Question about HP ProLiant DL365 G5 Server
Hp proliant dl365 g5 windows 2012 does not see hard drive
I'm trying to install Windows Server 2012 on an HP Proliant dl365 G5 server, but when I use a single hard drive for installation, it is not detected by Windows.
sam_HP_user
SOURCE: STORAGE
Hi, I found this thread interesting. Will try it out today.
http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?prodSeriesId=3799613&prodTypeId=18964&threadId=1285096&admit=109447626+1237817674797+28353475
It says that the right driver is not in the support CD!! As per the link, the problem was solved for him once he used a USB Floppy drive (Windows compatible).
Posted on Mar 23, 2009
ted1430
  • 339 Answers
SOURCE: hp proliant ml350 g5 vga drivers for windows 2000 professional
Download the latest Proliant Support Pack from HP's web site. This will update the drivers for everything on the server at once.
Just go to hp.com and click the link for "Support & Drivers" at the top, then click the radio button to download drivers and enter ML350 into the text box. Select the G5 from the list and then select your OS. The PSP will be near the bottom of the page. The display driver will be close to the top if you just want to update it.
Posted on Jul 12, 2009
  • 1481 Answers
SOURCE: i have HP proliant Ml110 g5 server and i want to
visit my site
www.sureshayyar.110mb.com
for all installation issues of XP....detailed instructions can be found to install XP there...browse all pages there....
which driver are u looking for and which one you have for what hardware ?
Posted on Mar 27, 2010
  • 166 Answers
SOURCE: Hard disk not found message coming while
Save any critical or important files. Even if this is an secondary hard drive installation.
Turn off the power and unplug the PC from the outlet. Also, unplug all external connections to the Windows PC. Be sure to touch something metal to ground the user. Static electrical shocks can damage a PC.
Open the PC housing and determine the placement of the hard drive. Generally computers come with a latch that, when pressed, opens the housing. Make certain the space necessary for the hard drive is available. Usually the drive bays are in the front of the PC near the CD or DVD drives.
Make sure the IDE jumpers are set correctly. If the hard drive is the primary drive then set the jumpers to "Master" mode. If the hard drive is the secondary drive then set the jumpers to "Slave" mode. Please consult the hard drive's manual for the proper jumper setting for each mode. Another possibility--if there are two hard drive, set both drives to "Cable select" mode and the Windows PC will choose which one to make "Master" and "Slave."
5
Mount the hard drive in the available internal slot. The drive is sometimes mounted with four screws to the drive bay. Some internal drives have a rail that slides into the open bay. Look at the other devices to determine which mounting option is available in the specific computer.
6
Connect the hard drive cables to the Windows PC. Connect the power supply connector to the available cable. Next, connect the data cable to the available connector. The internal data cable usually has a red stripe to make identification easier.
7
Close the housing and reconnect the external power supply. Plug the external cables back into the computer and reconnect to the power supply.
8
Configure the BIOS. The BIOS (Basic Input/Output System) is accessible during computer start-up. To access the BIOS consult the computer manual to find out with which key press during start-up. Most often, the key is F8. Once in the BIOS change the hard drive setting to "Auto detect." When finished, exit the BIOS and allow the start-up to continue.
9
Format and partition the Windows PC hard drive. Select "Start" from the operating system menu. Choose "Control panel" from the start menu. Next click on "Administrative tools". From the administrative tools menu choose the "Computer management" icon and finally "Disk management." Choose the new hard drive and right click. Select "New partition" from the right click menu. Follow the on-screen option to partition and format the drive the drive.
10
Restart the computer and check the hard drive to ensure it is operating properly.
Posted on Feb 23, 2011
  • 24 Answers
SOURCE: i am unable to instal
Option 1 (HIGLY Recommended): HP servers should come with an install disk that prepares the windows installer for you. Boot from that disk,tell it your OS, and pop in the disk for the OS when prompted. It will come up fine and have all the HP monitoring agents installed.
Option 2: Load the driver the old fashioned way. Unless you have a floppy drive the standard "Press F6 to load drivers" trick won't work. If you do, then you'll need to put the RAID driver on the disk.
Option 3: Use an installation customizer like nLite to pre-add the RAID driver to the Windows 2003 installer.
Good luck.
Posted on Feb 28, 2011
Hello mate. i have server hp proliant ml350 g5, when i buy it ,it works ok. when i replace the HDD from 250g to 80g the system doesent work anymore. i wont to install windwos server from begening but says...
Are the hard drives connected to a RAID controller? If so you will need to configure the disk in the RAID BIOS and initialize them.
It is likely that the Windows installer still will not recognize the drive because you will need to provide the drivers to the RAID controller during the installation process.
Aug 09, 2012 | HP Compaq ProLiant ML350 G5 Server
I am unable to instal windows server 2003 on HP Proliant ML150 G5 because it gives me message no hard drive found
Good luck.
Feb 26, 2011 | HP ProLiant ML150 G5 Server
Hard disk not found message coming while installing windows server 2003 on Hp Proliant ML150 G5
You need to press F6 and load special drivers for your disk driver card
See which disk adapter your server has and get the drivers on a floppy disk
Put the disk into your computer before seutp, then click F6 when prompted
it will search your floppy drive for them
Feb 15, 2011 | HP ProLiant ML150 G5 Server
My HP ProLiant ML350 G5 failed to boot to Windows. After showing Windows 2003 Server, blank screen comes up
There was a critical HP ProLiant ML350 G5 ROM BIO upgrade dated on 17 Aug 2010.
Please bookmark the bio update link HERE for reference.
Check your monitor Hz and display resolution setting.
Did you change any video driver or resolution before reboot?
If all else fail then swap in a simple S-VGA card and let Windows 2003 to sort out the 640X480 display mode.
Jan 05, 2011 | HP Compaq ProLiant ML350 G5 Server
I have HP ProLiant DL360 G5 Server i found
For Server-HP Proliant , Boot using SmartStart Cd(if you don't have download iso image from HP support site--Free & burn it to media)
Now boot using this Smartstart cd and choose Maintain Server...Use Diagostic options..to check hardware.....Also check Drives status....if amber light
Replace hardware or it is Contact HP for any hardware issue
Oct 05, 2009 | HP Smart Buy HP ProLiant DL360 G5 (2x)...
Hp proliant ml350 g5 vga drivers for windows 2000 professional
Apr 08, 2009 | HP ProLiant ML350 G5 Server
STORAGE
Sep 08, 2008 | HP ProLiant ML150 G5 Server
HP ProLiant DL365 G5  Server Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
