...
Dishwasher trips RCD electrics
fault is probably heating element but you need a megga to test it. other disconnect element, tape up wires then check on wash cycle. be carefull!!
Mar 20, 2007 | Electrolux 23 in. ESL624 Built-in...
Indesit 24 in. D63 Free-standing Dishwasher Logo
21 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
